BBox2 low VSDL Profile 8d 14/1 Training 35db Att:9
leondinant
For unknown reason moved from 38/8 to 14/1 speed
several days ago. Contacted Proximus many times but seems technical support does not know a lot about VSDL2.
Reinstall and clean cables and go from Training/Att 23/13 to 35/9. Seems signal noise rate is excellent but
14/1 is below minimum required (required minimum 2.8Mbps outgoing traffic).
BBOX2 Sagem
 	VDSL Version 	Firmware-VTU-R:9.5.7.13IK105012 Time Nov 18 2014, 20:09:20
 	Runtime Code Version 	60R10N-60A09Q  	Hardware version: 1
 VDSL2Tool 2.3 - http://hierzo.net/ *
                        download          upload
Line:                  14536 kbps        1056 kbps
Modem max:             58480 kbps        n/a Estimated!
Calculated max:        48015 kbps         10060 kbps Estimated!
Profile:               8d
Line length:           78 m Estimated!
Training margin:       35.4 dB
Attenuation:           9.1 dB
Bedankt: 3720 keer
Any reason why you are still using a B-box2 :-( ?
Do yourself a favour and go and get a B-box3 :wink: .
Your speed will increase to at least 70/20 as a start, with further increased to potentially 100/35 :-) .
Alternatively, try to initiate a line test (TBF):
  • call 0800 22424 (from any Belgian fixed or mobile phone).
  • if requested, enetr your 9-digit customer number.
  • then enter the line number of your VDSL2 line (not necessarily the phone number of your fixed phone line).
  • disregard all further messages, but wait until the end of the announcements before hanging up.
After a few minutes, your line will be disconnected, and you will be allocated the proper line profile (depending distance).
see table: https://userbase.be/forum/viewtopic.php?f=24&t=51035
Then DLM will monitoring the line, and eventually increase further…
[EDIT]
In the (rare) event that you are not connected to a vectored ROP you still should sync with a 17a profile (in stead of 8d).
In that case, your base speed (zone 1) should be 30/10 (starting), with potential increases up tot 70/10 :-) .
