3x APC Switched Rack Power Distribution Units
fren
* 2x APC AP8953: Rack PDU 2G, Switched, ZeroU, 32A, 230V, (21) C13 & (3) C19
Output
Overload Protection Yes
Maximum Total Current Draw 32
Output Connections
(3) IEC 320 C19 (Battery Backup)
(21) IEC 320 C13 (Battery Backup)
Input
Nominal Input Voltage 200V , 208V , 230V
Input frequency 50/60 Hz
Input Connections IEC 309 32A 2P+E
Cord Length 3.05meters
Acceptable Input Voltage 220-240VAC
Number of Power Cords 1
Maximum Input Current 32A
Maximum Line Current 32A
Physical
Maximum Height 1829mm / 182.9CM
Maximum Width 56mm / 5.6CM
Maximum Depth 46mm / 4.6CM
Net Weight 7.59KG
Color Black
Meer informatie
http://www.apc.com/shop/et/en/products/ ... 9/P-AP8953
Meer fotos
Meeneemprijs 400eur/stuk
Minimumprijs: 200eur/stuk
* 1x APC AP7954: Rack PDU, Switched, Zero U,16A,230V,(21)C13&(3)C19, IEC309, 10' Cord
Output
Nominal Output Voltage 230V
Maximum Total Current Draw 16
Output Connections
Input
Input frequency 47 - 63 Hz
Input Connections IEC 309 16A 2P+E
Load Capacity 3680VA
Maximum Input Current 16A
Physical
Maximum Height 1619mm / 161.9CM
Maximum Depth 44mm / 4.4CM
Net Weight 5.92KG
Color Black
Meer informatie
http://www.apc.com/shop/my/en/products/ ... d/P-AP7954
Meer fotos
Meeneemprijs: 200eur
Minimumprijs: 100eur
Verkoopsvoorwaarden :
- Objectlocatie: Sint-Amandsberg (Gent).
- Per 5,00 EUR of hoger opbieden.
- Winnaar: 48u na laatste bod.
Betalingsvoorwaarden :
- Vooraf betaling per overschrijving, PayPal (+4,00%) of cash bij afhaling.
Transportvoorwaarden :
- Kan opgehaald worden te Sint-Amandsberg (Gent).
cybersurfr
Bedankt: 21 keer
€100 voor APC AP7954
fren
Thanks cybersurfr, ik contacteer je na het verlopen van de 48u.
