Lancering Weepee TV
ubremoved_15739
Bedankt: 542 keer
De log is gewoon van vlc player, zonder tijdstip per lijn.
Maar in feite zou ik nu eigenlijk zorgeloos TV aan het kijken kunnen zijn. :wink:
Niet waar?
Afin, een laatste log in debug mode. Van iets voor de eerste error tot het moment dat vlc player er mee ophoud.
stream_filter_httplive info: Live Playlist HLS protocol version: 1
stream_filter_httplive info: updating hls stream (program-id=0, bandwidth=1503699) has 0 segments
stream_filter_httplive info: updating hls stream (program-id=0, bandwidth=0) has 5 segments
stream_filter_httplive info: - segment 10105 appended
main debug: creating access 'https' location='weepeetv.my-stream.eu/channel/8d39efee-220c-4f1d-bff1-918ef5831e4d/7acb6a6f-66df-445e-833e-cb6872dccd05/part-135653113400010105.ts', path='\\weepeetv.my-stream.eu\channel\8d39efee-220c-4f1d-bff1-918ef5831e4d\7acb6a6f-66df-445e-833e-cb6872dccd05\part-135653113400010105.ts'
main debug: looking for access module: 1 candidate
access_http debug: http: server='weepeetv.my-stream.eu' port=443 file='/channel/8d39efee-220c-4f1d-bff1-918ef5831e4d/7acb6a6f-66df-445e-833e-cb6872dccd05/part-135653113400010105.ts'
main debug: net: connecting to weepeetv.my-stream.eu port 443
main debug: connection succeeded (socket = 96848)
main debug: looking for tls client module: 1 candidate
gnutls debug: GnuTLS v2.12.20 initialized
main debug: using tls client module "gnutls"
main debug: TIMER module_need() : 24.643 ms - Total 24.643 ms / 1 intvls (Avg 24.643 ms)
gnutls debug: TLS/x509 certificate verified
main debug: TLS client session initialized
access_http debug: protocol 'HTTP' answer code 404
access_http error: error: HTTP/1.1 404 Not Found
gnutls debug: GnuTLS deinitialized
access_http debug: switching to HTTP version 1.0
main debug: TIMER module_need() : 36.417 ms - Total 36.417 ms / 1 intvls (Avg 36.417 ms)
main debug: no access module matching "https" could be loaded
main debug: TIMER module_need() : 944.164 ms - Total 944.164 ms / 1 intvls (Avg 944.164 ms)
main error: no suitable access module for `https://weepeetv.my-stream.eu/channel/8d39efee-220c-4f1d-bff1-918ef5831e4d/7acb6a6f-66df-445e-833e-cb6872dccd05/part-135653113400010105.ts'
stream_filter_httplive error: downloaded segment 10105 from stream 0 failed
main debug: connection succeeded (socket = 93248)
main debug: TIMER module_need() : 36.299 ms - Total 36.299 ms / 1 intvls (Avg 36.299 ms)
main debug: TIMER module_need() : 36.298 ms - Total 36.298 ms / 1 intvls (Avg 36.298 ms)
main debug: TIMER module_need() : 993.510 ms - Total 993.510 ms / 1 intvls (Avg 993.510 ms)
stream_filter_httplive info: Reloading HLS live meta playlist
main debug: creating access 'https' location='weepeetv.my-stream.eu/channel/8d39efee-220c-4f1d-bff1-918ef5831e4d/7acb6a6f-66df-445e-833e-cb6872dccd05/stream.m3u8', path='\\weepeetv.my-stream.eu\channel\8d39efee-220c-4f1d-bff1-918ef5831e4d\7acb6a6f-66df-445e-833e-cb6872dccd05\stream.m3u8'
access_http debug: http: server='weepeetv.my-stream.eu' port=443 file='/channel/8d39efee-220c-4f1d-bff1-918ef5831e4d/7acb6a6f-66df-445e-833e-cb6872dccd05/stream.m3u8'
main debug: TIMER module_need() : 24.498 ms - Total 24.498 ms / 1 intvls (Avg 24.498 ms)
access_http debug: protocol 'HTTP' answer code 200
access_http debug: Server: nginx/1.2.6
