Hoi,
Ik heb het prg'tje Peerguardian geïnstalleerd; deze zorgt ervoor dat 'ongewenste' IP's' (lees: RIAA en Co) geblocked worden.
Indien ik éénmaal op UB ingelogd ben begint Peerguardian gelijk een
gek IP's te blokken, bv:
Connection Rejected: 195.154.195.154 - atbp (04-28-2004 @ 23:31:26)
Connection Rejected: 213.244.183.212 - atbp (04-28-2004 @ 23:31:33)
Connection Rejected: 213.244.183.215 - atbp (04-28-2004 @ 23:31:33)
Connection Rejected: 213.244.183.215 - atbp (04-28-2004 @ 23:31:40)
Connection Rejected: 213.244.183.215 - atbp (04-28-2004 @ 23:31:44)
Connection Rejected: 213.244.183.204 - atbp (04-28-2004 @ 23:31:44)
Connection Rejected: 213.244.183.210 - atbp (04-28-2004 @ 23:31:44)
Connection Rejected: 213.244.183.212 - atbp (04-28-2004 @ 23:31:45)
Connection Rejected: 213.244.183.215 - atbp (04-28-2004 @ 23:31:45)
Connection Rejected: 213.244.183.215 - atbp (04-28-2004 @ 23:32:37)
Connection Rejected: 213.244.183.204 - atbp (04-28-2004 @ 23:32:37)
Connection Rejected: 213.244.183.210 - atbp (04-28-2004 @ 23:32:37)
Connection Rejected: 213.244.183.212 - atbp (04-28-2004 @ 23:32:37)
Connection Rejected: 213.244.183.204 - atbp (04-28-2004 @ 23:32:41)
Connection Rejected: 213.244.183.210 - atbp (04-28-2004 @ 23:32:41)
Connection Rejected: 213.244.183.212 - atbp (04-28-2004 @ 23:32:41)
Connection Rejected: 213.244.183.215 - atbp (04-28-2004 @ 23:32:41)
Connection Rejected: 213.244.183.210 - atbp (04-28-2004 @ 23:32:44)
Connection Rejected: 213.244.183.212 - atbp (04-28-2004 @ 23:32:44)
Connection Rejected: 213.244.183.215 - atbp (04-28-2004 @ 23:32:44)
Connection Rejected: 213.244.183.204 - atbp (04-28-2004 @ 23:32:44)
Connection Rejected: 213.244.183.212 - atbp (04-28-2004 @ 23:32:45)
Connection Rejected: 213.244.183.215 - atbp (04-28-2004 @ 23:32:45)
Connection Rejected: 213.244.183.204 - atbp (04-28-2004 @ 23:32:46)
Connection Rejected: 213.244.183.210 - atbp (04-28-2004 @ 23:32:46)
Connection Rejected: 213.244.183.212 - atbp (04-28-2004 @ 23:32:47)
Connection Rejected: 213.244.183.215 - atbp (04-28-2004 @ 23:32:47)
Connection Rejected: 213.244.183.204 - atbp (04-28-2004 @ 23:32:47)
Connection Rejected: 213.244.183.210 - atbp (04-28-2004 @ 23:32:47)
Connection Rejected: 213.244.183.212 - atbp (04-28-2004 @ 23:32:49)
Connection Rejected: 213.244.183.215 - atbp (04-28-2004 @ 23:32:49)
Connection Rejected: 213.244.183.204 - atbp (04-28-2004 @ 23:32:49)
Connection Rejected: 213.244.183.210 - atbp (04-28-2004 @ 23:32:49)
Connection Rejected: 213.244.183.212 - atbp (04-28-2004 @ 23:33:37)
Connection Rejected: 213.244.183.215 - atbp (04-28-2004 @ 23:33:37)
Connection Rejected: 213.244.183.204 - atbp (04-28-2004 @ 23:33:37)
Connection Rejected: 213.244.183.210 - atbp (04-28-2004 @ 23:33:37)
Connection Rejected: 213.244.183.212 - atbp (04-28-2004 @ 23:34:19)
Connection Rejected: 213.244.183.215 - atbp (04-28-2004 @ 23:34:19)
