Hoeveel mag ik verwachten en hoe lang kan het duren eer die verbetering er is?
B-Box 3 Sagem Tool v0.12.0
Device: B-Box 3 Sagem
Downstream current bit rate: 40 199 kbps
Upstream current bit rate: 10 054 kbps
Downstream max bit rate: 73 605 kbps
Upstream max bit rate: 19 701 kbps
Downstream attenuation: 11,2 dB
Downstream noise margin: 16,8 dB
Upstream noise margin: 11,0 dB
Vectoring down: no
Vectoring up: no
Modem vectoring compatible: yes
ROP vectoring compatible: Unknown
DSL standard: VDSL2
DSL profile: 17a
Estimated distance: 236 m
Proximus profile name: 40/10
Proximus DLM profile: yes
Proximus repair profile: no