access_http debug: Content-Type: text/plain
access_http debug: Transfer-Encoding: chunked
access_http debug: Connection: close
main debug: using access module "access_http"
main debug: TIMER module_need() : 468.282 ms - Total 468.282 ms / 1 intvls (Avg 468.282 ms)
main debug: Using stream method for AStream*
main debug: starting pre-buffering
main debug: received first data after 0 ms
main debug: pre-buffering done 256 bytes in 0s - 4310 KiB/s
main debug: removing module "access_http"
stream_filter_httplive debug: parse_M3U8
#EXTM3U
#EXT-X-TARGETDURATION:10
#EXT-X-MEDIA-SEQUENCE:10101
#EXTINF:10,
part-135653113400010101.ts
#EXTINF:10,
part-135653113400010102.ts
#EXTINF:10,
part-135653113400010103.ts
#EXTINF:10,
part-135653113400010104.ts
#EXTINF:10,
stream_filter_httplive info: playing segment 10103 from stream 0
main debug: connection succeeded (socket = 92412)
main debug: TIMER module_need() : 24.362 ms - Total 24.362 ms / 1 intvls (Avg 24.362 ms)
main debug: TIMER module_need() : 455.537 ms - Total 455.537 ms / 1 intvls (Avg 455.537 ms)
main debug: pre-buffering done 256 bytes in 0s - 3906 KiB/s
#EXTM3U
#EXTINF:10,
#EXTINF:10,
#EXTINF:10,
#EXTINF:10,
#EXTINF:10,
main debug: TIMER module_need() : 24.582 ms - Total 24.582 ms / 1 intvls (Avg 24.582 ms)
main debug: TIMER module_need() : 449.659 ms - Total 449.659 ms / 1 intvls (Avg 449.659 ms)
#EXTM3U
#EXT-X-MEDIA-SEQUENCE:10102
#EXTINF:10,
#EXTINF:10,
#EXTINF:10,
#EXTINF:10,
#EXTINF:10,
part-135653113400010106.ts
stream_filter_httplive info: - segment 10106 appended
main debug: creating access 'https' location='weepeetv.my-stream.eu/channel/8d39efee-220c-4f1d-bff1-918ef5831e4d/7acb6a6f-66df-445e-833e-cb6872dccd05/part-135653113400010106.ts', path='\\weepeetv.my-stream.eu\channel\8d39efee-220c-4f1d-bff1-918ef5831e4d\7acb6a6f-66df-445e-833e-cb6872dccd05\part-135653113400010106.ts'
access_http debug: http: server='weepeetv.my-stream.eu' port=443 file='/channel/8d39efee-220c-4f1d-bff1-918ef5831e4d/7acb6a6f-66df-445e-833e-cb6872dccd05/part-135653113400010106.ts'
main debug: connection succeeded (socket = 96856)
main debug: TIMER module_need() : 24.686 ms - Total 24.686 ms / 1 intvls (Avg 24.686 ms)
access_http debug: protocol 'HTTP' answer code 206
access_http debug: Content-Type: text/plain; charset=UTF-8
access_http debug: this frame size=2561876
access_http debug: stream size=2561876,pos=0,remaining=2561876
main debug: TIMER module_need() : 396.782 ms - Total 396.782 ms / 1 intvls (Avg 396.782 ms)
main debug: pre-buffering done 1024 bytes in 0s - 35714 KiB/s
stream_filter_httplive info: downloaded segment 10106 from stream 0
main debug: connection succeeded (socket = 95184)
main debug: TIMER module_need() : 24.795 ms - Total 24.795 ms / 1 intvls (Avg 24.795 ms)
main debug: TIMER module_need() : 485.145 ms - Total 485.145 ms / 1 intvls (Avg 485.145 ms)
main debug: pre-buffering done 256 bytes in 0s - 4545 KiB/s
#EXTM3U
#EXTINF:10,
#EXTINF:10,
#EXTINF:10,
#EXTINF:10,
#EXTINF:10,
stream_filter_httplive info: playing segment 10104 from stream 0
main debug: TIMER module_need() : 24.307 ms - Total 24.307 ms / 1 intvls (Avg 24.307 ms)
main debug: TIMER module_need() : 455.395 ms - Total 455.395 ms / 1 intvls (Avg 455.395 ms)
main debug: pre-buffering done 256 bytes in 0s - 1250 KiB/s
#EXTM3U
#EXT-X-MEDIA-SEQUENCE:10103
#EXTINF:10,
