kan ik met deze waarden overstappen? anders steek ik er mijn tijd niet in:
Advanced DSL Port Configuration
Return to basic attribute list...
Advanced Port Attributes
Name Value
Driver Version 1.57
API Version GS_API_419
Firmware Version A.4.19.21
Dsp Version Turbo v1.0 A0 (0x40)
Connected true
Operational Mode G.Dmt
State Showtime
Watchdog 0x00000053
Operation Progress 0x000000ad
Last Failed 0x000000fd
Tx Bit Rate 384000
Rx Bit Rate 3328000
Tx Cell Rate 905
Rx Cell Rate 7849
Phy TX Cell Count 2666
Phy RX Cell Count 5997
Phy Cell Drop Count 0
Overall Failure 0
Local ITU Country Code 0x0000b5ff
Local SEF 0
Local End LOS 0
Local SNR Margin 25.5 dB
Local Line Attn 34.5 dB
Raw Attn 0.0 dB
Local Tx Power 11.9 dB
Local Fast Channel Rx Rate 3328000
Local Fast Channel Tx Rate 384000
Local Fast Channel FEC 0
Local Fast Channel CRC 2
Local Fast Channel HEC 0
Local Fast Channel NCD 0
Local Fast Channel OCD 0
Local Interleaved Channel Rx Rate 0
Local Interleaved Channel Tx Rate 0
Local Interleaved Channel FEC 0
Local Interleaved Channel CRC 0
Local Interleaved Channel HEC 0
Local Interleaved Channel NCD 0
Local Interleaved Channel OCD 0
Remote SEF 0
Remote LOS 0
Remote Line Attn 21.0 dB
Remote SNR Margin 24 dB
Remote Fast Channel FEC 0
Remote Fast Channel CRC 0
Remote Fast Channel HEC 0
Remote Fast Channel NCD 0
Remote Interleaved Channel FEC 0
Remote Interleaved Channel CRC 0
Remote Interleaved Channel HEC 0
Remote Interleaved Channel NCD 0
Host Control Enable
Auto Start True
Failsafe false
Whip Disable
Whip Active Inactive
Action Startup
Profile Main
Standard Multimode
Ec Fdm Mode FDM
Max Bits Per Bin 15
Tx Start Bin 6
Tx End Bin 31
Rx Start Bin 32
Rx End Bin 255
Rx Auto Bin Adjust Disable
Tx Attenuation 0
Bit Swap Enable
Bit Swap Up Disable
NTR Mode Enable
Annex Type AnnexA
Max Down Rate 131040000
Physical Port 0
Retrain Enable
Detect Noise Disable
Capability Disable
Coding Gain auto
Cut Back Disable
Framer Type Type3
Fast Retrain Disable
Dying Gasp Disable
Defaults None
Activate Line None
Reset Defaults False
Port Snmp If Index 1
Port Snmp If Type 37
Dank bij voorbaat
Kan ik naar een 6Mbit profiel gaan
- seagull
- Twitter: WimVerlinden
- Uitgedeelde bedankjes: 51 keer
- Bedankt: 91 keer
Doe geen moeite. Ik heb 9 maanden bij Scarlet gezaagd. Telekens zou er volgende maand een oplossing komen. Niet dus.
Nu zit ik bij edpnet wel met een 6 Mbit profiel en betaal ik 10 euro minder per maand.
Business Fibernet 300 plus met Speedboost 1G Business- Proximus Internet Maxi fixed IP (failover)
Business Mobile Flex + (smartphone) & Business Mobile Flex (Mifi router) - 3CX/Teams Direct Routing - Proximus TV
nekpijn schreef:Ok dan waag ik mij aan een koppel uren telefoneren met de scarlet helpdesk.
Of weet iemand hier een nr van scarlet waar ze echt iets weten en ik geen uur aan de telefoon moet hangen?
Nee, de kans dat er bij Scarlet iemand is die over IETS op de hoogte is, is quasi nihil.
- Bedankt: 16 keer
deej schreef:Hoge SNR en deftige Line Attenuation. Zou moeten werken volgens mij.
Hoeveel moet je eigenlijk hebben om goed te zijn? (Downstream-Upstream)
En wat geven deze waarden eigenlijk aan?
