De snelheid was al jaren 70/30Mbit , en ging gisteren even naar 7558/572 kbit , waarna hij nu op 30/10Mbit zit . (zie onderstaande log)
Wat zou hier gebeurd zijn ?
Huidige connectiedetails :
Max. DSLAM throughput	kbit/s	30064	10064
Min. DSLAM throughput	kbit/s	14568	640
Attainable throughput	kbit/s	88952	30563
Current throughput	kbit/s	30063	10062
Seamless rate adaptation		off	off
Latency		8 ms	4 ms
Impulse Noise Protection (INP)		3	2
G.INP		off	off
Signal-to-noise ratio	dB	22	19
Bitswap		off	on
Line attenuation	dB	8	12
Profile	17a
G.Vector		full	full
Carrier record		B43	B43Greepje uit de logfile (ip adressen ingekort) :
26.02.19   01:09:05	Internet connection established successfully. IP address: 213, DNS server: 212. and 212., gateway: 213., broadband PoP: BRAS01
26.02.19	01:09:04	Internet connection cleared.
26.02.19	01:09:04	Clearing Internet connection briefly to prevent the Internet service provider from disconnecting you in the immediate future.
25.02.19	15:43:59	Internet connection established successfully. IP address: 213., DNS server: 212. and 212., gateway: 213., broadband PoP: BRAS01
25.02.19	15:43:49	PPPoE error: Timeout. [6 messages since 25.02.19 15:42:41]
25.02.19	15:42:28	Timeout during PPP negotiation.
25.02.19	15:42:28	Internet connection cleared.
25.02.19	15:01:03	Internet connection established successfully. IP address: 213., DNS server: 212. and 212. gateway: 213., broadband PoP: BRAS01
25.02.19	15:00:51	PPPoE error: Timeout. [2 messages since 25.02.19 15:00:37]
25.02.19	15:00:31	DSL is available (DSL synchronization exists with 30063/10062 kbit/s).
25.02.19	14:59:10	DSL not responding (no DSL synchronization).
25.02.19	14:59:02	PPPoE error: Timeout.
25.02.19	14:58:56	DSL is available (DSL synchronization exists with 7558/572 kbit/s).
25.02.19	14:57:50	Timeout during PPP negotiation.
25.02.19	14:57:49	Internet connection cleared.
25.02.19	14:57:45	DSL not responding (no DSL synchronization).
25.02.19	01:39:27	Internet connection established successfully. IP address: 94., DNS server: 185. and 185., gateway: 185., broadband PoP: msr2.antcen.be
25.02.19	01:39:25	Internet connection cleared.
25.02.19	01:39:25	Clearing Internet connection briefly to prevent the Internet service provider from disconnecting you in the immediate future.
24.02.19	01:40:25	Internet connection established successfully. IP address: 94., DNS server: 185. and 185., gateway: 185., broadband PoP: msr2.antcen.be
24.02.19	01:40:24	Internet connection cleared.
24.02.19	01:40:23	Clearing Internet connection briefly to prevent the Internet service provider from disconnecting you in the immediate future.
18.02.19	21:21:13	DSL is available (DSL synchronization exists with 99998/29999 kbit/s).
