Er zit een volledige linux driver cd bij, met source code!
Deze heb ik dus kunnen compileren, en werkend gekregen, voor een meer recente vortexbox 2.2 beta kernel:
[vortexbox.localdomain hostapd]# find /lib -name '*8192eu*'
/lib/modules/3.9.4-101.fc16.i686/kernel/drivers/net/wireless/8192eu.ko
wlan0 Link encap:Ethernet HWaddr 00:E0:4C:01:92:13
inet addr:203.0.113.1 Bcast:203.0.113.255 Mask:255.255.255.0
inet6 addr: fe80::2e0:4cff:fe01:9213/64 Scope:Link
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:1 overruns:0 frame:0
TX packets:0 errors:0 dropped:3 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 b) TX bytes:0 (0.0 b)
[vortexbox.localdomain hostapd]# ls -al hostapd
-rwxr-xr-x 1 root root 1797290 Nov 3 14:44 hostapd
[vortexbox.localdomain hostapd]# pwd
/storage/linux/wpa_supplicant_hostapd/wpa_supplicant_hostapd-0.8_rtw_r7048.20130424/hostapdCode: Selecteer alles
[root@vortexbox hostapd]# cat /tmp/hostapd.conf
interface=wlan0
logger_syslog=-1
logger_syslog_level=2
logger_stdout=-1
logger_stdout_level=2
dump_file=/tmp/hostapd.dump
ctrl_interface=/var/run/hostapd
ctrl_interface_group=0
ssid=432EVO
country_code=BE
hw_mode=b
channel=6
beacon_int=100
dtim_period=2
max_num_sta=255
rts_threshold=2347
fragm_threshold=2346
macaddr_acl=0
auth_algs=3
ignore_broadcast_ssid=0
wpa=2
wpa_passphrase=gfsetkqefkk
[root@vortexbox hostapd]# ./hostapd /tmp/hostapd.conf
Configuration file: /tmp/hostapd.conf
drv->ifindex=5
l2_sock_recv==l2_sock_xmit=0x0x9a6d5a8
rtl871x_set_rts_threshold, rts=2347
rtl871x_set_frag_threshold, frag=2346
+rtl871x_sta_deauth_ops, ff:ff:ff:ff:ff:ff is deauth, reason=2
rtl871x_set_key_ops
rtl871x_set_key_ops
rtl871x_set_key_ops
rtl871x_set_key_ops
Using interface wlan0 with hwaddr 00:e0:4c:01:92:13 and ssid '432EVO'
rtl871x_set_wps_assoc_resp_ie
rtl871x_set_wps_beacon_ie
rtl871x_set_wps_probe_resp_ie
rtl871x_set_key_ops
rtl871x_set_beacon_ops
rtl871x_set_hidden_ssid ignore_broadcast_ssid:0, 432EVO,6
rtl871x_set_acl
Ik heb even de stralingsmeter ernaast gelegd, en ik merk dat de dongle enkel bij het opstarten van hostapd de typische 100ms ticks (SSID broadcasts) uitzendt, en nadien niks meer.
Hier een echte access point, die blijft uiteraard 24/7 SSID broadcasts pulsen a 10 tikken per seconde.
iwconfig toont wel de Master mode (access point mode), maar ook geen security, en das bizar:
[vortexbox.localdomain hostapd]# iwconfig
wlan0 unassociated Nickname:"<WIFI@REALTEK>"
Mode:Master Frequency=2.437 GHz Access Point: 00:E0:4C:01:92:13
Sensitivity:0/0
Retry:off RTS thr:off Fragment thr:off
Encryption key:off
Power Management:off
Link Quality:0 Signal level:0 Noise level:0
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:0 Missed beacon:0Net een netgear stick gevonden die bij m'n panasonic tv zat, werkt direct met de standaard hostapd van fc16 en bovenstaande config.
Dus pech action ...