#EXTINF:10,
#EXTINF:10,
#EXTINF:10,
#EXTINF:10,
part-135653113400010107.ts
stream_filter_httplive info: - segment 10107 appended
main debug: creating access 'https' location='weepeetv.my-stream.eu/channel/8d39efee-220c-4f1d-bff1-918ef5831e4d/7acb6a6f-66df-445e-833e-cb6872dccd05/part-135653113400010107.ts', path='\\weepeetv.my-stream.eu\channel\8d39efee-220c-4f1d-bff1-918ef5831e4d\7acb6a6f-66df-445e-833e-cb6872dccd05\part-135653113400010107.ts'
access_http debug: http: server='weepeetv.my-stream.eu' port=443 file='/channel/8d39efee-220c-4f1d-bff1-918ef5831e4d/7acb6a6f-66df-445e-833e-cb6872dccd05/part-135653113400010107.ts'
main debug: TIMER module_need() : 24.478 ms - Total 24.478 ms / 1 intvls (Avg 24.478 ms)
access_http debug: this frame size=1748964
access_http debug: stream size=1748964,pos=0,remaining=1748964
main debug: TIMER module_need() : 511.841 ms - Total 511.841 ms / 1 intvls (Avg 511.841 ms)
main debug: pre-buffering done 1024 bytes in 0s - 32258 KiB/s
stream_filter_httplive info: downloaded segment 10107 from stream 0
main debug: connection succeeded (socket = 92640)
main debug: TIMER module_need() : 24.741 ms - Total 24.741 ms / 1 intvls (Avg 24.741 ms)
main debug: TIMER module_need() : 475.529 ms - Total 475.529 ms / 1 intvls (Avg 475.529 ms)
main debug: pre-buffering done 256 bytes in 0s - 4716 KiB/s
#EXTM3U
#EXTINF:10,
#EXTINF:10,
#EXTINF:10,
#EXTINF:10,
#EXTINF:10,
ts debug: eof ?
main debug: EOF reached
main debug: waiting decoder fifos to empty
main debug: finished input
main debug: waitpipe: object killed
main debug: removing module "faad"
main debug: killing decoder fourcc `mp4a', 0 PES in FIFO
main debug: removing module "scaletempo"
main debug: removing module "samplerate"
main debug: removing module "aout_directx"
aout_directx debug: closing audio device
aout_directx debug: DirectSoundThread exiting
main debug: removing module "audio_format"
main debug: removing module "float32_mixer"
main debug: releasing audio output
main debug: removing module "packetizer_mpeg4audio"
main debug: removing module "avcodec"
avcodec debug: ffmpeg codec (H264 - MPEG-4 AVC (part 10)) stopped
main debug: killing decoder fourcc `h264', 0 PES in FIFO
main debug: saving a free vout
main debug: reusing provided vout
main debug: removing module "packetizer_h264"
main debug: removing module "ts"
ts debug: pid list:
ts debug:   - pid[0] seen
ts debug:   - pid[66] seen
ts debug:   - pid[68] seen
main debug: Program doesn't contain anymore ES
ts debug:   - pid[69] seen
ts debug:   - pid[8191] seen
main debug: removing module "stream_filter_record"
main debug: removing module "stream_filter_httplive"
main debug: dead input
main debug: changing item without a request (current 37/38)
main debug: nothing to play
main debug: destroying useless vout
main debug: removing module "direct3d"
direct3d debug: Direct3D scene released successfully
qt4 debug: IM: Deleting the input
direct3d debug: DirectXEventThread terminating
direct3d debug: DirectXCloseWindow
direct3d debug: WinProc WM_DESTROY
qt4 debug: releasing video...
qt4 debug: Video is not needed anymore
main debug: removing module "freetype"
main debug: removing module "yuvp"
main debug: removing module "swscale"
AnD
Uitgedeelde bedankjes: 393 keer
Bedankt: 87 keer
Toch knap dat de mensen van Userbase Weepee TV testen.
