Deeper Connect Mini (Scam?) VPN
Uitgedeelde bedankjes: 457 keer
Bedankt: 313 keer
https://www.indiegogo.com/projects/worl ... for-life#/
Decentralized Private Network
World's 1st Decentralized VPN & Firewall- For life
Pay once; no subscriptions. Fast. Secure. Zero logging.
https://www.thetrendyblog.net/deeper-co ... -firewall/
https://bitcointalk.org/index.php?topic=5288352.0
https://linustechtips.com/topic/1218319 ... r-connect/
Iemand ervaring hiermee? Of scam?
Bedankt: 112 keer
Je gebruikt elkaars verbinding als VPN endpoint... als iemand dus illegale dingen doet kan dit mogelijks via jou verbinding naar buiten gaan.
Veel succes ermee als er plots één of andere instantie aan je deur staat !
Bedankt: 313 keer
"Dear backers,
We are currently finishing up shipping for all orders placed on and before April 30th and will start covering May orders starting on June 10th! Thank you all for your patience and support along the way.
Again, you can find our setup manual here: http://deepernetwork.cc/t/manual
Deeper Connect Nano is available on IGG soon!
We are also excited to announce that our latest model, Deeper Connect Nano, will be available for purchase on Indiegogo starting on June 10th!
The Nano carries all the same great features, with the same plug-and-play setup, in an even smaller and more portable size – the perfect companion for travels and business trips!
Deeper Connect Mini vs Deeper Connect Nano
New Pricing starting on June 10th
Deeper Connect Nano - $249 USD(16% off) (= 204 €)
Deeper Connect Mini - $269 USD (10% off)
Deeper Connect Mini + Deeper Connect Nano - $508 USD (15% off)
USA Shipping - $15 USD
Global Shipping - $25 USD (=21 €)
Thank you all for supporting Deeper Network!
Deeper Network Team
Ter info:
Bestelbedrag in euro’s € 263,16
Invoerrechten bedrag € 11,05
BTW bedrag € 57,58
Totale bijkomende kosten € 80,64
Totaalbedrag € 343,79 (+30,64%)
Denk dat dit toestel betere investering is.
https://www.appletips.nl/de-snelste-vpn ... -de-markt/
Sinna
Twitter: KrSi78
Uitgedeelde bedankjes: 208 keer
Bedankt: 152 keer
URL in voorgaand bericht klopt niet en moet https://www.appletips.nl/de-snelste-vpn-router-op-de-markt/ zijn (outer > router).
Bedankt: 112 keer
satsurfer schreef:Denk dat dit toestel betere investering is.
Totaal geen specificaties over hoe het werkt... en het dan een betere investering noemen :eek:
Bedankt: 313 keer
Bedankt: 313 keer
Bedankt: 313 keer
Bedankt: 341 keer
Laten we zeggen dat dit soort toestel er bij mij niet zou inkomen zonder veel meer info.
Waar zit de processing? Welke toegang hebben ze? Welk type hardware? Om ids/ips te doen op een stream van 1gbps moet je toch al iewat deftige hardware hebben.
Welk os? Hoe lang updates? Etc...
Bedankt: 446 keer
de firewalla en de deeper connect zijn niet aan elkaar gerelateerd.
devilkin schreef: Waar zit de processing? Welke toegang hebben ze? Welk type hardware?...
hier is er eentje via indiegogo besteld, moet nog aankomen (update gehad dat de shipping begonnen is laatst, dus verwacht het wel eerdaags in huis te hebben).
natuurlijk niet vrij aan mijn internet, maar op aparte vlan etc.
ik wil hem dan ook niet als client gebruiken, maar als deel van het netwerk.
ze werken namelijk volgens het concept: jij neemt zo een ding in huis, jij deelt dat aan degene die het willen gebruiken (en offert een deel van je internet op aan het deeper netwerk) - en krijgt daarvoor hun token in ruil.
op die manier kost het netwerk zelf hun eigenlijk niet veel (want decentralized door degenen die de coin daarvoor krijgen, via proof of credit), hou je het in stand zolang er mensen de coin willen (kijk naar de andere crypto), en kan je een product aanbieden dat dus doet wat ze zeggen.
het grootste risico dat ik erin zie, is dat anderen misbruik zouden maken van die vpn en dat je dan moet gaan kijken waar de aansprakelijkheid komt te liggen (kijk naar bv tor endpoints)
wat betreft meer info: hier heb je hun onepager: https://www.deeper.network/onepager en hier de whitepaper: https://www.deeper.network/whitepaper_e ... 0309023662
mij lijkt het een best haalbaar concept, decentralized vpn via proof of credit mining: nuttig, gespreide kost, schaalbaar, en weinig impact op je elektra rekening in vergelijking met de traditionele mining.
ik ging of hierop springen of op helium... maar de kost voor deeper is een pak lager en ik heb niet de ideale locatie voor een helium miner, dus was de keus vrij snel gemaakt.
Bedankt: 386 keer
Splitter schreef:het grootste risico dat ik erin zie, is dat anderen misbruik zouden maken van die vpn en dat je dan moet gaan kijken waar de aansprakelijkheid komt te liggen (kijk naar bv tor endpoints)
Hoe zit dat vandaag de dag? Ik las in het weekend deze waaruit blijkt dat in de VS, tor endpoints en IP's horende bij VPN's niet gebruikt konden worden als "probable cause" om een huiszoeking uit te voeren, toch niet zonder beter te stofferen. Residentiële IP's daarentegen wel (zolang ze dus geen deel uitmaken van anonymizers).
Bij ons zijn vrijheden minder gewaarborgd en zijn procureurs ook veel minder op de hoogte van technologie waardoor ze makkelijker misleid kunnen worden obv een simpel IP-adres. Maar wat is de stand van de wet vandaag de dag?
Bedankt: 446 keer
goede vraag, en daar wil ik het antwoord ook wel op weten... maar wetgeving is niet mijn forté...
dus als er hier toevallig een jurist rondloopt, help us out :)
