Speed Problems EDPnet?
hi,
since 1 hour my dsl line (edpnet max6 dyn) is very slow. only between 700 and 1000kbit. i dont have any down and uploads active...
Your current download speed:
751kbit/s
or
94kbyte/s
Your current upload speed:
295kbit/s
or
37kbyte/s
have you also problems?
chris
751kbit/s
or
94kbyte/s
295kbit/s
or
37kbyte/s
chris
Laatst gewijzigd door conrads 05 feb 2006, 18:55, in totaal 2 gewijzigd.
heb hetzelfde probleem, zeer slechte downloadsnelheden met mijn nieuwe 6mbit lijn
http://www.adslbox.be speed test results:
- Download speed : 378 kbit/s or 47 kbyte/s
- Upload speed : 374 kbit/s or 47 kbyte/s
Sun Feb 5 2006 at 19:33:15 UTC+0100
byter
- Bedankt: 6 keer
yup it is happening again; made a ticket but it is kinda late
C:\>tracert 82.192.78.104
Bezig met het traceren van de route naar 82.192.78.104 via maximaal 30 hops
1 <1 ms <1 ms <1 ms SpeedTouch.lan
2 10 ms 10 ms 10 ms 213.219.175.1.adslpower.by.edpnet.be [213.219.17
5.1]
3 11 ms 11 ms 10 ms 213.219.132.237.adslpower.by.edpnet.be [213.219.
132.237]
4 13 ms 13 ms 13 ms 213.219.132.210.adslpower.by.edpnet.be [213.219.
132.210]
5 156 ms 169 ms 172 ms adam01.edpnet.net [212.71.27.6]
6 143 ms 143 ms 141 ms 10ge-2-0.amsix.ams.nl.leaseweb.net [195.69.144.2
15]
7 133 ms 133 ms 135 ms gi2-1.tc2.nl.leaseweb.net [62.212.80.29]
8 138 ms 144 ms 160 ms 82.192.78.104
De trace is voltooid.
always high pings at adam01.edpnet.net
5.1]
132.237]
132.210]
15]
I got my EDPnet connection active this afternoon , and I'm experiencing low download speeds (not higher than 400Kb/s from ftp.belnet.be , with my previous isp I got a stable 430kb/s on a 4mbit line profile , now less on a 6mbit line profileconrads schreef:hi,
also this evening i have some speed problems, low connection rates, high pings... the whole day all was ok, but since 19h the problems are appearing!
whats happening EDPNET?
chris
Pingen naar www.games.telenet.be [195.130.132.82] met 32 byte gegevens:
Antwoord van 195.130.132.82: bytes=32 tijd=170 ms TTL=53
Antwoord van 195.130.132.82: bytes=32 tijd=191 ms TTL=53
Antwoord van 195.130.132.82: bytes=32 tijd=153 ms TTL=53
Antwoord van 195.130.132.82: bytes=32 tijd=112 ms TTL=53
Antwoord van 195.130.132.82: bytes=32 tijd=145 ms TTL=53
Antwoord van 195.130.132.82: bytes=32 tijd=133 ms TTL=53
Antwoord van 195.130.132.82: bytes=32 tijd=128 ms TTL=53
Antwoord van 195.130.132.82: bytes=32 tijd=116 ms TTL=53
Pingen naar www.google.com [64.233.183.99] met 32 byte gegevens:
Antwoord van 64.233.183.99: bytes=32 tijd=165 ms TTL=242
Antwoord van 64.233.183.99: bytes=32 tijd=171 ms TTL=242
Antwoord van 64.233.183.99: bytes=32 tijd=176 ms TTL=242
Antwoord van 64.233.183.99: bytes=32 tijd=164 ms TTL=242
thx, good that the problem is in the network and not caused by my line
i opened also a ticket i hope EDPnet will get the problems under control. it would be very bad to have each evening these problems!
chris
chris
- Ken
- Bedankt: 110 keer
Same problem tonight
It's like I caught a nasty line every evening. Very strange. I'm the only user atm. No other persons of my family are downloading or uploading something.
and again... i have to quit gaming because the lag is getting to worse...
just the same as yesterday , when I tried to ping again at 2400 the pings where still a bit high but normal (50ms) and I was even able to play online !