Ik vraag me af of ze (Weepee) dat niet gedaan hebben voordat ze het naar buiten brachten?
Uitgedeelde bedankjes: 1423 keer
Bedankt: 878 keer
Eén ding is zeker: er is toch al veel over gezegd :).
Bedankt: 343 keer
Er was al veel over gezegd nog voor iemand er echt iets van wist ;)
De hele avond geen buffering meer gehad op de computer, het is niet altijd zichtbaar, maar achter de schermen werken ze er toch aan :)
Tim.Bracquez
Bedankt: 451 keer
Klopt, hier nu ook geen buffering meer gezien op de lifetv stream! Super
ubremoved_15739
Bedankt: 542 keer
Er wordt momenteel ook mooier gestreamed: geen grote blokken van pakketten meer maar mooi regelmatig wat segmenten.
En de 404 error blijft precies achterwege nu. Afwachten of dit zo blijft uiteraard.
En afwachten wat het morgen in de "rode uren" geeft...
Edit:
Hmm. Iets te vroeg gedacht dat het opgelost was.
Daar is de 404 weer...
Het had wel lang geduurd eer hij er was dit keer.
stream_filter_httplive info: updating hls stream (program-id=0, bandwidth=1162892) has 0 segments
stream_filter_httplive info: - segment 11580 appended
main error: no suitable access module for `https://weepeetv.my-stream.eu/channel/8d39efee-220c-4f1d-bff1-918ef5831e4d/7acb6a6f-66df-445e-833e-cb6872dccd05/part-135653113400011580.ts'
stream_filter_httplive error: downloaded segment 11580 from stream 0 failed
stream_filter_httplive info: playing segment 11579 from stream 0
stream_filter_httplive info: - segment 11581 appended
stream_filter_httplive info: downloaded segment 11581 from stream 0
TiTanium
Uitgedeelde bedankjes: 710 keer
Bedankt: 469 keer
Vandaag in VLC een uitzending gepauzeerd en na het eten kon ik perfect verder kijken. Niet enkele minuten, maar effectief de rest van het programma.
PS: Ik kijk liever via VLC dan via de site.
PC: PRIME Asus X299 Deluxe ~ i7 7820X ~ 32GB DDR4 ~ 1080Ti Strix ~ M.2 EVO 960 500GB
NUC: NUC8i3BEH2 ~ 8GB DDR4 ~ M.2 SX6000 Pro 256GB
Monitor: Asus 27" ROG Strix XG27WQ
Provider: Telenet
OneUP ~ TVbox ~ HGW CH8568LG
Unifi: Dream Machine Switch: 2x 8 POE-60W ~ 2x Flex Mini AP's: Flex-HD ~ Mesh
Smartphone: Samsung S21 Ultra 512GB[/size]
fryelectro
Uitgedeelde bedankjes: 314 keer
Bedankt: 143 keer
das wel een coole feature, maar wil dat dan zeggen dat wptv voor elke kijker de stream *oneindig* buffert indien deze laatste de stream pauzeert??
Edpnet VDSL XL - 100/30 Fritz!Box 7530
Orange go plus
TiTanium
Bedankt: 469 keer
Ik heb het ook eens getest met de site zelf en daar kan ik blijkbaar ook gewoon pauzeren voor een geruime tijd.
Als 2é nog wat gefoefeld met android:
Nu in gang gekregen bij android tablet maar heb ik iets anders voor :(
4:3 beeld
En bij de SGS II crasht het na +/- 30sec :(
Provider: Telenet
Robert Ford
Uitgedeelde bedankjes: 110 keer
Bedankt: 102 keer
Ja idd, die 4:3 resolutie had ik ook al opgemerkt.
Kan je fullscreen afspelen op een android tablet?
TiTanium
Bedankt: 469 keer
Het beeld dat u ziet in de afbeelding is full screen. Maar spijtig genoeg 4:3.
Provider: Telenet
Abusimbal
Uitgedeelde bedankjes: 194 keer
Bedankt: 85 keer
Kan de beeldverhouding niet via de opties van je videospeler in Android aanpassen ?
