'k had het geprobeerd met het Ontopia.net tooltje, maar die instalde ni direct fantastisch
Zie screenshot onderaan (catalina.bat zit wel degelijk in die folder)
& op Sourceforge.net, was er ook ni direct iets datk zag datk eventueel kon gebruiken om het online/cd-rom te zetten
( TM4J, TM4JScript, TMedit, Project Harpia )
Topic Map related :en.wikipedia.org schreef:Topic maps are an ISO standard for the representation and interchange of knowledge, with an emphasis on the findability of information. The standard is formally known as ISO/IEC 13250:2003.
A topic map can represent information using topics (representing any concept, from people, countries, and organizations to software modules, individual files, and events), associations (which represent the relationships between them), and occurrences (which represent relationships between topics and information resources relevant to them). They are thus similar to semantic networks and both concept and mind maps in many respects. In loose usage all those concepts are often used synonymously, though only topic maps are standardized.
Topics, associations, and occurrences can be typed, but the types must be defined by the creator of the topic maps, and is known as the ontology of the topic map. There are also additional features, such as merging and scope. The concept of merging and identity allows automated integration of topic maps from diverse sources into a coherent new topic map.
mintert.com
XML.com
topic-maps.org
links
startup.bat schreef:@echo off
if "%OS%" == "Windows_NT" setlocal
rem ---------------------------------------------------------------------------
rem Start script for the CATALINA Server
rem
rem $Id: startup.bat 302918 2004-05-27 18:25:11Z yoavs $
rem Guess CATALINA_HOME if not defined
set CURRENT_DIR=%cd%
if not "%CATALINA_HOME%" == "" goto gotHome
set CATALINA_HOME=%CURRENT_DIR%
if exist "%CATALINA_HOME%\bin\catalina.bat" goto okHome
cd ..
set CATALINA_HOME=%cd%
cd %CURRENT_DIR%
:gotHome
echo The CATALINA_HOME environment variable is not defined correctly
echo This environment variable is needed to run this program
goto end
:okHome
set EXECUTABLE=%CATALINA_HOME%\bin\catalina.bat
rem Check that target executable exists
if exist "%EXECUTABLE%" goto okExec
echo Cannot find %EXECUTABLE%
echo This file is needed to run this program
goto end
:okExec
rem Get remaining unshifted command line arguments and save them in the
set CMD_LINE_ARGS=
:setArgs
if ""%1""=="""" goto doneSetArgs
set CMD_LINE_ARGS=%CMD_LINE_ARGS% %1
shift
goto setArgs
:doneSetArgs
call "%EXECUTABLE%" start %CMD_LINE_ARGS%
:end