Connection Rejected: 213.244.183.204 - atbp (04-28-2004 @ 23:34:19)
Connection Rejected: 213.244.183.210 - atbp (04-28-2004 @ 23:34:19)
Connection Rejected: 213.244.183.212 - atbp (04-28-2004 @ 23:34:40)
Connection Rejected: 213.244.183.215 - atbp (04-28-2004 @ 23:34:40)
Connection Rejected: 213.244.183.204 - atbp (04-28-2004 @ 23:34:40)
Connection Rejected: 213.244.183.210 - atbp (04-28-2004 @ 23:34:40)
Connection Rejected: 213.244.183.212 - atbp (04-28-2004 @ 23:34:56)
Connection Rejected: 213.244.183.215 - atbp (04-28-2004 @ 23:34:56)
Connection Rejected: 213.244.183.204 - atbp (04-28-2004 @ 23:34:56)
Connection Rejected: 213.244.183.210 - atbp (04-28-2004 @ 23:34:56)
Connection Rejected: 213.244.183.212 - atbp (04-28-2004 @ 23:35:12)
Connection Rejected: 213.244.183.215 - atbp (04-28-2004 @ 23:35:12)
Connection Rejected: 213.244.183.204 - atbp (04-28-2004 @ 23:35:12)
Connection Rejected: 213.244.183.210 - atbp (04-28-2004 @ 23:35:12)
Connection Rejected: 213.244.183.212 - atbp (04-28-2004 @ 23:41:02)
Connection Rejected: 213.244.183.215 - atbp (04-28-2004 @ 23:41:02)
Connection Rejected: 213.244.183.204 - atbp (04-28-2004 @ 23:41:02)
Connection Rejected: 213.244.183.210 - atbp (04-28-2004 @ 23:41:02)
Connection Rejected: 213.244.183.212 - atbp (04-28-2004 @ 23:43:15)
Connection Rejected: 213.244.183.215 - atbp (04-28-2004 @ 23:43:15)
Connection Rejected: 213.244.183.204 - atbp (04-28-2004 @ 23:43:15)
Connection Rejected: 213.244.183.210 - atbp (04-28-2004 @ 23:43:15)
Kan iemand die Peerguardian heeft dit ook eens testen?
Of misschiens de logfiles van de Firewall eens bekijken of deze IP's er
ook tussenzitten?
Bedankt,
MrZipper
Peerguardian blockt IP's op Userbase
- meon
- Twitter: meon
- Uitgedeelde bedankjes: 581 keer
- Bedankt: 780 keer
Effe gekeken van wie die IP's zijn en die zijn van:
- Doubleclick.net (banners) en da's al niet van deze site, want die gebruiken we niet.
- Extreme Tracker, en die gebuiken we wél, ter aanvulling op de interne statistieken. Blijkbaar blokt PeerGuardian dus ook "webbugs", zijnde tracking images. Dat is dus wat er aan de hand is.
Speedsound
- Starter
Extreme Tracker cookies worden ook gezien als spyware.
Ze worden o.a. ontdekt door Pestpatrol, info vind je hier.
Ze doen dus meer dan enkel je bezoekers tellen!
Welke info van de user wordt er dan precies door jullie bijgehouden?- Extreme Tracker, en die gebuiken we wél, ter aanvulling op de interne statistieken. Blijkbaar blokt PeerGuardian dus ook "webbugs", zijnde tracking images. Dat is dus wat er aan de hand is.
Graag een woordje meer uitleg ...
Greetz
Juist niets... behalve je login (als je de cookie laat staan) en je daaraan verbonden account.MrZipper schreef:Welke info van de user wordt er dan precies door jullie bijgehouden? Graag een woordje meer uitleg ...![]()
De informatie kan je trouwens beter uit je webserver log halen... en daar bv. een Webtrends op los laten.
