De snelheid was al jaren 70/30Mbit , en ging gisteren even naar 7558/572 kbit , waarna hij nu op 30/10Mbit zit . (zie onderstaande log)
Wat zou hier gebeurd zijn ?
Huidige connectiedetails :
Max. DSLAM throughput kbit/s 30064 10064
Min. DSLAM throughput kbit/s 14568 640
Attainable throughput kbit/s 88952 30563
Current throughput kbit/s 30063 10062
Latency 8 ms 4 ms
Impulse Noise Protection (INP) 3 2
G.INP off off
Signal-to-noise ratio dB 22 19
Bitswap off on
Line attenuation dB 8 12
Profile 17a
G.Vector full full
Carrier record B43 B43Greepje uit de logfile (ip adressen ingekort) :
26.02.19 01:09:05 Internet connection established successfully. IP address: 213, DNS server: 212. and 212., gateway: 213., broadband PoP: BRAS01
26.02.19 01:09:04 Internet connection cleared.
26.02.19 01:09:04 Clearing Internet connection briefly to prevent the Internet service provider from disconnecting you in the immediate future.
25.02.19 15:43:59 Internet connection established successfully. IP address: 213., DNS server: 212. and 212., gateway: 213., broadband PoP: BRAS01
25.02.19 15:43:49 PPPoE error: Timeout. [6 messages since 25.02.19 15:42:41]
25.02.19 15:42:28 Timeout during PPP negotiation.
25.02.19 15:42:28 Internet connection cleared.
25.02.19 15:01:03 Internet connection established successfully. IP address: 213., DNS server: 212. and 212. gateway: 213., broadband PoP: BRAS01
25.02.19 15:00:51 PPPoE error: Timeout. [2 messages since 25.02.19 15:00:37]
25.02.19 15:00:31 DSL is available (DSL synchronization exists with 30063/10062 kbit/s).
25.02.19 14:59:10 DSL not responding (no DSL synchronization).
25.02.19 14:59:02 PPPoE error: Timeout.
25.02.19 14:58:56 DSL is available (DSL synchronization exists with 7558/572 kbit/s).
25.02.19 14:57:50 Timeout during PPP negotiation.
25.02.19 14:57:49 Internet connection cleared.
25.02.19 14:57:45 DSL not responding (no DSL synchronization).
25.02.19 01:39:27 Internet connection established successfully. IP address: 94., DNS server: 185. and 185., gateway: 185., broadband PoP: msr2.antcen.be
25.02.19 01:39:25 Internet connection cleared.
25.02.19 01:39:25 Clearing Internet connection briefly to prevent the Internet service provider from disconnecting you in the immediate future.
24.02.19 01:40:25 Internet connection established successfully. IP address: 94., DNS server: 185. and 185., gateway: 185., broadband PoP: msr2.antcen.be
24.02.19 01:40:24 Internet connection cleared.
24.02.19 01:40:23 Clearing Internet connection briefly to prevent the Internet service provider from disconnecting you in the immediate future.
18.02.19 21:21:13 DSL is available (DSL synchronization exists with 99998/29999 kbit/s).