Didn't heard anything from the ticket I made yet , if I still don't have a response tomorrow I'm gonna call the support line. I can't live with such high pings when I wanna play online
*edit*
when performing a traceroute to google.be it seems that it's starts to lag at adam01.edpnet.net [212.71.27.6] , just like byter in his post yesterday mentioned.
Are there other people where it's lagging to at the moment ? (just checking if it isn't region dependend , i'm living 30km from byter)
Antwoord van 195.130.132.82: bytes=32 tijd=183 ms TTL=53
Time-out bij opdracht.
Antwoord van 195.130.132.82: bytes=32 tijd=174 ms TTL=53
Antwoord van 195.130.132.82: bytes=32 tijd=172 ms TTL=53
Pingen naar www.l.google.com [64.233.183.147] met 32 byte gegevens:
Antwoord van 64.233.183.147: bytes=32 tijd=212 ms TTL=242
Antwoord van 64.233.183.147: bytes=32 tijd=192 ms TTL=242
Antwoord van 64.233.183.147: bytes=32 tijd=199 ms TTL=242
Antwoord van 64.233.183.147: bytes=32 tijd=151 ms TTL=242
*edit*
1 10 ms 10 ms 10 ms 213.219.173.1.adslpower.by.edpnet.be [213.219.17
3.1]
2 11 ms 10 ms 10 ms 213.219.132.237.adslpower.by.edpnet.be [213.219.
132.237]
3 14 ms 13 ms 13 ms 213.219.132.210.adslpower.by.edpnet.be [213.219.
132.210]
4 104 ms 100 ms 103 ms adam01.edpnet.net [212.71.27.6]
5 148 ms 153 ms * ge-5-1-0.mpr3.ams1.nl.above.net [195.69.144.122]
6 140 ms 135 ms 136 ms so-0-0-0.mpr1.ams5.nl.above.net [64.125.27.182]
7 122 ms 135 ms 147 ms so-5-0-0.cr2.lhr3.uk.above.net [64.125.27.177]
8 130 ms 130 ms 128 ms pos-8-0.mpr2.lhr1.uk.above.net [64.125.27.217]
9 172 ms 162 ms 168 ms 213-152-230-99.google.net [213.152.230.99]
10 * 170 ms 173 ms 72.14.238.246
11 171 ms 164 ms 173 ms 216.239.43.91
12 182 ms 185 ms 207 ms 216.239.43.88
13 167 ms 160 ms 154 ms 64.233.175.246
14 146 ms 169 ms 163 ms 216.239.43.30
15 171 ms 169 ms 170 ms 64.233.183.147
Mmm... not enough bandwidth on the peering ?ruben schreef:when performing a traceroute to google.be it seems that it's starts to lag at adam01.edpnet.net [212.71.27.6] , just like byter in his post yesterday mentioned.
vanuit antwerpen:
gro@darkstar:~ % traceroute www.google.be (di 7 20:57)
traceroute: Warning: www.google.be has multiple addresses; using 64.233.183.104
traceroute to www.l.google.com (64.233.183.104), 30 hops max, 46 byte packets
1 usrobotics (192.168.1.1) 1.692 ms 1.709 ms 1.616 ms
2 213.219.164.1 (213.219.164.1) 8.816 ms 13.149 ms 8.641 ms
3 213.219.132.237.adslpower.by.edpnet.be (213.219.132.237) 15.629 ms 12.516 ms 9.208 ms
4 213.219.132.25.adslpower.by.edpnet.be (213.219.132.25) 17.464 ms 13.067 ms 11.755 ms
5 adam01.edpnet.net (212.71.27.6) 163.225 ms 169.155 ms 172.212 ms
6 ge-5-1-0.mpr3.ams1.nl.above.net (195.69.144.122) 177.694 ms 175.841 ms 185.002 ms
7 so-0-0-0.mpr1.ams5.nl.above.net (64.125.27.182) 173.217 ms 160.804 ms 173.433 ms
8 so-5-0-0.cr2.lhr3.uk.above.net (64.125.27.177) 202.164 ms * 202.054 ms
9 pos-8-0.mpr2.lhr1.uk.above.net (64.125.27.217) 197.214 ms 206.970 ms 212.617 ms
10 213-152-230-99.google.net (213.152.230.99) 217.443 ms 227.626 ms 225.981 ms
11 72.14.238.246 (72.14.238.246) 231.733 ms 72.14.238.242 (72.14.238.242) 182.326 ms 187.191 ms
12 216.239.43.91 (216.239.43.91) 188.448 ms 187.605 ms 184.175 ms
13 216.239.43.88 (216.239.43.88) 190.958 ms 204.598 ms 219.267 ms
14 64.233.175.246 (64.233.175.246) 207.064 ms 200.384 ms 204.552 ms
15 216.239.43.30 (216.239.43.30) 195.187 ms 199.877 ms 226.605 ms
16 64.233.183.104 (64.233.183.104) 212.993 ms * 240.745 ms
- deej
- Bedankt: 4 keer
Ik heb al 2 maand een ticket open voor occasionele lag op die router maar ze zeggen dat er niks aan de hand is.ruben schreef: when performing a traceroute to google.be it seems that it's starts to lag at adam01.edpnet.net [212.71.27.6] , just like byter in his post yesterday mentioned.
