Maar in feite zou ik nu eigenlijk zorgeloos TV aan het kijken kunnen zijn.
Niet waar?
Afin, een laatste log in debug mode. Van iets voor de eerste error tot het moment dat vlc player er mee ophoud.
stream_filter_httplive info: Live Playlist HLS protocol version: 1
stream_filter_httplive info: updating hls stream (program-id=0, bandwidth=1503699) has 0 segments
stream_filter_httplive info: updating hls stream (program-id=0, bandwidth=0) has 5 segments
stream_filter_httplive info: - segment 10105 appended
main debug: creating access 'https' location='weepeetv.my-stream.eu/channel/8d39efee-220c-4f1d-bff1-918ef5831e4d/7acb6a6f-66df-445e-833e-cb6872dccd05/part-135653113400010105.ts', path='\\weepeetv.my-stream.eu\channel\8d39efee-220c-4f1d-bff1-918ef5831e4d\7acb6a6f-66df-445e-833e-cb6872dccd05\part-135653113400010105.ts'
main debug: looking for access module: 1 candidate
access_http debug: http: server='weepeetv.my-stream.eu' port=443 file='/channel/8d39efee-220c-4f1d-bff1-918ef5831e4d/7acb6a6f-66df-445e-833e-cb6872dccd05/part-135653113400010105.ts'
main debug: net: connecting to weepeetv.my-stream.eu port 443
main debug: connection succeeded (socket = 96848)
main debug: looking for tls client module: 1 candidate
gnutls debug: GnuTLS v2.12.20 initialized
main debug: using tls client module "gnutls"
main debug: TIMER module_need() : 24.643 ms - Total 24.643 ms / 1 intvls (Avg 24.643 ms)
gnutls debug: TLS/x509 certificate verified
main debug: TLS client session initialized
access_http debug: protocol 'HTTP' answer code 404
access_http error: error: HTTP/1.1 404 Not Found
gnutls debug: GnuTLS deinitialized
access_http debug: switching to HTTP version 1.0
main debug: TIMER module_need() : 36.417 ms - Total 36.417 ms / 1 intvls (Avg 36.417 ms)
main debug: no access module matching "https" could be loaded
main debug: TIMER module_need() : 944.164 ms - Total 944.164 ms / 1 intvls (Avg 944.164 ms)
main error: no suitable access module for `https://weepeetv.my-stream.eu/channel/8d39efee-220c-4f1d-bff1-918ef5831e4d/7acb6a6f-66df-445e-833e-cb6872dccd05/part-135653113400010105.ts'
stream_filter_httplive error: downloaded segment 10105 from stream 0 failed
main debug: connection succeeded (socket = 93248)
main debug: TIMER module_need() : 36.299 ms - Total 36.299 ms / 1 intvls (Avg 36.299 ms)
main debug: TIMER module_need() : 36.298 ms - Total 36.298 ms / 1 intvls (Avg 36.298 ms)
main debug: TIMER module_need() : 993.510 ms - Total 993.510 ms / 1 intvls (Avg 993.510 ms)
stream_filter_httplive info: Reloading HLS live meta playlist
main debug: creating access 'https' location='weepeetv.my-stream.eu/channel/8d39efee-220c-4f1d-bff1-918ef5831e4d/7acb6a6f-66df-445e-833e-cb6872dccd05/stream.m3u8', path='\\weepeetv.my-stream.eu\channel\8d39efee-220c-4f1d-bff1-918ef5831e4d\7acb6a6f-66df-445e-833e-cb6872dccd05\stream.m3u8'
access_http debug: http: server='weepeetv.my-stream.eu' port=443 file='/channel/8d39efee-220c-4f1d-bff1-918ef5831e4d/7acb6a6f-66df-445e-833e-cb6872dccd05/stream.m3u8'
main debug: TIMER module_need() : 24.498 ms - Total 24.498 ms / 1 intvls (Avg 24.498 ms)
access_http debug: protocol 'HTTP' answer code 200
access_http debug: Server: nginx/1.2.6
access_http debug: Content-Type: text/plain
