VIA EPIA SN18000G en 3988 Mini-ITX Case, mag weg voor zo n 170eur
hmm, nu ik details opzocht zie ik dat er toch een fan inzit, dus beetje offtopic misschien, sorry daarvoor. Maar k had de fan nooit gehoord, vandaar de verwarring
VIA EPIA SN-Series Mini-ITX Mainboard Specifications
Model Name
• VIA EPIA SN18000G
Processor
• VIA C7 1.8GHz NanoBGA2 Processor
Chipset
• VIA CN896 North Bridge
• VIA VT8251 South Bridge
System Memory
• 2 DDR2 400/533/667 DIMM sockets
• Up to 4GB Memory Support
• Integrated VIA Chrome9™HC Integrated Graphics with 2D/3D and Video acceleration
Expansion Slots
• 1 16-Lane PCI-E slot
• 1 32-Bit miniPCI slot
Onboard IDE
• 1 UltraDMA 133/100/66 connector 1 UltraDMA 133/100/66 connector
Onboard LAN
• 1 VIA VT6103L 10/100Mbps Ethernet PHY
• 1 VIA VT6130 PCI-E Gigabit Ethernet Controller
Onboard Audio
• VIA VT1708A High Defination Audio Codec
Onboard TPM
• Infineon SLB9635TT 1.2 (Trusted Platform Module)
Onboard I/O Connectors
• 4 SATA II connectors
• 2 Fan pin connectors: CPU/Sys FAN
• 1 USB pin connectors for 2 additional USB 2.0 ports
• 1 LVDS/DVI module connectors(an add-on card is required)
• 1 CF(compact Flash) type I connector(share with IDE1)
• 1 serial port pin connector for COM2 ( 5V/12V selectable)
• 1 LPC header
• 1 CIR pin connector(switchable for KB/MS)
• 1 SIR pin connector (IRDA 1.0)
• 1 SMBUS connector
• 1 Digital I/O pin connector
• 1 S/PDIF out pin connector
• 1 Front-panel pin connector
• 1 Front-panel audio pin connectors(MIC and Line-out)
• ATX power connector
Back Panel I/O
• 1 PS2 mouse port
• 1 PS2 keyboard port
• 1 Serial port
• 1 VGA port
• 2 RJ-45 LAN connector
• 4 USB 2.0 ports
• 3 Audio jacks for MIC-In, Line-In & Line-Out (Horizontal, Smart 5.1 Support)
BIOS
• AMI BIOS
• LPC 4/8Mbit flash memory
Operating System
• Windows 2000/XP, Linux, Win CE, XPe
System Monitoring & Management
• Fan control
• CPU voltage monitoring
• AC power failure recovery
• System power management
• Wake-on-LAN, Keyboard-power-on, Timer-Power-on,
• Watch-Dog Timer,
Operating Temperature 0°C ~ 50°C
Operating Humidity 0% ~ 95% (relative humidity; non-condensing)
Form Factor
• Mini-ITX( 6 layers)
• 17cm x 17cm
Drive bays: 1x 3.5"/2.5" HDD bay, slim-optical bay
Power supply: 90W DC-DC board, 80W AC/DC adapter
Including P4 cable
LED indicators: Power and HDD activity
Switches: Power and reset
Expansion slots: 1x PCI32 through a riser card
Front connections**: USB2.0 x2, audio, FireWire (IEEE1394)
Materials: SECC body, ABS and aluminum front panel
Cooling: 80mm fan
Dimensions (WxDxH): 202 x 97 x 273mm
Accessory included: assembly kit, 2.5" HDD cable, slim-optical converter, compact ATA cable, stand for vertical use.