Hoop dat ze me nu gaan geloven en er iets aan gaan doen
MRC101
- Bedankt: 5 keer
Here in Gent everything looks good (or am I testing to late?).
traceroute to www.l.google.com (64.233.183.147), 10 hops max, 44 byte packets
1 213.219.174.1.adslpower.by.edpnet.be (213.219.174.1) 6.294 ms 6.227 ms 6.089 ms
2 213.219.132.237.adslpower.by.edpnet.be (213.219.132.237) 6.326 ms 6.668 ms 7.022 ms
3 213.219.132.25.adslpower.by.edpnet.be (213.219.132.25) 10.539 ms 8.962 ms 9.224 ms
4 adam01.edpnet.net (212.71.27.6) 25.547 ms 25.194 ms 24.793 ms
5 ge-5-1-0.mpr3.ams1.nl.above.net (195.69.144.122) 33.223 ms 29.413 ms 42.022 ms
6 so-0-0-0.mpr1.ams5.nl.above.net (64.125.27.182) 29.536 ms 29.619 ms 25.273 ms
7 so-5-0-0.cr2.lhr3.uk.above.net (64.125.27.177) 41.062 ms 39.981 ms 36.875 ms
8 pos-8-0.mpr2.lhr1.uk.above.net (64.125.27.217) 32.939 ms 32.066 ms 33.143 ms
9 213-152-230-99.google.net (213.152.230.99) 45.571 ms 41.425 ms 50.441 ms
10 72.14.238.242 (72.14.238.242) 56.114 ms 72.14.238.246 (72.14.238.246) 47.680 ms 55.075 ms
everything is fine here too , it seems that they have a bottleneck when it's 'rush hour' (dont know how to call it in english but in dutch it's called 'piekuur')
now i'm playing on
82.192.78.29:27015 (telenet games cs server #1) with a ping ingame around 30-70ms (which isn't that good , but playable)
also , when pinging google.be :
since this was the same yesterday it lets me conclude that there aren't any problems when there are less users online at the same time , and that EDPnet has to do a network upgrade (maybe on the specific node adam01.edpnet.net only ?) to let those lag problems disapear.
now i'm playing on
Bezig met het traceren van de route naar www.l.google.com [64.233.183.147]
via maximaal 30 hops:
3.1]
2 11 ms 11 ms 10 ms 213.219.132.237.adslpower.by.edpnet.be [213.219.
132.237]
3 13 ms 13 ms 13 ms 213.219.132.210.adslpower.by.edpnet.be [213.219.
