who can change my profile?
I do not know where I can complain to Proximus.
Because I actually have to have more speed.
565 meters normal must be at least 50 Mbits
![Afbeelding](https://s12.directupload.net/images/200416/8n9flgfw.jpg)
Nee, de max bitrate is in principe 'de max' dat je lijn kan hebben (waarvan je meestal een stukje minder krijgt om stabiliteit te garanderen).bartman schreef:De max bit rate is dat te halen met een netwerkkabel?
[code]
B-Box 3 Sagem Tool v0.13.0
Device: B-Box 3 Sagem
Downstream current bit rate: 69,999 kbps
Upstream current bit rate: 30,434 kbps
Downstream max bit rate: 83,971 kbps
Upstream max bit rate: 36,369 kbps
Downstream attenuation: 14.6 dB
Downstream noise margin: 10.7 dB
Upstream noise margin: 9.3 dB
Vectoring down: yes
Vectoring up: yes
Modem vectoring compatible: yes
ROP vectoring compatible: yes
DSL standard: VDSL2 Annex B
DSL profile: 17a
Estimated distance: 344 m
Proximus profile name: 70/30
Proximus DLM profile: no
Proximus repair profile: no
Downstream current bit rate: 85,000 kbps
Upstream current bit rate: 35,000 kbps
Downstream max bit rate: 114,015 kbps
Upstream max bit rate: 40,565 kbps
Downstream attenuation: 16.4 dB
Downstream noise margin: 15.9 dB
Upstream noise margin: 9.1 dB
Vectoring down: yes
Vectoring up: yes
DSL profile: 17a
Estimated distance: 414 m
Proximus profile name: 85/35
Proximus DLM profile: yes
Downstream current bit rate: 70.417 kbps
Upstream current bit rate: 19.999 kbps
Downstream max bit rate: 88.945 kbps
Upstream max bit rate: 22.864 kbps
Downstream attenuation: 19,4 dB
Downstream noise margin: 12,3 dB
Upstream noise margin: 7,1 dB
Vectoring down: yes
Vectoring up: yes
DSL profile: 17a
Estimated distance: 516 m
Proximus profile name: 70/20
Alle b-box 3v+ zijn Sagemcom modellen. Dus, geen zorgen.dupondje schreef:Werkt de BBOX tool eigenlijk op een BBOX 3v+?
Downstream current bit rate: 69 999 kbps
Upstream current bit rate: 35 000 kbps
Downstream max bit rate: 109 138 kbps
Upstream max bit rate: 41 340 kbps
Downstream attenuation: 17,9 dB
Downstream noise margin: 19,4 dB
Upstream noise margin: 9,8 dB
Vectoring down: yes
Vectoring up: yes
DSL profile: 17a
Estimated distance: 450 m
Proximus profile name: 70/35
Ik stond vroeger op 85/35 maar sinds nieuwe buren ben ik gezakt naar 70 profiel. zou een lijntest iets uithalen?EotT schreef:DLM zal jouw lijn waarschijnlijk nog wel verhogen naar 85/35. Hiervoor moet je niks doen, gewoon geduld hebben. 100/35 zal waarschijnlijk niet lukken denk ik.
