Peerguardian blockt IP's op Userbase
Geplaatst: 28 apr 2004, 23:51
door MrZipper
Hoi,
Ik heb het prg'tje Peerguardian geïnstalleerd; deze zorgt ervoor dat 'ongewenste' IP's' (lees: RIAA en Co) geblocked worden.
Indien ik éénmaal op UB ingelogd ben begint Peerguardian gelijk een
gek IP's te blokken, bv:
Connection Rejected: 195.154.195.154 - atbp (04-28-2004 @ 23:31:26)
Connection Rejected: 213.244.183.212 - atbp (04-28-2004 @ 23:31:33)
Connection Rejected: 213.244.183.215 - atbp (04-28-2004 @ 23:31:33)
Connection Rejected: 213.244.183.215 - atbp (04-28-2004 @ 23:31:40)
Connection Rejected: 213.244.183.215 - atbp (04-28-2004 @ 23:31:44)
Connection Rejected: 213.244.183.204 - atbp (04-28-2004 @ 23:31:44)
Connection Rejected: 213.244.183.210 - atbp (04-28-2004 @ 23:31:44)
Connection Rejected: 213.244.183.212 - atbp (04-28-2004 @ 23:31:45)
Connection Rejected: 213.244.183.215 - atbp (04-28-2004 @ 23:31:45)
Connection Rejected: 213.244.183.215 - atbp (04-28-2004 @ 23:32:37)
Connection Rejected: 213.244.183.204 - atbp (04-28-2004 @ 23:32:37)
Connection Rejected: 213.244.183.210 - atbp (04-28-2004 @ 23:32:37)
Connection Rejected: 213.244.183.212 - atbp (04-28-2004 @ 23:32:37)
Connection Rejected: 213.244.183.204 - atbp (04-28-2004 @ 23:32:41)
Connection Rejected: 213.244.183.210 - atbp (04-28-2004 @ 23:32:41)
Connection Rejected: 213.244.183.212 - atbp (04-28-2004 @ 23:32:41)
Connection Rejected: 213.244.183.215 - atbp (04-28-2004 @ 23:32:41)
Connection Rejected: 213.244.183.210 - atbp (04-28-2004 @ 23:32:44)
Connection Rejected: 213.244.183.212 - atbp (04-28-2004 @ 23:32:44)
Connection Rejected: 213.244.183.215 - atbp (04-28-2004 @ 23:32:44)
Connection Rejected: 213.244.183.204 - atbp (04-28-2004 @ 23:32:44)
Connection Rejected: 213.244.183.212 - atbp (04-28-2004 @ 23:32:45)
Connection Rejected: 213.244.183.215 - atbp (04-28-2004 @ 23:32:45)
Connection Rejected: 213.244.183.204 - atbp (04-28-2004 @ 23:32:46)
Connection Rejected: 213.244.183.210 - atbp (04-28-2004 @ 23:32:46)
Connection Rejected: 213.244.183.212 - atbp (04-28-2004 @ 23:32:47)
Connection Rejected: 213.244.183.215 - atbp (04-28-2004 @ 23:32:47)
Connection Rejected: 213.244.183.204 - atbp (04-28-2004 @ 23:32:47)
Connection Rejected: 213.244.183.210 - atbp (04-28-2004 @ 23:32:47)
Connection Rejected: 213.244.183.212 - atbp (04-28-2004 @ 23:32:49)
Connection Rejected: 213.244.183.215 - atbp (04-28-2004 @ 23:32:49)
Connection Rejected: 213.244.183.204 - atbp (04-28-2004 @ 23:32:49)
Connection Rejected: 213.244.183.210 - atbp (04-28-2004 @ 23:32:49)
Connection Rejected: 213.244.183.212 - atbp (04-28-2004 @ 23:33:37)
Connection Rejected: 213.244.183.215 - atbp (04-28-2004 @ 23:33:37)
Connection Rejected: 213.244.183.204 - atbp (04-28-2004 @ 23:33:37)
Connection Rejected: 213.244.183.210 - atbp (04-28-2004 @ 23:33:37)
Connection Rejected: 213.244.183.212 - atbp (04-28-2004 @ 23:34:19)
Connection Rejected: 213.244.183.215 - atbp (04-28-2004 @ 23:34:19)
