kan ik met deze waarden overstappen? anders steek ik er mijn tijd niet in:
Advanced DSL Port Configuration
Return to basic attribute list...
Advanced Port Attributes
Name					Value
Driver Version 				1.57
API Version 				GS_API_419
Firmware Version 			A.4.19.21
Dsp Version 				Turbo v1.0 A0 (0x40)
Connected 				true
Operational Mode 			G.Dmt
State 					Showtime
Watchdog 				0x00000053
Operation Progress 			0x000000ad
Last Failed 				0x000000fd
Tx Bit Rate 				384000
Rx Bit Rate 				3328000
Tx Cell Rate 				905
Rx Cell Rate 				7849
Phy TX Cell Count 			2666
Phy RX Cell Count 			5997
Phy Cell Drop Count 			0
Overall Failure 			0
Local ITU Country Code 			0x0000b5ff
Local SEF 				0
Local End LOS 				0
Local SNR Margin 			25.5 dB
Local Line Attn 			34.5 dB
Raw Attn 				0.0 dB
Local Tx Power 				11.9 dB
Local Fast Channel Rx Rate 		3328000
Local Fast Channel Tx Rate 		384000
Local Fast Channel FEC 			0
Local Fast Channel CRC 			2
Local Fast Channel HEC 			0
Local Fast Channel NCD 			0
Local Fast Channel OCD 			0
Local Interleaved Channel Rx Rate 	0
Local Interleaved Channel Tx Rate 	0
Local Interleaved Channel FEC 		0
Local Interleaved Channel CRC 		0
Local Interleaved Channel HEC 		0
Local Interleaved Channel NCD 		0
Local Interleaved Channel OCD 		0
Remote SEF 				0
Remote LOS 				0
Remote Line Attn 			21.0 dB
Remote SNR Margin 			24 dB
Remote Fast Channel FEC 		0
Remote Fast Channel CRC 		0
Remote Fast Channel HEC 		0
Remote Fast Channel NCD 		0
Remote Interleaved Channel FEC 		0
Remote Interleaved Channel CRC 		0
Remote Interleaved Channel HEC 		0
Remote Interleaved Channel NCD 		0
Host Control 				Enable
Auto Start 				True
Failsafe 				false
Whip 					Disable
Whip Active 				Inactive
Action 					Startup
Profile 				Main
Standard 				Multimode
Ec Fdm Mode 				FDM
Max Bits Per Bin 			15
Tx Start Bin 				6
Tx End Bin 				31
Rx Start Bin 				32
Rx End Bin 				255
Rx Auto Bin Adjust 			Disable
Tx Attenuation 				0
Bit Swap 				Enable
Bit Swap Up 				Disable
NTR Mode 				Enable
Annex Type 				AnnexA
Max Down Rate 				131040000
Physical Port 				0
Retrain 				Enable
Detect Noise 				Disable
Capability 				Disable
Coding Gain 				auto
Cut Back 				Disable
Framer Type 				Type3
Fast Retrain 				Disable
Dying Gasp 				Disable
Defaults 				None
Activate Line 				None
Reset Defaults 				False
Port Snmp If Index 			1
Port Snmp If Type 			37
Dank bij voorbaat
						Kan ik naar een 6Mbit profiel gaan
- seagull
- Twitter: WimVerlinden
- Bedankt: 108 keer
Doe geen moeite. Ik heb 9 maanden bij Scarlet gezaagd. Telekens zou er volgende maand een oplossing komen. Niet dus.
Nu zit ik bij edpnet wel met een 6 Mbit profiel en betaal ik 10 euro minder per maand.
Nee, de kans dat er bij Scarlet iemand is die over IETS op de hoogte is, is quasi nihil.nekpijn schreef:Ok dan waag ik mij aan een koppel uren telefoneren met de scarlet helpdesk.
Of weet iemand hier een nr van scarlet waar ze echt iets weten en ik geen uur aan de telefoon moet hangen?
				skipper
- Bedankt: 16 keer
Hoeveel moet je eigenlijk hebben om goed te zijn? (Downstream-Upstream)deej schreef:Hoge SNR en deftige Line Attenuation. Zou moeten werken volgens mij.
En wat geven deze waarden eigenlijk aan?
