DDR3 bitrot uitlokbaar: Many DDR3 Modules Vulnerable
Nasty ....
Researchers from Carnegie Mellon and Intel report that a large percentage of tested regular DDR3 modules flip bits in adjacent rows (PDF) when a voltage in a certain control line is forced to fluctuate. The program that triggers this is dead simple — just two memory reads with special relative offset and some cache control instructions in a tight loop. The researchers don't delve deeply into applications of this, but hint at possible security exploits. For example a rather theoretical attack on JVM sandbox using random bit flips (PDF) has been demonstrated before.
https://www.ece.cmu.edu/~safari/pubs/kim-isca14.pdf