132.210]
4 31 ms 29 ms 30 ms adam01.edpnet.net [212.71.27.6]
5 27 ms 27 ms 26 ms ge-5-1-0.mpr3.ams1.nl.above.net [195.69.144.122]
6 25 ms * 25 ms so-0-0-0.mpr1.ams5.nl.above.net [64.125.27.182]
7 38 ms 39 ms 41 ms so-5-0-0.cr2.lhr3.uk.above.net [64.125.27.177]
8 39 ms 41 ms 47 ms pos-8-0.mpr2.lhr1.uk.above.net [64.125.27.217]
9 48 ms 51 ms * 213-152-230-99.google.net [213.152.230.99]
10 46 ms 47 ms 43 ms 72.14.238.242
11 37 ms 40 ms 40 ms 216.239.43.91
12 43 ms 46 ms 39 ms 216.239.43.88
13 49 ms 49 ms 48 ms 216.239.43.89
14 58 ms 56 ms 57 ms 216.239.43.30
15 59 ms 51 ms 55 ms 216.239.43.41
16 73 ms 60 ms * 64.233.183.147
17 55 ms 53 ms 55 ms 64.233.183.147
Jelly
- Bedankt: 17 keer
Maybe also the reason why there is a delay with the outroll of adsl2+?
Guess it's just the same like all the small providers... good offer but no bandwith to support it.
Greetings, Jellen
Greetings, Jellen
Everything that has a beginning has an end.
- EDPnet
- ISP Official
- Bedankt: 153 keer
Zoals gisteren reeds aangegeven in een andere posting : de overschakeling van BROBAII naar BRUO (o.a. om ADSL2+ te kunnen supporteren) zal veel van de PVC-upgrade problematiek automatisch oplossen.
internet, fiber & telephony
nephilimhell
- Bedankt: 3 keer
wanneer is die overschakeling voorzien?EDPnet schreef:Zoals gisteren reeds aangegeven in een andere posting : de overschakeling van BROBAII naar BRUO (o.a. om ADSL2+ te kunnen supporteren) zal veel van de PVC-upgrade problematiek automatisch oplossen.
FlashBlue
- Erelid
- Bedankt: 296 keer
sometimes i wonder ...
do u only use your dsl connection to do speedtests and complain here if they arent perfect ? because you wont notice those small speed variances in surfing or downloading ...
Ik heb geen snelheidsproblemen meer op het moment (sinds gisteren),maar mijn lijnconnectie staat ook iets lager dan 6Mbit zegt maar 5Mbit ofzoiets.
4409kbit/s
or
551kbyte/s
517kbit/s
or
65kbyte/s
ps. waarom kun je met de speedtest het resultaat niet meer in uw clipboard plakken
4409kbit/s
or
551kbyte/s
517kbit/s
or
65kbyte/s
my dear, i think is my decision to post some troubles in this forum. i don't need any unprofessional comments... the last one i posted a problem it was a big problem @edpnet (after this they upgraded their international backbone)!FlashBlue schreef:sometimes i wonder ...
so keep cool
@other, interested users: my speed problems are solved now - i seems that it was a capacity-problem (peak time at weekend)
plasma-lcd
- Starter
Ik heb sinds een week echt veel snelheids verlies
sinds vrijdag adslmax maar snelheid ligt tussen de 100kb en de 595kb
is niet normaal.
Tot voor een week gelden op mijn neutrino 3000 altijd CONSTANT 300kb
Zou volgends edp aan mijn binnenbekabbeling liggen , maar kan absoluut niet omdat die pas een jaar oud zijn en ik dus tot voorkort NOOIT problemen had.
Ik heb edp weer gemailt met screenshots van de speedtests.
Hoop echt dat het probleem snel opgelost is.
is niet normaal.
- Bijlagen
- speestest
- (6.37 KiB) 1722 keer gedownload
- userbase
- (4.69 KiB) 1722 keer gedownload
Funfile
- Bedankt: 37 keer
plasma-lcd schreef:Ik heb sinds een week echt veel snelheids verlies
is niet normaal.![]()
Bij mij is het hetzelfde. Voorheen altijd connectie aan 3,3 Mb. Vanaf dat EDPnet de eerste opleveringen deed van hun Max regelmatig disconnecties en dan connecties aan 1,6 Mbps. En nu mijn lijn is overgeschakeld naar Max heb ik steeds connectie aan 2,0 Mbps.
EDPnet heeft metingen (laten) uitvoeren en zegt dat het aan mijn binneninstallatie ligt (groot verlies hierop volgens hun). Ik vraag me toch af hoe het kan dat ik nu ineens - 'toevallig' met het invoeren van de nieuwe formules - problemen krijg. Al 2 maal een ticket ingelegd met telkens hetzelfde antwoord.
