 *** SOLVED ***
  *** SOLVED ***
 Does your Mac Ethernet/Wireless keep giving you a fake 169.254.x.x ip address?
Recently I started running Mac OS X Leopard (10.5.
 on my spare computer. It worked fine for a few days until one day when I changed my router, my Mac stopped connecting to the router. It would repeatedly get a 169.254.x.x ip address through DHCP. If I set the IP address manually, it would show that it assigned the IP address, yet it would still not “properly” be connected in the background.
 on my spare computer. It worked fine for a few days until one day when I changed my router, my Mac stopped connecting to the router. It would repeatedly get a 169.254.x.x ip address through DHCP. If I set the IP address manually, it would show that it assigned the IP address, yet it would still not “properly” be connected in the background.So here is what I did to fix this problem. Open up Terminal using Spotlight. And type the command:
sudo ifconfig en0 ether 00:11:22:33:44:55
It will then ask you for your password. That’s it.
Explanation:
sudo: Gives you administrative power
ifconfig: the program that interacts with all your connectivity configurations
en0: the interface’s name, it could also be en1, en2, etc. (depending on the amount of network wired/wireless cards you have)
00:11:22:33:44:55: the mac address, pick whatever hex combination (i.e. only use characters 0-9 and a-z)
BEDANKT AAN IEDEREEN VOOR DE HULP!
Heb in ieder geval veel bijgeleerd.
WIE NIET OPGEEFT ZAL ZIJN DOEL BEREIKEN
____________________________________________
*ORIGINAL POST*
Ben hier al één maand mee aan het sukkelen...
 Ik heb een Seagate Business storage - 4 bay gekocht. http://www.seagate.com/external-hard-dr ... 4-bay-nas/
En ik zou deze aan kunnen sluiten door gebruik te maken van een switch op mijn router maar de ethernet kabel die ligt veel te ver
om tot aan mijn Mac te krijgen.
Dus nu is de vraag hoe kan ik deze rechtstreeks aan mijn mac koppelen?
UPDATE:
Ik weet nu dat dit valt op te lossen met een switch en een powerline adapter te kopen.
Maar toch wil ik gewoon van mijn Mac met gebruik van een cross kabel naar mijn Nas files kunnen overdragen en backupen.
Maar de vraag is Hoe en waarom werkt dit steeds niet...
ALVAST BEDANKT!!! HELP!!!
 heeft wel geen gigabit ethernet poort.