Connection Rejected: 213.244.183.204 - atbp (04-28-2004 @ 23:34:19)
Connection Rejected: 213.244.183.210 - atbp (04-28-2004 @ 23:34:19)
Connection Rejected: 213.244.183.212 - atbp (04-28-2004 @ 23:34:40)
Connection Rejected: 213.244.183.215 - atbp (04-28-2004 @ 23:34:40)
Connection Rejected: 213.244.183.204 - atbp (04-28-2004 @ 23:34:40)
Connection Rejected: 213.244.183.210 - atbp (04-28-2004 @ 23:34:40)
Connection Rejected: 213.244.183.212 - atbp (04-28-2004 @ 23:34:56)
Connection Rejected: 213.244.183.215 - atbp (04-28-2004 @ 23:34:56)
Connection Rejected: 213.244.183.204 - atbp (04-28-2004 @ 23:34:56)
Connection Rejected: 213.244.183.210 - atbp (04-28-2004 @ 23:34:56)
Connection Rejected: 213.244.183.212 - atbp (04-28-2004 @ 23:35:12)
Connection Rejected: 213.244.183.215 - atbp (04-28-2004 @ 23:35:12)
Connection Rejected: 213.244.183.204 - atbp (04-28-2004 @ 23:35:12)
Connection Rejected: 213.244.183.210 - atbp (04-28-2004 @ 23:35:12)
Connection Rejected: 213.244.183.212 - atbp (04-28-2004 @ 23:41:02)
Connection Rejected: 213.244.183.215 - atbp (04-28-2004 @ 23:41:02)
Connection Rejected: 213.244.183.204 - atbp (04-28-2004 @ 23:41:02)
Connection Rejected: 213.244.183.210 - atbp (04-28-2004 @ 23:41:02)
Connection Rejected: 213.244.183.212 - atbp (04-28-2004 @ 23:43:15)
Connection Rejected: 213.244.183.215 - atbp (04-28-2004 @ 23:43:15)
Connection Rejected: 213.244.183.204 - atbp (04-28-2004 @ 23:43:15)
Connection Rejected: 213.244.183.210 - atbp (04-28-2004 @ 23:43:15)
Kan iemand die Peerguardian heeft dit ook eens testen?
Of misschiens de logfiles van de Firewall eens bekijken of deze IP's er
ook tussenzitten?
Bedankt,
MrZipper
Geplaatst: 29 apr 2004, 10:00
door meon
Effe gekeken van wie die IP's zijn en die zijn van:
- Doubleclick.net (banners) en da's al niet van deze site, want die gebruiken we niet.
- Extreme Tracker, en die gebuiken we wél, ter aanvulling op de interne statistieken. Blijkbaar blokt PeerGuardian dus ook "webbugs", zijnde tracking images. Dat is dus wat er aan de hand is.
Geplaatst: 29 apr 2004, 13:22
door Speedsound
Extreme Tracker cookies worden ook gezien als spyware.
Ze worden o.a. ontdekt door Pestpatrol, info vind je hier.
Ze doen dus meer dan enkel je bezoekers tellen! :twisted:
Geplaatst: 29 apr 2004, 21:14
door MrZipper
bedankt voor de info Speedsound !
:wink:
Geplaatst: 29 apr 2004, 21:18
door MrZipper
Welke info van de user wordt er dan precies door jullie bijgehouden?
Graag een woordje meer uitleg ... :???:
Greetz
Geplaatst: 29 apr 2004, 21:24
door airzimmy
kijk zelf maar: http://www.extreme-dm.com/tracking/
Niets dat te misbruiken valt.
Geplaatst: 01 mei 2004, 21:45
door ubremoved_539
MrZipper schreef:Welke info van de user wordt er dan precies door jullie bijgehouden? Graag een woordje meer uitleg ... :???:
Juist niets... behalve je login (als je de cookie laat staan) en je daaraan verbonden account.
De informatie kan je trouwens beter uit je webserver log halen... en daar bv. een Webtrends op los laten.