access_http debug: Transfer-Encoding: chunked
access_http debug: Connection: close
main debug: using access module "access_http"
main debug: TIMER module_need() : 468.282 ms - Total 468.282 ms / 1 intvls (Avg 468.282 ms)
main debug: Using stream method for AStream*
main debug: starting pre-buffering
main debug: received first data after 0 ms
main debug: pre-buffering done 256 bytes in 0s - 4310 KiB/s
main debug: removing module "access_http"
stream_filter_httplive debug: parse_M3U8
#EXTM3U
#EXT-X-TARGETDURATION:10
#EXT-X-MEDIA-SEQUENCE:10101
#EXTINF:10,
part-135653113400010101.ts
#EXTINF:10,
part-135653113400010102.ts
#EXTINF:10,
part-135653113400010103.ts
#EXTINF:10,
part-135653113400010104.ts
#EXTINF:10,
stream_filter_httplive info: playing segment 10103 from stream 0
main debug: connection succeeded (socket = 92412)
main debug: TIMER module_need() : 24.362 ms - Total 24.362 ms / 1 intvls (Avg 24.362 ms)
main debug: TIMER module_need() : 455.537 ms - Total 455.537 ms / 1 intvls (Avg 455.537 ms)
main debug: pre-buffering done 256 bytes in 0s - 3906 KiB/s
#EXTM3U
#EXTINF:10,
#EXTINF:10,
#EXTINF:10,
#EXTINF:10,
#EXTINF:10,
main debug: TIMER module_need() : 24.582 ms - Total 24.582 ms / 1 intvls (Avg 24.582 ms)
main debug: TIMER module_need() : 449.659 ms - Total 449.659 ms / 1 intvls (Avg 449.659 ms)
#EXTM3U
#EXT-X-MEDIA-SEQUENCE:10102
#EXTINF:10,
#EXTINF:10,
#EXTINF:10,
#EXTINF:10,
#EXTINF:10,
part-135653113400010106.ts
stream_filter_httplive info: - segment 10106 appended
main debug: creating access 'https' location='weepeetv.my-stream.eu/channel/8d39efee-220c-4f1d-bff1-918ef5831e4d/7acb6a6f-66df-445e-833e-cb6872dccd05/part-135653113400010106.ts', path='\\weepeetv.my-stream.eu\channel\8d39efee-220c-4f1d-bff1-918ef5831e4d\7acb6a6f-66df-445e-833e-cb6872dccd05\part-135653113400010106.ts'
access_http debug: http: server='weepeetv.my-stream.eu' port=443 file='/channel/8d39efee-220c-4f1d-bff1-918ef5831e4d/7acb6a6f-66df-445e-833e-cb6872dccd05/part-135653113400010106.ts'
main debug: connection succeeded (socket = 96856)
main debug: TIMER module_need() : 24.686 ms - Total 24.686 ms / 1 intvls (Avg 24.686 ms)
access_http debug: protocol 'HTTP' answer code 206
access_http debug: Content-Type: text/plain; charset=UTF-8
access_http debug: this frame size=2561876
access_http debug: stream size=2561876,pos=0,remaining=2561876
main debug: TIMER module_need() : 396.782 ms - Total 396.782 ms / 1 intvls (Avg 396.782 ms)
main debug: pre-buffering done 1024 bytes in 0s - 35714 KiB/s
stream_filter_httplive info: downloaded segment 10106 from stream 0
main debug: connection succeeded (socket = 95184)
main debug: TIMER module_need() : 24.795 ms - Total 24.795 ms / 1 intvls (Avg 24.795 ms)
main debug: TIMER module_need() : 485.145 ms - Total 485.145 ms / 1 intvls (Avg 485.145 ms)
main debug: pre-buffering done 256 bytes in 0s - 4545 KiB/s
#EXTM3U
#EXTINF:10,
#EXTINF:10,
#EXTINF:10,
#EXTINF:10,
#EXTINF:10,
stream_filter_httplive info: playing segment 10104 from stream 0
main debug: TIMER module_need() : 24.307 ms - Total 24.307 ms / 1 intvls (Avg 24.307 ms)
main debug: TIMER module_need() : 455.395 ms - Total 455.395 ms / 1 intvls (Avg 455.395 ms)
main debug: pre-buffering done 256 bytes in 0s - 1250 KiB/s
#EXTM3U
