RAM CPU CHASSIS (Server onderdelen)
jdooren
ISP Official
ISP Official
Bedankt: 7 keer
Te koop aangeboden RAM, CPU, Chassis en netwerk. Bij aankoop van meerdere zaken valt er altijd over te prijs te praten.
RAM
32 x SAMSUNG 8GB 2Rx4 PC3L-10600R-09-11-E2-D3 (12,50 per stuk)
1 x SAMSUNG 8GB 2Rx4 PC3L-10600R-09-11-E2-P2 (12,50 per stuk)
6 x HYNIX 4GB 1Rx4 PC3L-10600R-9-11-C2 (7,50 per stuk)
24 x SAMSUNG 4GB 2Rx8 PC3-10600R-09-10-B0-D2 (7,50 per stuk)
6 X 2GB 1Rx8 PC3-10600R-09-10-A1-D2 (2,50 per stuk)
2 x SAMSUNG 2GB 1Rx8 PC3-10600E-09-10-D0 (2,50 per stuk)
4 x 2GB 2Rx4 PC2-5300F-555-11-E0 (2,50 per stuk)
6 x 2GB 2Rx8 PC3-10600E-09-11-E3 (2,50 per stuk)
8 x NANYA 2GB 2Rx4 PC2-5300F-555-11-E2-667-ECC (2,50 per stuk)
4 x HYS72T256420HFA-3S-B 2GB 2Rx4 PC2-5300F-555-11-H0 (2,50 per stuk)
1 x SAMSUNG 2GB 1Rx8 PC3-10600E-09-10-D0 (2,50 per stuk)
6 x HYNIX 1GB 1Rx8 PC3-8500E-7-10-D0 (1,50 per stuk)
4 x HYNIX 1GB 1Rx8 PC2-5300F-555-11 (1,50 per stuk)
CPU
4x E5-2660 2,20 Ghz (30 per stuk)
2x E5-2630 2,30 Ghz (25 per stuk)
2x E3-1220 3,10 Ghz (10 per stuk)
23x X5650 2,66 Ghz (7,50 per stuk)
4x E5620 2,40 Ghz (5 per stuk)
2 x E5-2403 1,80 Ghz (5 per stuk)
4x E5503 2,00 Ghz (5 per stuk)
3x E5506 2,13 Ghz (5 per stuk)
7x L5640 2,26 Ghz (10 per stuk)
2x E5420 2,50 Ghz (5 per stuk)
4x E5320 1,86 Ghz (5 per stuk)
2x E5520 2,26 Ghz (5 per stuk)
1x E5502 1,86 Ghz (5 per stuk)
3x X3430 2,40 Ghz (7,50 per stuk)
2x X3440 2,53 Ghz (7,50 per stuk)
4x E5310 1,50 Ghz (5 per stuk)
3x 3065 2,33 Ghz (5 per stuk)
NETWERK
9x Intel Dual Port DP 10gbe Ethernet Network Adapter Dell 0VFVGR Full Profile (50 per stuk)
2x Intel Dual Port DP 10gbe Ethernet Network Adapter Dell 0VFVGR Half Profile (50 per stuk)
4x INTEL-DELL-X520-T2-10GB-DUAL-PORT-ETHERNET-SERVER-ADAPTER-0JM42W Full Profile (50 per stuk)
1x Hot lava Tambora 64G 6x10gbe SFP+ (150 per stuk)
2x Hot lava Shasta 6x1gbe SFP+ (50 per stuk)
2x HP 530SFP+ PCI-E DUAL PORT 10GBE SERVER ADAPTER Full Profile (50 per stuk)
1x Dell Intel Pro/1000 ET Quad Port Gigabit Ethernet PCI-E Network Card NIC CWKPJ 0CWKPJ (5 per stuk)
Lege CHASSIS (incl. voeding en nieuwe power cables)
(de meeste ook incl rails, vraag gerust na)
1x IBM iDataplex dx360 M4 2u (incl 2 blades) (65 euro per stuk)
2x Dell PowerEdge C6100 (25 euro per stuk)
7x Dell PowerEdge R710 (zowel LFF als SFF) (25 euro per stuk)
5x Dell PowerEdge R610 SFF (25 euro per stuk)
1x Dell PowerEdge R410 LFF (25 euro per stuk)
5x Dell PowerEdge R310 LFF (25 euro per stuk)
3x Dell PowerEdge R200 (15 euro per stuk)
9x HP DL120G7 (15 euro per stuk)
5x Dell PowerEdge 2950 (10 euro per stuk)
1x Dell PowerEdge SC1425 (10 euro per stuk)
Einddatum/uur: dit is vrijdag 15 november 20:00.
Alles is werkende uit server / datacenter gehaald.
Ophalen regio Dendermonde of verzending op kosten van de koper.
Bedankt: 598 keer
ook een mogelijkheid dat je nog moederborden voor die dells verkoopt?
Ernie
Bedankt: 57 keer
Hoi, heb hier een optiplex 7010 SFF met:
Expansion Slots:
1 half height PCIe x16
1 half height PCIe x16 (wired x 4)
Heb daar proxmox op geïnstalleerd en zou een paar extra netwerkaansluitingen willen hebben.
