Toch echt goede specs voor zijn prijs. Geen betere voor die prijs gevonden op Ali.
- 12-in-1 USB C Docking Station: Higher specs, more stable performance. 4K USB C Hub has 2 higher specification displayports and 1 HDMI, 1 RJ45, 10Gbps USB C and USB A 3.1, 1 SD and TF 4.0, 1 PD charging port, 3.5mm Mic/audio and 2 USB 2.0. Please make sure your laptop's USB C port is Thunderbolt 3/4 or supports DisplayPort mode, if you are not sure you can check with us.
- Triple Monitor Visual Experience: Under the DP 1.4 source, 4K@60Hz is supported when connecting ONE monitor via dual DP docking station. DP 1.2 supports 4K@30Hz only. Please note: macOS does not support extended mode.
- 10G Fast Data Transfer Dock: This USB C Docking Station comes with USB A 3.1 and USB C 3.1 with a max speed of 10Gbps to transfer large files and games in few second. There are also two USB 2.0 ports where you can connect a wireless mouse or keyboard. Please note: This USB C Adapter is not compatible with Logitech wireless devices.
- USB C to SD 4.0 and Gigabit Ethernet ports: This Dual DisplayPort USB C Hub has higher specification SD/TF card reader slots with reading speed up to 250Mb/s, transferring your photos more conveniently and both card slots can be read at the same time. Dongle also has stable network ports supports 10/100/ 1000BASE-T Lan networks, no need to worry about the instability of WiFi.
- 100W PD Charging and 3.5mm Mic/Audio Port: When Triple Display USB C Dock is connected to multiple devices, please connect the power supply to ensure enough power to work. PD port is compatible with up to 100W input and 87W (Safty) to charge your computer. Plug your headphones into the 3.5mm Mic/Audio Port and enjoy lossless music quality.
- What You Get: 1 * USB C Docking Station, 1 * manual. 24-hour service, 30 days free-use and 18 months technical-support. Please note: The DP port cannot be connected to other ports via the converter! For example HDMI or VGA!
