Telemeter doet gek
mensaap
HTTP Status 500 -
type Exception report
message
description The server encountered an internal error () that prevented it from fulfilling this request.
exception
org.springframework.web.util.NestedServletException: Request processing failed; nested exception is org.springframework.context.ApplicationContextException: Could not load FreeMarker template for URL [/index.ftl]; nested exception is java.io.FileNotFoundException: Template /index.ftl not found.
	org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:488)
	org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:431)
	javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
	javax.servlet.http.HttpServlet.service(HttpServlet.java:802)
root cause
	org.springframework.web.servlet.view.freemarker.FreeMarkerView.checkTemplate(FreeMarkerView.java:210)
	org.springframework.web.servlet.view.freemarker.FreeMarkerView.initApplicationContext(FreeMarkerView.java:161)
	org.springframework.context.support.ApplicationObjectSupport.setApplicationContext(ApplicationObjectSupport.java:73)
	org.springframework.context.support.ApplicationContextAwareProcessor.postProcessBeforeInitialization(ApplicationContextAwareProcessor.java:72)
	org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyBeanPostProcessorsBeforeInitialization(AbstractAutowireCapableBeanFactory.java:302)
	org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1163)
	org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:293)
	org.springframework.web.servlet.view.UrlBasedViewResolver.loadView(UrlBasedViewResolver.java:413)
	org.springframework.web.servlet.view.AbstractCachingViewResolver.createView(AbstractCachingViewResolver.java:159)
	org.springframework.web.servlet.view.UrlBasedViewResolver.createView(UrlBasedViewResolver.java:378)
	org.springframework.web.servlet.view.AbstractCachingViewResolver.resolveViewName(AbstractCachingViewResolver.java:78)
	org.springframework.web.servlet.DispatcherServlet.resolveViewName(DispatcherServlet.java:1179)
	org.springframework.web.servlet.DispatcherServlet.render(DispatcherServlet.java:1123)
	org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:879)
	org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:792)
	org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:476)
root cause
	freemarker.template.Configuration.getTemplate(Configuration.java:489)
[b].............................. <<<<< nog een hoop tussen[/b]
note The full stack trace of the root cause is available in the Apache Tomcat/5.5.9 logs.
Apache Tomcat/5.5.9
Dit is wat ik te zien krijg als ik mij inlog bij de telemeter en dit is al verscheidene dagen zo...
heeft nog iemand last van dit probleem?
JrCv
Bedankt: 10 keer
hier op kot werkt de telemeter site gewoon, is precies in een nieuw kleedje gestoken?
TomG
Uitgedeelde bedankjes: 472 keer
Bedankt: 106 keer
Ze zouden toch wat meer controlle mogen in hun JSP pagina's steken, zodat ie niet zo'n fout geeft om te melden dat er een bestand niet gevonden is...
Bedankt: 1985 keer
TomG schreef:Ze zouden toch wat meer controlle mogen in hun JSP pagina's steken, zodat ie niet zo'n fout geeft om te melden dat er een bestand niet gevonden is...
Het is ook maar een framework dat men gebruikt... veel controle zal men over bepaalde dingen dus ook niet hebben.
Terug naar “Telenet (Base, Chello, UPC)”
