En zo ja, kan die persoon zijn wijsheid delen ?
Ik heb de setup aanwijzingen al 700 keer gelezen, alles wat ik kon bedenken geprobeerd... maar zonder resultaat.
![Embarassed :oops:](./images/smilies/icon_redface.gif)
Gewoon ter info : IE lijkt goed geconfigureerd en werkt...
05/24/2003 19:39:57.580: Proxy Server (v4.13 - Release) Starting with Services (0xFFFFFFCF)
05/24/2003 19:39:57.860: SMTP listen started (25)
05/24/2003 19:39:57.860: POP3 listen started (110)
05/24/2003 19:39:57.860: HTTP listen started (6588)
05/24/2003 19:39:57.910: SOCKS listen started (1080)
05/24/2003 19:40:17.850: 16387212 - POP3 Client connection accepted from 192.168.0.3
05/24/2003 19:40:18.010: 16387212 - POP3 Connection between local and remote established 'www.softhome.net:110'
05/24/2003 19:41:21.070: 16387212 - POP3 Local closed connection [read]
05/24/2003 19:41:21.070: 16387212 - POP3 Closing socket (1)
05/24/2003 19:41:21.120: 16387212 - POP3 Client connection accepted from 192.168.0.3
05/24/2003 19:41:21.180: 16387212 - POP3 Connection between local and remote established 'pop3pool1.skynet.be:110'
05/24/2003 19:41:23.930: 16387212 - POP3 Local closed connection [read]
05/24/2003 19:41:23.930: 16387212 - POP3 Closing socket (1)
05/24/2003 19:41:32.660: Proxy Server Stopping with Services (0xFFFFFFCF)
05/24/2003 19:41:32.770: Proxy SMTP listen shutdown requested
05/24/2003 19:41:32.770: SMTP closing threads... (0)
05/24/2003 19:41:32.770: SMTP listen stopped
05/24/2003 19:41:32.770: POP3 listen shutdown requested
05/24/2003 19:41:32.770: POP3 closing threads... (0)
05/24/2003 19:41:32.770: POP3 listen stopped
05/24/2003 19:41:32.770: Proxy HTTP listen shutdown requested
05/24/2003 19:41:32.770: HTTP closing threads... (0)
05/24/2003 19:41:32.770: HTTP listen stopped
05/24/2003 19:41:32.770: SOCKS listen shutdown requested
05/24/2003 19:41:32.770: SOCKS closing threads... (0)
05/24/2003 19:41:32.770: SOCKS listen stopped
05/24/2003 20:56:20.730: 16387212 - POP3 Client connection accepted from 192.168.0.3
05/24/2003 20:56:20.790: 16387212 - POP3 Connection between local and remote established 'pop3pool1.skynet.be:110'
05/24/2003 20:57:56.910: 16387212 - POP3 Local closed connection [read]
05/24/2003 20:57:56.910: 16387212 - POP3 Closing socket (1)
05/24/2003 20:59:54.780: 16387212 - POP3 Client connection accepted from 192.168.0.3
05/24/2003 20:59:54.830: 16387212 - POP3 Connection between local and remote established '195.238.3.116:110'
05/24/2003 21:00:59.920: 16387212 - POP3 Local closed connection [read]
05/24/2003 21:00:59.920: 16387212 - POP3 Closing socket (1)
Er is momenteel een probleem met onze inkomende mailservers [POP3]. Hierdoor kan u zowel moeilijkheden ondervinden om uw emails op te halen via uw emailprogramma, alsook via onze webmail pagina’s.
Opening: 16-05-2003 12:46:32
Status: open
Duur:
Gesloten:
The Oddity schreef:Cueboy,
hmm een nieuw tooltje, freeware?