Ik steek het voorlopig op kinderziektes. Ben al lang blij dat ik die 2 Mbps verbinding tenminste nog heb, en dat die niet meer disconnecteert.
Afstand tot de centrale is nog geen kilometer, dus daar kan het niet aan liggen.
Pluk de dag
OS : Windows 10, Linux Mint
FlashBlue
- Erelid
- Bedankt: 296 keer
het is niet omdat binnenbekabeling niet "oud" is; of goed heeft gewerkt op lagere snelheden; dat het met een 6mbit ook goed werkt.
Ik heb hier zelf ook jarenlang geen problemen gehad; en na kerst ineens upload problemen; disconnects; timeouts; etc ...
Attenuation en noise margin waren perfect; het was een voorbeeldlijn ... Na verschillende metingen heeft edpnet uiteindelijk een call opgezet met edpnet ; mij ; en belgacom; en zijn we gaan zoeken; uiteindelijk bleek er een isolatieprobleem te zijn tussen 2 aderparen in de binnenbekabeling ... (en dat waren geen simpele dunne telefoonsnoeren; maar high end telecombekabeling)
En die lijn had OOK jaaaaren perfect gewerkt ...
Verder hangt veel af van je modem; de alcatel ethernet speedtouchen bvb zijn heel goed in het vasthouden van sync op slechte lijnen; maar als je van een "redelijk slechte lijn" met een 3.3mbit naar een "redelijk slechte lijn" met 6mbit profiel gaat; dan kan het goed zijn dat de modem serieus gaat terugstappen om een stabiele sync te krijgen.
Dus, niet te rap roepen dat binnen alles in orde is; een splitter die niet perfect is; een toestel met een te hoge loadfactor; een kabel met een beetje crosstalk erop ... allemaal mogelijke redenen .
Persoonlijk heb ik ondervonden dat enkel de speedtest van userbase.be de meest correcte resultaten geeft. Andere testen gaven dan soms wel hogere cijfers... soms zelfs tot meer dan wat fysisch mogelijk was met de hardware ! (maak je dus niet blij met een dode mus).WhiteDog schreef:Ik zou iedereen aanraden om niet teveel af te gaan op de resultaten van de speedtests op userbase en ispmonitor. In de praktijk ligt de snelheid een pak hoger.
Bij mij blijft mijn snelheid stabiel hoor natuurlijk geen 600kb, maar zolang het boven 500kb is hoor je mij zker niet klagen
4255kbit/s
or
532kbyte/s
223kbit/s
or
28kbyte/s
4255kbit/s
or
532kbyte/s
223kbit/s
or
28kbyte/s
plasma-lcd
- Starter
ik zit nu met telefoonkabel van 60cm direct op adsl aansluiting
allemaal nieuwe kabels
blijft maar 119KB
tis volgens mij gewoon te weinig capaciteit voor al die nieuwe klanten is precies ene week nu aan de gang.
Mijn profiel van de modem staat gewoon op 6144/640
ik heb de edpnet Bausch proxima PR-I
moet ik ''opeens'' iets aan mijn instellingen veranderen?
blijft maar 119KB
- EDPnet
- ISP Official
- Bedankt: 153 keer
Het zou kunnen dat de capaciteit die voorzien is op het ATM netwerk van Belgacom te beperkt is. Om dit te kunnen nakijken dient u een support ticket te openen bij EDPnet. Is het mogelijk om misschien reeds enkele testen te doen op basis van tracert & ping ? Ook status informatie (te vinden in uw modem) over mogelijke lijnerrors kan interessant zijn.
plasma-lcd
- Starter
Ticket is al reeds gemaakt
vreemd nu blijft de snelheid steeds 119kb dus ook geen pieken meer
geen errors in modem admin
- Bijlagen
- (6.3 KiB) 1549 keer gedownload
- (6.14 KiB) 1549 keer gedownload
Funfile
- Bedankt: 37 keer
Gisteren en vandaag zonder problemen terug connectie aan 3,3 Mbps. Volgens mij zijn ze bij EDPnet hard aan het werken om hun snelheden terug op een normaal niveau te brengen. Chapeau !
Pluk de dag
