![Exclamation :!:](./images/smilies/icon_exclaim.gif)
YES YES YES
Problem solved!
Door deze post die ik op een ander forum vond, waar ik ook flink wat op poste vond ik het.
Het lag niet aan het soort kabel dat ik gebruikte of dat mijn ethernet stuk zou zijn, het lag eigenlijk bij iets simpelers:
Does your Mac Ethernet/Wireless keep giving you a fake 169.254.x.x ip address?
Recently I started running Mac OS X Leopard (10.5.
![Cool 8)](./images/smilies/icon_cool.gif)
on my spare computer. It worked fine for a few days until one day when I changed my router, my Mac stopped connecting to the router. It would repeatedly get a 169.254.x.x ip address through DHCP. If I set the IP address manually, it would show that it assigned the IP address, yet it would still not “properly” be connected in the background.
So here is what I did to fix this problem. Open up Terminal using Spotlight. And type the command:
sudo ifconfig en0 ether 00:11:22:33:44:55
It will then ask you for your password. That’s it.
Explanation:
sudo: Gives you administrative power
ifconfig: the program that interacts with all your connectivity configurations
en0: the interface’s name, it could also be en1, en2, etc. (depending on the amount of network wired/wireless cards you have)
00:11:22:33:44:55: the mac address, pick whatever hex combination (i.e. only use characters 0-9 and a-z)
BEDANKT AAN IEDEREEN VOOR DE HULP!
Heb in ieder geval veel bijgeleerd.
WIE NIET OPGEEFT ZAL ZIJN DOEL BEREIKEN
