olivervr schreef:
Goed ik zal beginnen bij het begin en ik hoop dat iemand mij kan helpen.
Ik ben reeds 3 maand klant bij de EDPNET en tot over 3 weken geleden was er geen vuiltje aan de lucht, 17000 kbps super stabiele lijn.
Nu 3 weken geleden is de miserie begonnen, met disconnects, COM pagina's die ik niet kon openen of toch heel moeilijk. Als ik internet had en een game wou spelen dan verloor ik de connectie in het spel en had ik ook geen internet meer.
Op het moment is mijn stabiele lijn gesmolten tot 8539 kbps, da's de helft van wat het ooit was!
http://users.edpnet.be/kiara/Oliver/edpnet1.JPG
noise margin upstream: 10 db
output power downstream: 22 db
attenuation upstream: 4 db
tone 0- 31: 00 00 00 06 89 ab bb cc cc cd dd dd dc cb ba a7
tone 32- 63: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 64- 95: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 96-127: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 128-159: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 160-191: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 192-223: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 224-255: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 256-287: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 288-319: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 320-351: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 352-383: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 384-415: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 416-447: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 448-479: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 480-511: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
noise margin downstream: 25 db
output power upstream: 12 db
attenuation downstream: 14 db
tone 0- 31: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
tone 32- 63: 00 00 00 01 12 23 33 44 55 56 67 77 77 88 88 88
tone 64- 95: 88 88 88 88 88 88 88 88 88 88 88 88 88 88 88 88
tone 96-127: 88 88 88 88 88 88 88 87 77 77 77 77 77 77 77 77
tone 128-159: 77 77 77 77 77 77 77 77 77 77 77 76 76 66 66 66
tone 160-191: 66 66 66 66 66 66 66 66 66 66 66 66 66 66 66 66
tone 192-223: 66 66 66 66 66 65 66 66 66 66 66 65 66 66 66 66
tone 224-255: 56 66 66 66 55 55 55 55 55 55 55 55 25 65 56 66
tone 256-287: 78 88 88 88 88 88 88 88 88 88 88 88 88 88 88 88
tone 288-319: 88 88 88 88 88 88 88 88 88 88 88 88 88 88 88 88
tone 320-351: 88 88 87 77 77 77 77 77 77 77 77 77 77 76 66 67
tone 352-383: 76 66 66 66 66 66 66 66 66 66 66 66 66 66 66 66
tone 384-415: 66 66 55 65 55 55 55 55 55 55 55 55 55 55 55 55
tone 416-447: 55 44 44 44 44 44 44 44 44 44 44 44 44 44 44 44
tone 448-479: 33 33 33 33 33 33 33 33 33 32 22 22 22 22 22 22
tone 480-511: 22 22 21 11 11 11 11 11 11 11 11 11 11 11 11 10
Direct een ticket aangemaakt bij de provider met mijn problemen en volgens hun was alles in orde, het kon wel zijn dat er iets met de modem mis was maar dit moest ik zelf uitzoeken. De modem was wel bij hun aangekocht.
Nu gisteren heb ik dan een andere modem gekocht, namelijk de Linksys AM200, alles geïnstalleerd en alles liep perfect tot ik 's avond's thuiskwam.
Ik kan juist geteld en als ik snel ben 3 internet pagina's openen en dan doet ie niets meer.
EDIT// Ik ben vergeten te vertellen dat als ik de Zyxell modem opnieuw gebruik kan ik zonder problemen surfen, ik moet een instelling verkeerd zetten, maar welke.
De VPI/VCI instelling heb ik overgenomen van de zyxell modem.
Ik heb de router er van tussen gedaan maar niets helpt, heeft er iemand wat tips voor me in gewone mensentaal?
Ik heb een screen gemaakt van de instellingen.
http://users.edpnet.be/kiara/Oliver/linksys%20am200.JPG
Alvast bedankt,
Oliver
Veel problemen.
Eigelijk wou ik weten welke instellingen ik moet gebruiken voor de Linksys AM200 of wat ik verkeerd doe, op dit moment is het niet zozeer een probleem met EDPNET, enkel als ik veel bandbreedte nodig heb dan gaat het mis met de provider.L-army schreef:Netwerken > EDPnet
Dit is een EDPnet vraag en heeft weinig of niets te maken met netwerken.
Ik heb een nieuwe modem gekocht maar krijg hem niet deftig aan de praat, daarom dat ik het in netwerk fora had geplaatst.
Ik zou de modem in bridged modus zetten en de router hem via PPPoE laten aansturen. Zorg ook dat de IP ranges van modem en router niet hetzelfde zijn (niet alle2 192.168.1.0/24 bvb). En bij type verbinding kies ook "Keep Alive" ipv "Dial on Demand"...olivervr schreef:olivervr schreef:
...snip...
Alvast bedankt,
Oliver