Samsung Galaxy S22 Ultra
Ubiquiti UDM Pro
Synology DS3615xs
Nvidia Shield TV console
Dell Latitude 5480
Microsoft Surface Pro 4
Garmin VivoSmart HR (activity tracker)
TiTanium
Bedankt: 469 keer
Geen van men androidplayers wil starten op het moment, dit is via de asus/android browser zelf. Als je eerst uw beeld vergroot (zonder video te starten) kan je op full screen je video starten en zien ;)
Als je eerst de video start kan je NIET naar full screen, alé hier toch ;)
Provider: Telenet
Kenw00t
Uitgedeelde bedankjes: 346 keer
Bedankt: 250 keer
Ik kreeg dit ook werkend met VLC, maar niet op alle laptops en PC's. Wat me opviel is dat VLC 2.0.5 meestal direct crashed, en VLC 2.0.4 de stream wel weergeeft. Kan iemand dit bevestigen?
Andere opmerkingen:
Ik hoop dat de security van de WeePeeTV-website waterdicht is. Daarmee bedoel ik enerzijds de wachtwoorden die plaintext via mail verstuurd worden. Ik hoop dat ze zo ook niet in de database staan.
Ten tweede lijkt het erop dat jullie zelf snel snel de betaling via credit card in de site ingebouwd hebben door er 2 simpele invoervelden in te zetten en te vragen naar de security code op de achterkant van de kaart. Waarom loopt dit niet via Ogone, DirectEbanking of PayPal? Vooral op dit vlak had ik een wrang gevoel dat dit niet volgens het boekje verloopt. Wees ervan bewust dat als dit soort details gelekt worden, het wel eens heel snel gedaan zou kunnen zijn met het imago...
Razornord
Bedankt: 17 keer
Ik kwam zonet een onofficiële applicatie tegen via Twitter om WeepeeTv te kijken op Android. Het blijkt niet noodzakelijk om de meest recente versie te hebben van Android maar hardwarematige decoding blijkt toch aangewezen.
glenner05
Bedankt: 4 keer
Voor degenen met het 4:3 probleem, zo heb ik het deftig werkend op mijn galaxy note 2 en asus transformer tablet. Ik heb op beide toestellen flash player geïnstalleerd (de laatste nieuwe versie) en de stock browser zo ingesteld dat hij de desktopversie van internetpaginas moet weergeven. Zo laadt hij de videostream van weepee via de flashplayer en is mijn beeldverhouding perfect schermvullend zowel op tablet als smartphone (je kan de video fullscreen maken door te dubbeltappen op het beeld). Zonder uitgerekte verhoudingn. Vooral mijn tablet had last van uitgerokken beelden alshij streamde via de html player...
Ik ben het nu al enige tijd aan het testen en vind de kwaliteit van weepee alvast veel beter dan yelo tv. Het enige waar ik soms last van heb is dat de audio niet altijd synchroon loopt met het beeld. Oh ja, en de prijs natuurlijk. Moest het maar 5 euro zijn dan kocht ik direct een jaar abbo. Maar 10 euro per maand voor iets dat ik vooral op mijn tablet zou gebruiken vind ik gewoon teveel. Dus na deze testmaand zal het voorlopig genoeg zijn voor mij vrees ik...
TiTanium
Bedankt: 469 keer
Kenw00t schreef:Wat me opviel is dat VLC 2.0.5 meestal direct crashed
Werkt hier perfect op windows 8. Als ik kook dan sta men laptop aan de andere kant van het aanrecht en kan ik rustig naar tv kijken tijdens het koken. Ik speel dit af op VLC 2.0.5.
Razornord schreef:Ik kwam zonet een onofficiële applicatie tegen via Twitter om WeepeeTv te kijken op Android.
Mx player speelt het hier inderaad goed af op android ;) Raar vorige keer kreeg ik die met MX-player niet gestart.
Provider: Telenet
redman
Bedankt: 88 keer
Razornord schreef:Ik kwam zonet een onofficiële applicatie tegen via Twitter om WeepeeTv te kijken op Android. Het blijkt niet noodzakelijk om de meest recente versie te hebben van Android maar hardwarematige decoding blijkt toch aangewezen.
