Te koop aangeboden RAM, CPU, Chassis en netwerk. Bij aankoop van meerdere zaken valt er altijd over te prijs te praten.
RAM
32 x SAMSUNG 8GB 2Rx4 PC3L-10600R-09-11-E2-D3 (12,50 per stuk)
1 x SAMSUNG 8GB 2Rx4 PC3L-10600R-09-11-E2-P2 (12,50 per stuk)
6 x HYNIX 4GB 1Rx4 PC3L-10600R-9-11-C2 (7,50 per stuk)
24 x SAMSUNG 4GB 2Rx8 PC3-10600R-09-10-B0-D2 (7,50 per stuk)
6 X 2GB 1Rx8 PC3-10600R-09-10-A1-D2 (2,50 per stuk)
2 x SAMSUNG 2GB 1Rx8 PC3-10600E-09-10-D0 (2,50 per stuk)
4 x 2GB 2Rx4 PC2-5300F-555-11-E0 (2,50 per stuk)
6 x 2GB 2Rx8 PC3-10600E-09-11-E3 (2,50 per stuk)
8 x NANYA 2GB 2Rx4 PC2-5300F-555-11-E2-667-ECC (2,50 per stuk)
4 x HYS72T256420HFA-3S-B 2GB 2Rx4 PC2-5300F-555-11-H0 (2,50 per stuk)
1 x SAMSUNG 2GB 1Rx8 PC3-10600E-09-10-D0 (2,50 per stuk)
6 x HYNIX 1GB 1Rx8 PC3-8500E-7-10-D0 (1,50 per stuk)
4 x HYNIX 1GB 1Rx8 PC2-5300F-555-11 (1,50 per stuk)
CPU
4x E5-2660 2,20 Ghz (30 per stuk)
2x E5-2630 2,30 Ghz (25 per stuk)
2x E3-1220 3,10 Ghz (10 per stuk)
23x X5650 2,66 Ghz (7,50 per stuk)
4x E5620 2,40 Ghz (5 per stuk)
2 x E5-2403 1,80 Ghz (5 per stuk)
4x E5503 2,00 Ghz (5 per stuk)
3x E5506 2,13 Ghz (5 per stuk)
7x L5640 2,26 Ghz (10 per stuk)
2x E5420 2,50 Ghz (5 per stuk)
4x E5320 1,86 Ghz (5 per stuk)
2x E5520 2,26 Ghz (5 per stuk)
1x E5502 1,86 Ghz (5 per stuk)
3x X3430 2,40 Ghz (7,50 per stuk)
2x X3440 2,53 Ghz (7,50 per stuk)
4x E5310 1,50 Ghz (5 per stuk)
3x 3065 2,33 Ghz (5 per stuk)
NETWERK
9x Intel Dual Port DP 10gbe Ethernet Network Adapter Dell 0VFVGR Full Profile (50 per stuk)
2x Intel Dual Port DP 10gbe Ethernet Network Adapter Dell 0VFVGR Half Profile (50 per stuk)
4x INTEL-DELL-X520-T2-10GB-DUAL-PORT-ETHERNET-SERVER-ADAPTER-0JM42W Full Profile (50 per stuk)
1x Hot lava Tambora 64G 6x10gbe SFP+ (150 per stuk)
2x Hot lava Shasta 6x1gbe SFP+ (50 per stuk)
2x HP 530SFP+ PCI-E DUAL PORT 10GBE SERVER ADAPTER Full Profile (50 per stuk)
1x Dell Intel Pro/1000 ET Quad Port Gigabit Ethernet PCI-E Network Card NIC CWKPJ 0CWKPJ (5 per stuk)
Lege CHASSIS (incl. voeding en nieuwe power cables)
(de meeste ook incl rails, vraag gerust na)
1x IBM iDataplex dx360 M4 2u (incl 2 blades) (65 euro per stuk)
2x Dell PowerEdge C6100 (25 euro per stuk)
7x Dell PowerEdge R710 (zowel LFF als SFF) (25 euro per stuk)
5x Dell PowerEdge R610 SFF (25 euro per stuk)
1x Dell PowerEdge R410 LFF (25 euro per stuk)
5x Dell PowerEdge R310 LFF (25 euro per stuk)
3x Dell PowerEdge R200 (15 euro per stuk)
9x HP DL120G7 (15 euro per stuk)
5x Dell PowerEdge 2950 (10 euro per stuk)
1x Dell PowerEdge SC1425 (10 euro per stuk)
Einddatum/uur: dit is vrijdag 15 november 20:00.
