Relative capacity
redman
Bedankt: 97 keer
Weet iemand hoe je de "relative capacity" berekend van een adsl verbinding.
Is het juist dat dit kan afgeleid worden van de SNR margin, Line Attenuation en de Transmit Power?
Op google zijn er veel mensen die dezelfde vraag stellen maar geen antwoord.
liger
wist zelfs niet wat dat is
The amount of bandwidth being used on a telephone line, and one of the return results of the metallic line test.
If an individual has a Relative Capacity Occupancy over 70 percent, it is usually perceived that there is a short on the line. This can be caused by several situations.
1. The individual has DSL service and they have not installed microfilters on all of the analog telephone devices in their home.
2. There is some kind of a problem with the inside wiring in the person's home, such as a short or crossed wire causing attenuation.
3.The individual has a faulty piece of telephone equipment