De applicatie WPTVdroid werkt echt goed, nu werkt weepee tv ook op mijn SG 2
42wim
Bedankt: 18 keer
Voor degene die interesse hebben, mijn onofficiële wptvdroid beta app is beschikbaar op https://docs.google.com/open?id=0B3MOGC ... UQyWWpqX1E (werkt tot 14/1)
Source komt op korte termijn ook beschikbaar.
https://github.com/42wim/wptvscraper is misschien ook wel interessant voor sommigen.
42wim
Bedankt: 18 keer
Vreemd, want bij mij werkt mxplayer niet met de https urls (vandaar dat ik stunnel heb moeten gebruiken)
TiTanium
Bedankt: 469 keer
Op men SGS II start hij met de MX-player, ik ga nu is testen op men tablet.
EDIT: Op mijn tablet weigert hij te starten.
Provider: Telenet
ubremoved_15739
Bedankt: 542 keer
Bij mij werkt een https url (m3u8 stream) in mxplayer wel.
Misschien ligt dit aan onderstaande geactiveerde optie?
TiTanium
Bedankt: 469 keer
Helpt niet, ik heb de instellingen vergeleken tussen de asus tablet en de sgs2. De instellingen zijn dezelfde en toch speelt de SGS II dit af en de tablet niet. SGS II heeft 4.0.4 en men tablet heeft 4.1.1.
Provider: Telenet
ubremoved_15739
Bedankt: 542 keer
@ TiTanium
Probeer eens de app van 42wim.
Bij deze app gebruikt mxplayer een "http://localhost:4444/....." url.
42wim schreef:Voor degene die interesse hebben, mijn onofficiële wptvdroid beta app is beschikbaar op https://docs.google.com/open?id=0B3MOGC ... UQyWWpqX1E (werkt tot 14/1)
Werkt hier perfect. Eenvoudig en efficiënt. :thumbs:
Automatisch inloggen, vlot wisselen tussen de zenders én de al mogelijkheden van mxplayer.
Meer moet dat niet zijn. :wink:
TiTanium
Bedankt: 469 keer
De app werkt bij mij niet, maar ik vermoed dat ik wat meer moet installeren of instellen. Ik zal het straks of zo moeten bezien met men wacht heb ik niet altijd tijd :-)
Provider: Telenet
criminala
Bedankt: 10 keer
Voor welke apparaten zijn er eigenlijk streaming clients in ontwikkeling ?
Playstation 3 zou prachtig zijn , alsook een Samsung tv client .
Bedankt: 343 keer
Xbox zou ook goed zijn :p maar zal niet gebeuren.
Voor ps3, zou het lukken met de ps3mediaserver software om deze te streamen naar de PS3? Of zou de ps3 niet gewoon M3U8 ondersteunen? Xbox alleszins niet, PS3 nog niet getest.
fryelectro
Bedankt: 143 keer
werkt het nu al (inofficieel) deftig op xbmc? Ik zou dat graag eens willen testen.
Orange go plus
bambipower
Uitgedeelde bedankjes: 526 keer
Bedankt: 248 keer
WPTVdroid werkt bij mij perfect op mijn android stick (gk802) en ook op mijn acer a500 tablet
proper werk (heb me ineens ook een abbo op weepeetv genomen)
de koe zegt boe
Ofloo
Bedankt: 92 keer
Weet iemand per toeval hoe je otttv naar dlna omzet ik had verstaan met xupnpd maar heeft iemand dit al getest?
[Mod Edit] Samengevoegd met bestaande topic. Geen reden om voor deze vraag een nieuwe topic te openen.
carlito
Uitgedeelde bedankjes: 4 keer
fryelectro schreef:werkt het nu al (inofficieel) deftig op xbmc? Ik zou dat graag eens willen testen.
nee, ze weigeren blijkbaar ook om te reageren op xbmc vragen. Spijtig, anders nam ik meteen een jaar abbonement. Nu zal het afgelopen zijn na een maand :(
Het zag er anders wel veelbelovend uit...
