who can change my profile?
I do not know where I can complain to Proximus.
Because I actually have to have more speed.
565 meters normal must be at least 50 Mbits
Nee, de max bitrate is in principe 'de max' dat je lijn kan hebben (waarvan je meestal een stukje minder krijgt om stabiliteit te garanderen).bartman schreef:De max bit rate is dat te halen met een netwerkkabel?
[code]
B-Box 3 Sagem Tool v0.13.0
Device: B-Box 3 Sagem
Downstream current bit rate: 69,999 kbps
Upstream current bit rate: 30,434 kbps
Downstream max bit rate: 83,971 kbps
Upstream max bit rate: 36,369 kbps
Downstream attenuation: 14.6 dB
Downstream noise margin: 10.7 dB
Upstream noise margin: 9.3 dB
Vectoring down: yes
Vectoring up: yes
Modem vectoring compatible: yes
ROP vectoring compatible: yes
DSL standard: VDSL2 Annex B
DSL profile: 17a
Estimated distance: 344 m
Proximus profile name: 70/30
Proximus DLM profile: no
Proximus repair profile: no
Downstream current bit rate: 85,000 kbps
Upstream current bit rate: 35,000 kbps
Downstream max bit rate: 114,015 kbps
Upstream max bit rate: 40,565 kbps
Downstream attenuation: 16.4 dB
Downstream noise margin: 15.9 dB
Upstream noise margin: 9.1 dB
Vectoring down: yes
Vectoring up: yes
DSL profile: 17a
Estimated distance: 414 m
Proximus profile name: 85/35
Proximus DLM profile: yes
Downstream current bit rate: 70.417 kbps
Upstream current bit rate: 19.999 kbps
Downstream max bit rate: 88.945 kbps
Upstream max bit rate: 22.864 kbps
Downstream attenuation: 19,4 dB
Downstream noise margin: 12,3 dB
Upstream noise margin: 7,1 dB
Vectoring down: yes
Vectoring up: yes
DSL profile: 17a
Estimated distance: 516 m
Proximus profile name: 70/20
Alle b-box 3v+ zijn Sagemcom modellen. Dus, geen zorgen.dupondje schreef:Werkt de BBOX tool eigenlijk op een BBOX 3v+?
Downstream current bit rate: 69 999 kbps
Upstream current bit rate: 35 000 kbps
Downstream max bit rate: 109 138 kbps
Upstream max bit rate: 41 340 kbps
Downstream attenuation: 17,9 dB
Downstream noise margin: 19,4 dB
Upstream noise margin: 9,8 dB
Vectoring down: yes
Vectoring up: yes
DSL profile: 17a
Estimated distance: 450 m
Proximus profile name: 70/35
Ik stond vroeger op 85/35 maar sinds nieuwe buren ben ik gezakt naar 70 profiel. zou een lijntest iets uithalen?EotT schreef:DLM zal jouw lijn waarschijnlijk nog wel verhogen naar 85/35. Hiervoor moet je niks doen, gewoon geduld hebben. 100/35 zal waarschijnlijk niet lukken denk ik.