#EXT-X-MEDIA-SEQUENCE:10103
#EXTINF:10,
#EXTINF:10,
#EXTINF:10,
#EXTINF:10,
#EXTINF:10,
part-135653113400010107.ts
stream_filter_httplive info: - segment 10107 appended
main debug: creating access 'https' location='weepeetv.my-stream.eu/channel/8d39efee-220c-4f1d-bff1-918ef5831e4d/7acb6a6f-66df-445e-833e-cb6872dccd05/part-135653113400010107.ts', path='\\weepeetv.my-stream.eu\channel\8d39efee-220c-4f1d-bff1-918ef5831e4d\7acb6a6f-66df-445e-833e-cb6872dccd05\part-135653113400010107.ts'
access_http debug: http: server='weepeetv.my-stream.eu' port=443 file='/channel/8d39efee-220c-4f1d-bff1-918ef5831e4d/7acb6a6f-66df-445e-833e-cb6872dccd05/part-135653113400010107.ts'
main debug: TIMER module_need() : 24.478 ms - Total 24.478 ms / 1 intvls (Avg 24.478 ms)
access_http debug: this frame size=1748964
access_http debug: stream size=1748964,pos=0,remaining=1748964
main debug: TIMER module_need() : 511.841 ms - Total 511.841 ms / 1 intvls (Avg 511.841 ms)
main debug: pre-buffering done 1024 bytes in 0s - 32258 KiB/s
stream_filter_httplive info: downloaded segment 10107 from stream 0
main debug: connection succeeded (socket = 92640)
main debug: TIMER module_need() : 24.741 ms - Total 24.741 ms / 1 intvls (Avg 24.741 ms)
main debug: TIMER module_need() : 475.529 ms - Total 475.529 ms / 1 intvls (Avg 475.529 ms)
main debug: pre-buffering done 256 bytes in 0s - 4716 KiB/s
#EXTM3U
#EXTINF:10,
#EXTINF:10,
#EXTINF:10,
#EXTINF:10,
#EXTINF:10,
ts debug: eof ?
main debug: EOF reached
main debug: waiting decoder fifos to empty
main debug: finished input
main debug: waitpipe: object killed
main debug: removing module "faad"
main debug: killing decoder fourcc `mp4a', 0 PES in FIFO
main debug: removing module "scaletempo"
main debug: removing module "samplerate"
main debug: removing module "aout_directx"
aout_directx debug: closing audio device
aout_directx debug: DirectSoundThread exiting
main debug: removing module "audio_format"
main debug: removing module "float32_mixer"
main debug: releasing audio output
main debug: removing module "packetizer_mpeg4audio"
main debug: removing module "avcodec"
avcodec debug: ffmpeg codec (H264 - MPEG-4 AVC (part 10)) stopped
main debug: killing decoder fourcc `h264', 0 PES in FIFO
main debug: saving a free vout
main debug: reusing provided vout
main debug: removing module "packetizer_h264"
main debug: removing module "ts"
ts debug: pid list:
ts debug: - pid[0] seen
ts debug: - pid[66] seen
ts debug: - pid[68] seen
main debug: Program doesn't contain anymore ES
ts debug: - pid[69] seen
ts debug: - pid[8191] seen
main debug: removing module "stream_filter_record"
main debug: removing module "stream_filter_httplive"
main debug: dead input
main debug: changing item without a request (current 37/38)
main debug: nothing to play
main debug: destroying useless vout
main debug: removing module "direct3d"
direct3d debug: Direct3D scene released successfully
qt4 debug: IM: Deleting the input
direct3d debug: DirectXEventThread terminating
direct3d debug: DirectXCloseWindow
direct3d debug: WinProc WM_DESTROY
qt4 debug: releasing video...
qt4 debug: Video is not needed anymore
main debug: removing module "freetype"
main debug: removing module "yuvp"
main debug: removing module "swscale"