Bedankt: 1985 keer
Het sterk punt... OTT lijkt trouwens ook niet echt zo schitterend te zijn. Als tweaker wil je misschien nog alle moeite doen om iets werkende te krijgen, maar voor de gemiddelde consument moet dit gewoon vanaf dag één werken.
carlito
ja momenteel ligt het product een beetje tussen tweaker en consumer. Niemand is er echt happig over momenteel...
42wim
Bedankt: 18 keer
Idem hier, krijg ook geen feedback van hun omtrent mijn android app.
Spijtig dat ze geen rekening houden met developers.
TiTanium
Bedankt: 469 keer
Het feit dat er weinig support/feedback is gaat hun klanten kosten. Misschien hadden ze in de stadium waar hun product nu bevindt niet mogen uitbrengen en geen beloftes mogen maken. Zoals het er nu naar uitzie ga ik waarschijnlijk niet verlengen.
  • Geen apps voorhanden (uitgezonderd van 42win)
  • Prijs voor wat het nu is, ligt te hoog (zouden de mensen een maand cadeau mogen doen voor de last/frustratie :()
  • Alle vlaamse zenders zijn niet voorhanden (Vier/Vijf)
  • Geen mogelijkheid om wachtwoord te veranderen
  • betalingsmogelijkheden en zoals eerder aangegeven waarom niet via ogone of dergelijke.
Provider: Telenet
carlito
Ja de beste kans die we hebben om al deze zaken aan te kaarten is om ze via hun facebook profiel aan te spreken...
fryelectro
Bedankt: 143 keer
Optimistisch wordt je er idd wel niet van. Hopelijk komen ze nog snel met wat positief nieuws. De tekortkomingen zijn hier al meerdere malen aangekaart geweest. Het is volledig aan hen.
Orange go plus
Bedankt: 343 keer
TiTanium schreef:Het feit dat er weinig support/feedback is gaat hun klanten kosten. Misschien hadden ze in de stadium waar hun product nu bevindt niet mogen uitbrengen en geen beloftes mogen maken. Zoals het er nu naar uitzie ga ik waarschijnlijk niet verlengen.
Jep, na enkele dagen fier een nieuwe zender aankondigen en dat was het dan. Inmiddels terug last van haperingen op de computer. Die vlaamse zenders kunnen me weinig schelen, maar de prijs en het feit dat er geen apps zijn (en dan vooral voor XBMC wil ik eentje) is maar flauw. Na deze maand geen verlenging tot er verbetering is.
Het is zelfs nodig een externe tv-gids te raadplegen om te weten naar welk programma je kijkt.
meon
Twitter: meon
Bedankt: 759 keer
Hier nog een blije gebruiker van 42wim's apk'tje :)
Samsung Galaxy S met Android 4.1.2, werkt vlotjes via MX Player :)
En inderdaad: sommige kleine dingen zouden de gebruikerservaring zoveel kunnen verbeteren... Een change password implementeren kan toch geen maand op zich laten wachten? :-/
fryelectro
Bedankt: 143 keer
carlito schreef:nee, ze weigeren blijkbaar ook om te reageren op xbmc vragen. Spijtig, anders nam ik meteen een jaar abbonement. Nu zal het afgelopen zijn na een maand :(
Sinds de nieuwe xbmc frodo release candidate kan ik dus wel de lifetv stream zien. Dit werkt zeer goed, enkel de kwaliteit is wel ondermaats op m'n flatscreen, maar verder wel totaal geen onderbrekingen gehad. Nu zou ik wel eens willen experimenteren met de betalende weepeetv kanalen maar er is precies niemand die me wil of kan vertellen hoe je die kanalen dan moet zichtbaar maken op xbmc. Je hebt maw ook een app nodig die aangepast is voor weepeetv of een dedicated weepeetv app op xbmc. Dat laatste zal er wellicht nooit komen via weepee maar voor de launch was er wel reeds iemand die hiermee bezig was en beloofde om deze te opensourcen na de launch.
ik heb de beruchte post teruggevonden:
https://www.facebook.com/WeePeeTV/posts/433599620029186
(453.55 KiB) 11 keer gedownload
Misschien interessant om deze persoon eens vriendelijk te vragen of hij iets werkend heeft ondertussen?
edit: btw zoals je kan zien was toen de officiële reactie van weepee wel dat ze er "voor open staan"...
Orange go plus
