hi,
Deze morgen met Scarlet TD gebeld.. Ze gingen dat onderzoeken schijnt..
Ondertussen zit ik altijd met hoge pingen & lage snelheid.. al 4 dagen..(had al de zaterdag gebeld eig.)
Mijn laaste pingen naar google :
Pinging
http://www.l.google.com [74.125.77.99] with 32 bytes of data:
Reply from 74.125.77.99: bytes=32 time=40ms TTL=244
Reply from 74.125.77.99: bytes=32 time=114ms TTL=244
Reply from 74.125.77.99: bytes=32 time=107ms TTL=244
Reply from 74.125.77.99: bytes=32 time=116ms TTL=244
Reply from 74.125.77.99: bytes=32 time=36ms TTL=244
Reply from 74.125.77.99: bytes=32 time=127ms TTL=244
Reply from 74.125.77.99: bytes=32 time=30ms TTL=244
Reply from 74.125.77.99: bytes=32 time=82ms TTL=244
Reply from 74.125.77.99: bytes=32 time=89ms TTL=244
Reply from 74.125.77.99: bytes=32 time=93ms TTL=244
Reply from 74.125.77.99: bytes=32 time=37ms TTL=244
Reply from 74.125.77.99: bytes=32 time=100ms TTL=244
Reply from 74.125.77.99: bytes=32 time=50ms TTL=244
Reply from 74.125.77.99: bytes=32 time=115ms TTL=244
Reply from 74.125.77.99: bytes=32 time=35ms TTL=244
Reply from 74.125.77.99: bytes=32 time=81ms TTL=244
Reply from 74.125.77.99: bytes=32 time=85ms TTL=244
Reply from 74.125.77.99: bytes=32 time=34ms TTL=244
Request timed out.
Reply from 74.125.77.99: bytes=32 time=84ms TTL=244
Request timed out.
Reply from 74.125.77.99: bytes=32 time=94ms TTL=244
Reply from 74.125.77.99: bytes=32 time=31ms TTL=244
Reply from 74.125.77.99: bytes=32 time=72ms TTL=244
Reply from 74.125.77.99: bytes=32 time=91ms TTL=244
Reply from 74.125.77.99: bytes=32 time=103ms TTL=244
Reply from 74.125.77.99: bytes=32 time=69ms TTL=244
Ping statistics for 74.125.77.99:
Packets: Sent = 31, Received = 29, Lost = 2 (6% loss),
Approximate round trip times in milli-seconds:
Minimum = 30ms, Maximum = 127ms, Average = 77ms
Nu
http://www.scarlet.bePinging
http://www.scarlet.be [193.74.71.30] with 32 bytes of data:
Reply from 193.74.71.30: bytes=32 time=44ms TTL=249
Reply from 193.74.71.30: bytes=32 time=92ms TTL=249
Reply from 193.74.71.30: bytes=32 time=97ms TTL=249
Reply from 193.74.71.30: bytes=32 time=100ms TTL=249
Reply from 193.74.71.30: bytes=32 time=22ms TTL=249
Reply from 193.74.71.30: bytes=32 time=68ms TTL=249
Reply from 193.74.71.30: bytes=32 time=65ms TTL=249
Reply from 193.74.71.30: bytes=32 time=110ms TTL=249
Reply from 193.74.71.30: bytes=32 time=35ms TTL=249
Request timed out.
Reply from 193.74.71.30: bytes=32 time=64ms TTL=249
Reply from 193.74.71.30: bytes=32 time=82ms TTL=249
Reply from 193.74.71.30: bytes=32 time=99ms TTL=249
Reply from 193.74.71.30: bytes=32 time=106ms TTL=249
Reply from 193.74.71.30: bytes=32 time=73ms TTL=249
Reply from 193.74.71.30: bytes=32 time=117ms TTL=249
Reply from 193.74.71.30: bytes=32 time=48ms TTL=249
Reply from 193.74.71.30: bytes=32 time=80ms TTL=249
Request timed out.
Request timed out.
Request timed out.
Reply from 193.74.71.30: bytes=32 time=83ms TTL=249
Reply from 193.74.71.30: bytes=32 time=124ms TTL=249
![Afbeelding](http://www.speedtest.net/result/476261283.png)
![Afbeelding](http://www.speedtest.net/result/476262476.png)
nog straffer.. mijn download vanuit amsterdam is beter !
![Afbeelding](http://www.speedtest.net/result/476263321.png)
mis nog een trace route ..
Tracing route to
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms [192.168.1.1]
2 20 ms 20 ms 22 ms ip-81-x-x-x.dsl.scarlet.be [81.x.x.x]
3 84 ms 97 ms 109 ms atm6-0-0-100.ndl-pe01.mpl.scarlet.be [195.95.30.53]
4 115 ms 101 ms 113 ms gig5-0-0-205.vil-pe08.mpl.scarlet.be [193.74.71.252]
5 36 ms 28 ms 31 ms
Trace complete.
en nu
http://www.google.beTracing route to
http://www.l.google.com [74.125.79.104]
2 15 ms 17 ms 16 ms ip-81-x-x-x.dsl.scarlet.be [81.x.x.x]
3 68 ms 71 ms 64 ms atm6-0-0-100.ndl-pe01.mpl.scarlet.be [195.95.30.53]
4 56 ms 58 ms 47 ms 194.119.228.145
5 126 ms 96 ms 83 ms so-0-0-0.bru21.ip.tiscali.net [77.67.66.157]
6 81 ms 119 ms 87 ms xe-4-3-0.ams10.ip.tiscali.net [89.149.185.93]
7 59 ms 198 ms 84 ms core1.ams.net.google.com [195.69.144.247]
8 112 ms 106 ms 99 ms 209.85.248.93
9 131 ms 130 ms 127 ms 64.233.175.246
10 62 ms 57 ms 45 ms 72.14.239.197
11 152 ms 121 ms * 209.85.255.122
12 129 ms 124 ms 134 ms ey-in-f104.google.com [74.125.79.104]
Trace complete.
Schiterend die waarden ! pfff en da na een "upgrade" naar het bgc netwerk .. heb meer den indruk dat op een "downgrade" ga hier
Ik word er stilaan gek van..
Morgen nog een terugbellen..
