(zie topic : http://userbase.be/forum/viewtopic.php?f=48&t=42488)
Goed, even wachten tot DLM langskomt denk ik dan.
Vanochtend plots teruggevallen op 16,5/2 (std 8d profiel, geen repair helaas)
Dit is wat VDSL2 tool zegt:
 __________________________________________________
| VDSL2Tool 3.0 | © Arno Raps | http://hierzo.net/ |
\__________________________________________________/
				downstream			upstream
Line:			16552 kbps			2064 kbps
Max: 			48225 kbps			10104 kbps
Profile: 		8d
Distance:		44 m
Training:		33,1 dB
Attenuation:	6 dB
Extended Port Status
Bme: 1 Port: 1
Downstream line rate: 20000 kbps
Upstream line rate: 2752 kbps
Bearer0 Downstream payload rate: 0 kbps
Bearer1 Downstream payload rate: 16552 kbps
Bearer0 Upstream payload rate: 0 kbps
Bearer1 Upstream payload rate: 2064 kbps
Downstream attainable payload rate: 58736 kbps
Downstream attainable line rate: 73500 kbps
Downstream Training Margin: 33.1 dB
Downstream Line Protection (Bearer1 Path): 4.0 DMT Symbols
Upstream Line Protection (Bearer1 Path): 1.0 DMT Symbols
Near-end ITU Vendor Id: 0xb500494b4e530200
Far-end ITU Vendor Id: 0xb5004244434da45f
Downstream delay: 14.8 ms
Upstream delay: 4.2 ms
Tx total power -29.4 dbm
FE Tx total power 11.2 dbm
VDSL Estimated Loop Length : 437 ft
G.Hs Estimated Near End Loop Length : 0 ft
G.Hs Estimated Far End Loop Length :0 ft
Current framing mode: 0x10
Bandplan Type...........: 2
No. of Upstream Bands...: 2
No. of Downstream Bands.: 2
Line Type: 0x00800000
