Hello,
I would like to start experimenting with IPoE (single VLAN) on VDSL2.
I can configure the change from shared VLAN (PPPoE) to single VLAN in MyProximus.
Is there any way I can use my BBox3 as modem (in bridge mode?) with that setup?
Thanks for your ideas
IPoE (single VLAN) with BBox3 ?
- Bedankt: 3720 keer
As far as we are aware, this is not supported.
However, you can swap your B-box with a new Proximus "Internet Box"
- as soon as the Internet Box is detected, your line will automatically be converted to "single VLAN" mode.
- bridge mode is available trough "My Proximus" (by adding the WAN MAC adress of your router in the "Bridged Host" field.
- alloja
- Bedankt: 51 keer
I’ve heard on the contrary that the latest b-box 3 software updates add the compatibility to the single VLAN. Nevertheless, until now, I’ve only used Internet Box in order to “convert” my line to single VLAN. So it’s perhaps more appropriate to ask a swap to make sure the line is OK end-to-end.
UCG-Fiber • Proximus Flex+ Ultra Fiber • Voo Giga Max
Vu+ Duo 4K SE (DVB-C + DVB-T2) • V7c • Box évasion • Apple TV 4K (Pickx Mix FR)
qless
- Bedankt: 155 keer
I'm not sure that it will automatically be converted, as on my fiber line (mobile vikings) the internet box would not work. only the bbox would work.philippe_d schreef: 13 feb 2025, 10:51 As far as we are aware, this is not supported.
However, you can swap your B-box with a new Proximus "Internet Box"In this case no need for PPPoE anymore on your own router.
