Voordien
Downstream current bit rate: 99.999 kbps
Upstream current bit rate: 39.999 kbps
Downstream max bit rate: 136.578 kbps
Upstream max bit rate: 45.652 kbps
Downstream attenuation: 13,2 dB
Downstream noise margin: 19,2 dB
Upstream noise margin: 9,0 dB
Vectoring down: yes
Vectoring up: yes
Modem vectoring compatible: yes
ROP vectoring compatible: yes
DSL standard: VDSL2 Annex B
DSL profile: 17a
Estimated distance: 288 m
Proximus profile name: 100/40
Proximus DLM profile: yes
Proximus repair profile: no
Upstream current bit rate: 35.000 kbps
Downstream max bit rate: 136.581 kbps
Upstream max bit rate: 43.660 kbps
Downstream attenuation: 13,1 dB
Upstream noise margin: 11,4 dB
Vectoring down: yes
Vectoring up: yes
DSL profile: 17a
Proximus profile name: 100/35
