Ik heb zopas een Fiber connectie bij Edpnet besteld, gezien dit kan volgens hun support pages: https://www.edpnet.be/nl/support/bestel ... nding.html
Hiervoor heb ik een router met OpenWRT op geflashed. Heb hier een VLAN 10 opgezet, en de PPPoE crendentials ingegeven die mij doorgegeven zijn. Waardoor ik volgende network config verkrijg:
config interface 'loopback'
option ifname 'lo'
option proto 'static'
option ipaddr '127.0.0.1'
option netmask '255.0.0.0'
config globals 'globals'
option ula_prefix 'fde2:3015:4e4b::/48'
config interface 'lan'
option type 'bridge'
option ifname 'eth0.1'
option ipaddr '192.168.1.1'
option netmask '255.255.255.0'
option ip6assign '60'
config interface 'wan'
option ifname 'eth1.10'
option proto 'pppoe'
option username '***'
option password '***'
config interface 'wan6'
option proto 'dhcpv6'
config switch
option name 'switch0'
option reset '1'
option enable_vlan '1'
config switch_vlan
option device 'switch0'
option vlan '1'
option vid '1'
option ports '0 1 2 3 5t'
config switch_vlan
option vlan '10'
option vid '10'
option ports '4t 6t'Code: Selecteer alles
Sun Mar 7 15:34:00 2021 daemon.notice netifd: Interface 'wan' is setting up now
Sun Mar 7 15:34:00 2021 daemon.err insmod: module is already loaded - slhc
Sun Mar 7 15:34:00 2021 daemon.err insmod: module is already loaded - ppp_generic
Sun Mar 7 15:34:00 2021 daemon.err insmod: module is already loaded - pppox
Sun Mar 7 15:34:00 2021 daemon.err insmod: module is already loaded - pppoe
Sun Mar 7 15:34:00 2021 daemon.info pppd[10624]: Plugin rp-pppoe.so loaded.
Sun Mar 7 15:34:00 2021 daemon.info pppd[10624]: RP-PPPoE plugin version 3.8p compiled against pppd 2.4.7
Sun Mar 7 15:34:00 2021 daemon.notice pppd[10624]: pppd 2.4.7 started by root, uid 0
Sun Mar 7 15:34:00 2021 daemon.debug pppd[10624]: Send PPPOE Discovery V1T1 PADI session 0x0 length 12
Sun Mar 7 15:34:00 2021 daemon.debug pppd[10624]: dst ff:ff:ff:ff:ff:ff src 60:38:e0:c2:bf:38
Sun Mar 7 15:34:00 2021 daemon.debug pppd[10624]: [service-name] [host-uniq 80 29 00 00]
Sun Mar 7 15:34:05 2021 daemon.debug pppd[10624]: Send PPPOE Discovery V1T1 PADI session 0x0 length 12
Sun Mar 7 15:34:05 2021 daemon.debug pppd[10624]: dst ff:ff:ff:ff:ff:ff src 60:38:e0:c2:bf:38
Sun Mar 7 15:34:05 2021 daemon.debug pppd[10624]: [service-name] [host-uniq 80 29 00 00]
Sun Mar 7 15:34:10 2021 daemon.debug pppd[10624]: Send PPPOE Discovery V1T1 PADI session 0x0 length 12
Sun Mar 7 15:34:10 2021 daemon.debug pppd[10624]: dst ff:ff:ff:ff:ff:ff src 60:38:e0:c2:bf:38
Sun Mar 7 15:34:10 2021 daemon.debug pppd[10624]: [service-name] [host-uniq 80 29 00 00]
Sun Mar 7 15:34:15 2021 daemon.warn pppd[10624]: Timeout waiting for PADO packets
Sun Mar 7 15:34:15 2021 daemon.err pppd[10624]: Unable to complete PPPoE Discovery
Sun Mar 7 15:34:15 2021 daemon.info pppd[10624]: Exit.
Sun Mar 7 15:34:15 2021 daemon.notice netifd: Interface 'wan' is now downIs er iemand die een eigen router gebruikt voor FTTH, en misschien weet of ik iets verkeerd instelde, of hoe ik erachter kan komen of de lijn wel actief is?
