Hoi, ik hergebruik even mijn post die ik deed op het TP-Link forum (vandaar het Engels, hopelijk is dit geen probleem?) :
Kan iemand me helpen aub? FYI: de Deco P9 beschikt over ingebouwde powerline functionaliteit.
My setup:
Inside the house: Modem ISP ---cat6_cable---> Deco P9 (configured as main in router mode) ---cat6_cable---> switch (to provide internet to wired devices)
Also spread in the house: 4 Deco M9 Plus units connected to the main Deco through WiFi
In the garden shed (about 30 meters from the house): 1 Deco P9
Problem in the garden shed there's a very, very weak WiFi signal, therefor opted for P9 as I was hoping to get this P9 to connect to the other using powerline.
This is not the case however! The P9 in the garden shed is always connected via WiFi but since the signal is very weak, the speed over there is terribly low.
When I put that P9 in the same room as the main P9, it even connects through WiFi, never via powerline. Help!!
All units have the latest firmware. I added those 2 P9 units recently, before I only had the M9's. But with an M9 as main it didn't work either, so I decided to promote a P9 as main hoping that was the solution.
Alvast bedankt!
nieuwe Deco P9 in tuinhuis connecteert steeds met main Deco over wifi ipv powerline
koswo
- Bedankt: 1 keer
Dat weet ik niet zeker. Maar toen ik een tijdje geleden probeerde met een klassieke (oudere) powerline adapter gebruikmakende van dezelfde stopcontacten als nu, werkte dat wel.