Alles is werkende uit server / datacenter gehaald.
Ophalen regio Dendermonde of verzending op kosten van de koper.
RAM CPU CHASSIS (Server onderdelen)
- Uitgedeelde bedankjes: 228 keer
- Bedankt: 45 keer
Hoi, heb hier een optiplex 7010 SFF met:
Heb daar proxmox op geïnstalleerd en zou een paar extra netwerkaansluitingen willen hebben.
Is er 1 van die NIC's die daar in zou kunnen passen?
Expansion Slots:
1 half height PCIe x16
1 half height PCIe x16 (wired x 4)
Gelukkig & gezond 2022!
- Bedankt: 343 keer
Ik ga vanavond eens kijken welk RAM ik in men zelfbouwnas heb steken om wat uit te breiden. En in die 10GB netwerkkaarten heb ik ook interesse, eerst eens kijken welk profiel zou passen vanavond + de compatibiliteit met FreeNAS.
- ISP Official
- Bedankt: 7 keer
Moederborden zitten er ook nog in, sorry voor de onduidelijkheid.Splitter schreef:ook een mogelijkheid dat je nog moederborden voor die dells verkoopt?
De chassis zijn met moederbord, voeding (incl. cables), bezel, meeste met rails (best navragen wat dat betreft), (wat caddy's betreft ook best navragen), geen CPU, geen RAM, geen Disk.
- Splitter
- Bedankt: 446 keer
voor mij dan aub het volgende:
- 1x Dell PowerEdge R410 LFF
- 1x L5640
- 4x SAMSUNG 4GB 2Rx8 PC3-10600R-09-10-B0-D2
- 1x Dell Intel Pro/1000 ET Quad Port Gigabit Ethernet PCI-E Network Card NIC CWKPJ 0CWKPJ
- 1x L5640
- Splitter
- Bedankt: 446 keer
(onder voorbehoud dat die ook in niet-dell systemen werkt)Splitter schreef:1x Intel Dual Port DP 10gbe Ethernet Network Adapter Dell 0VFVGR Half Profile mag er voor mij ook nog extra bij
- mailracer
- Uitgedeelde bedankjes: 224 keer
- Bedankt: 318 keer
Enmailracer schreef:Ik reserveer volgend item :
INTEL-DELL-X520-T2-10GB-DUAL-PORT-ETHERNET-SERVER-ADAPTER-0JM42W Full Profile : 2 stuks
Intel Dual Port DP 10gbe Ethernet Network Adapter Dell 0VFVGR Half Profile : 1stuk
Met verzending
- ISP Official
- Bedankt: 7 keer
Hi mailracer, ik heb je een mailtje gestuurdmailracer schreef:Enmailracer schreef:Ik reserveer volgend item :
Met verzending
FlexieLex schreef:Ik kom graag het volgende ophalen;
- 1x IBM iDataplex dx360 M4 2u
- 1x Dell PowerEdge R710 lff
- 1x Dell PowerEdge R710 sff
+ 2x L5640
... en wellicht nog passende 10gbe netwerk kaarten
- mailracer
- Bedankt: 318 keer
Ik kan bevestigen dat deze onder win10 en onder winserver 2019 werkt zonder problemen. Ik heb mijn onderdelen vandaag trouwens ontvangen en ben er zeer tevreden van. Ze zien eruit als nieuw en werken perfect zonder issues.Splitter schreef:(onder voorbehoud dat die ook in niet-dell systemen werkt)Splitter schreef:1x Intel Dual Port DP 10gbe Ethernet Network Adapter Dell 0VFVGR Half Profile mag er voor mij ook nog extra bij
Hoi,
ik kan nog 1 Intel Dual Port DP 10gbe Ethernet Network Adapter Dell 0VFVGR Full Profile (50 per stuk) en 1 Intel Dual Port DP 10gbe Ethernet Network Adapter Dell 0VFVGR Half Profile (50 per stuk) gebruiken.
Zijn deze nog beschikbaar? Ik kom ze afhalen.
- ISP Official
- Bedankt: 7 keer
Wim
Ik stuur een bericht.
wimvg schreef:Hoi,