Is er 1 van die NIC's die daar in zou kunnen passen?
Heppie NY!
Ik ga vanavond eens kijken welk RAM ik in men zelfbouwnas heb steken om wat uit te breiden. En in die 10GB netwerkkaarten heb ik ook interesse, eerst eens kijken welk profiel zou passen vanavond + de compatibiliteit met FreeNAS.
NuKeM
Is de "Dell Intel Pro/1000 ET Quad Port Gigabit Ethernet PCI-E Network Card NIC CWKPJ 0CWKPJ" full profile? Zoja, dan heb ik daarin alvast interesse.
jdooren
ISP Official
ISP Official
Bedankt: 7 keer
Splitter schreef:ook een mogelijkheid dat je nog moederborden voor die dells verkoopt?
Moederborden zitten er ook nog in, sorry voor de onduidelijkheid.
De chassis zijn met moederbord, voeding (incl. cables), bezel, meeste met rails (best navragen wat dat betreft), (wat caddy's betreft ook best navragen), geen CPU, geen RAM, geen Disk.
Bedankt: 598 keer
voor mij dan aub het volgende:
- 1x Dell PowerEdge R410 LFF
- 1x L5640
- 4x SAMSUNG 4GB 2Rx8 PC3-10600R-09-10-B0-D2
- 1x Dell Intel Pro/1000 ET Quad Port Gigabit Ethernet PCI-E Network Card NIC CWKPJ 0CWKPJ
FlexieLex
Ik kom graag het volgende ophalen;
- 1x IBM iDataplex dx360 M4 2u
- 1x Dell PowerEdge R710 lff
- 1x Dell PowerEdge R710 sff
Bedankt: 598 keer
1x Intel Dual Port DP 10gbe Ethernet Network Adapter Dell 0VFVGR Half Profile mag er voor mij ook nog extra bij
Bedankt: 598 keer
Splitter schreef:1x Intel Dual Port DP 10gbe Ethernet Network Adapter Dell 0VFVGR Half Profile mag er voor mij ook nog extra bij
(onder voorbehoud dat die ook in niet-dell systemen werkt)
mailracer
Bedankt: 315 keer
Ik reserveer volgend item :
INTEL-DELL-X520-T2-10GB-DUAL-PORT-ETHERNET-SERVER-ADAPTER-0JM42W Full Profile : 2 stuks
mailracer
Bedankt: 315 keer
mailracer schreef:Ik reserveer volgend item :
En
Intel Dual Port DP 10gbe Ethernet Network Adapter Dell 0VFVGR Half Profile : 1stuk
Met verzending
jdooren
ISP Official
ISP Official
Bedankt: 7 keer
En
Met verzending
Hi mailracer, ik heb je een mailtje gestuurd ;-)
jdooren
ISP Official
ISP Official
Bedankt: 7 keer
FlexieLex schreef:Ik kom graag het volgende ophalen;
Hi
Ik stuur een berichtje
Ordon
Bedankt: 120 keer
4x X5650
jdooren
ISP Official
ISP Official
Bedankt: 7 keer
Ordon schreef:4x X5650
Ik stuur een berichtje.
FlexieLex
+ 2x L5640
... en wellicht nog passende 10gbe netwerk kaarten
Luboli
Bedankt: 63 keer
Voor mij 4x X5650 graag + verzending
Robrecht
Bedankt: 13 keer
De C6100's zijn die incl 4 "blades" ?
mailracer
Bedankt: 315 keer
Ik kan bevestigen dat deze onder win10 en onder winserver 2019 werkt zonder problemen. Ik heb mijn onderdelen vandaag trouwens ontvangen en ben er zeer tevreden van. Ze zien eruit als nieuw en werken perfect zonder issues.
wimvg
Hoi,
ik kan nog 1 Intel Dual Port DP 10gbe Ethernet Network Adapter Dell 0VFVGR Full Profile (50 per stuk) en 1 Intel Dual Port DP 10gbe Ethernet Network Adapter Dell 0VFVGR Half Profile (50 per stuk) gebruiken.
Zijn deze nog beschikbaar? Ik kom ze afhalen.
jdooren
ISP Official
ISP Official
Bedankt: 7 keer
Wim
Ik stuur een bericht.
wimvg schreef:Hoi,
Ordon
Bedankt: 120 keer
Indien nog mogelijk:
-) 1x E3-1220 3,10 Ghz (10 per stuk)
-) 2x X5650 2,66 Ghz (7,50 per stuk)
jdooren
ISP Official
ISP Official
Bedankt: 7 keer
Ordon schreef:Indien nog mogelijk:
Hi
De E3-1220 heb ik niet meer liggen.
2x X5650 is er wel nog.
wimvg
Hoi,
Ik heb interesse in 8 stuks van:
Heb je die nog?
Mvg,
Wim
jdooren
ISP Official
ISP Official
Bedankt: 7 keer
wimvg schreef:Hoi,
Heb je die nog?
Mvg,
Wim
Dag Wim
Deze zijn allen verkocht.
