Januari 2023
B-Box 3 Sagem Tool v0.13.0
Device: B-Box 3 Sagem
Downstream current bit rate: 30.057 kbps
Upstream current bit rate: 4.053 kbps
Downstream max bit rate: 42.745 kbps
Upstream max bit rate: 4.053 kbps
Downstream attenuation: 16,2 dB
Downstream noise margin: 19,0 dB
Upstream noise margin: 9,4 dB
Vectoring down: no
Vectoring up: no
Modem vectoring compatible: yes
ROP vectoring compatible: no
DSL standard: VDSL2 Annex B
DSL profile: unknown
Estimated distance: 535 m
Proximus profile name: 30/4
Proximus DLM profile: yes
Proximus repair profile: noCode: Selecteer alles
Downstream current bit rate: 16.550 kbps
Upstream current bit rate: 2.062 kbps
Downstream max bit rate: 54.854 kbps
Upstream max bit rate: 13.458 kbps
Downstream attenuation: 16,4 dB
Downstream noise margin: 28,4 dB
Upstream noise margin: 31,9 dB
Vectoring down: no
Vectoring up: no
DSL profile: 8d
Estimated distance: 489 m
Proximus profile name: 16,5/2
Proximus DLM profile: unknown
Proximus repair profile: noMen bevestigt mij dat Proximus zal ingrijpen, na 4 dagen (modem blijft altijd aan) alweer geen resultaat, terwijl de beschikbare snelheid wel hoger staat.
Graag jullie mening hierover,
Citymesh - 300GB
Hey! (modem in bridge)
