Slechte pings?
helaas
Forumleden,
Vandaag wilde ik na lange tijd nog eens online gamen, maar geen enkel spel valt deftig te spelen.
Ik heb namelijk last van verschrikkelijke pings. Dit probleem moet recent zijn, want ik had toevallig enkele dagen geleden nog eens een ping gedaan naar telenet.be, en dat bleef toen onder de 40ms.
Microsoft Windows [Version 6.2.9200]
(c) 2012 Microsoft Corporation. All rights reserved.
C:\Users\Kevin>ping www.telenet.be
Pinging webcontent.prd.telenet-ops.be [195.130.131.38] with 32 bytes of data:
Reply from 195.130.131.38: bytes=32 time=157ms TTL=50
Reply from 195.130.131.38: bytes=32 time=158ms TTL=50
Reply from 195.130.131.38: bytes=32 time=159ms TTL=50
Ping statistics for 195.130.131.38:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 157ms, Maximum = 159ms, Average = 158ms
C:\Users\Kevin>ping www.dommel.be
Pinging www.dommel.be [193.109.184.76] with 32 bytes of data:
Reply from 193.109.184.76: bytes=32 time=126ms TTL=124
Reply from 193.109.184.76: bytes=32 time=130ms TTL=124
Reply from 193.109.184.76: bytes=32 time=131ms TTL=124
Reply from 193.109.184.76: bytes=32 time=132ms TTL=124
Ping statistics for 193.109.184.76:
    Minimum = 126ms, Maximum = 132ms, Average = 129ms
C:\Users\Kevin>tracert telenet.be
Tracing route to telenet.be [195.130.144.20]
over a maximum of 30 hops:
  1     1 ms    <1 ms    <1 ms  192.168.1.1
  2   122 ms   124 ms   123 ms  gateway.customer.schedom-europe.net [83.101.75.1]
  3   130 ms   128 ms   126 ms  vlan202.ae2.largo-matisse.bru.schedom-europe.net [83.101.0.194]
  4   132 ms   127 ms   126 ms  4-2.r1.br.hwng.net [209.197.1.245]
  5   144 ms   152 ms   144 ms  3-4.r1.am.hwng.net [69.16.191.85]
  6   143 ms   145 ms     *     1-7.r1.fr.hwng.net [69.16.190.106]
  7   150 ms   145 ms   144 ms  xe-3-2-2.fra28.ip4.tinet.net [141.136.100.93]
  8   156 ms   160 ms   159 ms  xe-0-0-0.anr11.ip4.tinet.net [89.149.187.117]
  9   159 ms     *      161 ms  telenet-gw.ip4.tinet.net [141.136.97.250]
 10   165 ms   162 ms   163 ms  dD5E0FD06.access.telenet.be [213.224.253.6]
 11   159 ms   157 ms   166 ms  dD5E0F89D.access.telenet.be [213.224.248.157]
 12   152 ms   149 ms   150 ms  dD5E0F8A6.access.telenet.be [213.224.248.166]
 13     *        *        *     Request timed out.
 14     *        *        *     Request timed out.
 15     *        *        *     Request timed out.
 16     *        *        *     Request timed out.
 17     *        *        *     Request timed out.
 18     *        *        *     Request timed out.
 19     *        *        *     Request timed out.
 20     *        *        *     Request timed out.
 21  dD5E0F8A6.access.telenet.be [213.224.248.166]  reports: Destination net unreachable.
Trace complete.
Om andere toestellen op mijn netwerk hetzelfde, ligt dus niet aan de PC.
Ik ben woonachtig te Aarschot, zone 016.
Anderen met hetzelfde probleem?
Uzzi
Bedankt: 34 keer
helaas
Uzzi schreef:Misschien gerelateerd aan ....
http://userbase.be/forum/viewtopic.php?f=77&t=36403
Hmm.
Mijn stats:
[code]
                        download          upload
Line:                  30056 kbps        6048 kbps
Modem max:             72860 kbps        n/a Estimated!
Calculated max:        59821 kbps         12533 kbps Estimated!
Profile:               17a
Line length:           420 m Estimated!
Training margin:       17.5 dB
Attenuation:           14.6 dB
[/code]
Uzzi
Bedankt: 34 keer
Doe eens een speedtest ....
http://speedtest.telenet.be/
helaas
Last Result:
Download Speed: 6139 kbps (767.4 KB/sec transfer rate)
Upload Speed: 1797 kbps (224.6 KB/sec transfer rate)
Latency: 115 ms
04 January 2013 23:44:19
Zeer abnormaal...
Uzzi
Bedankt: 34 keer
Ongeveer de snelheden die ik momenteel haal ...
helaas
Lijkt mij opgelost te zijn ondertussen :)
Terug naar “Dommel”
