Zit al een tijdje bij edpnet , en in 2015 een profielverhoging gekregen na het openen van een ticket.
Ik zat toen op een 70/20 profiel. De test reultaten zie je hieronder.
action item id 3359867
customer name EDPNET status Completed
service identifier 101837268546 creation date 11/09/2015 09:09
domain WBA type Pre-Trouble Shooting
+more details...
result
-details...
-diagnose result
diagnose result
The measurements indicate no fault. If you decide to create a repair ticket, a field intervention will be created. / A DLM profile is active. Before the repair ticket creation, be sure that this profile is not the reason of your problem (instability, quality issue, ...). If you suspect it, first launch a TBF and wait for the result.
-copper analysis
copper analysis
CABLELENGTH = 2340 m
AE_Insulation = 10 MOHMS
BE_Insulation = 10 MOHMS
AB_Insulation = 10 MOHMS
BA_Insulation = 10 MOHMS
AC_Insulation = 10 MOHMS
BC_Insulation = 1 MOHMS
AE_Capacitance = 190 nF
BE_Capacitance = 188 nF
AB_CAPACITANCE = 479 nF
BA_Capacitance = 479 nF
CableCapacitance = 105 nF
MutualCapacitance = 750 nF
Copper test type = 4TEL
-synchro analysis
synchro analysis
LineProfile = vdsl2_DLM_Dyn6M_v1
PortState = UNLOCK
SynchroState = SYNCH
DslamName = h03bev00002
DownstreamAttenuation = 16.4
UpstreamAttenuation = 24.7
DownstreamBitRate = 70001.0
UpstreamBitRate = 10064.0
DownstreamNoiseMargin = 12.7
UpstreamNoiseMargin = 14.4
VLAN10_AgentCircuitID = *H03BEV00002 eth 6/2/01/39:10
VLAN10_PBIT = p0
VLAN10_OALID = 001063450
VLAN10_SSID = 000000001991025
VLAN10_VLAN_OLO_S-tag = 203
-LED indicator
LED indicator
Modem status = Modem info not available
+modem information
-vectoring information
Firmware version = 1.100.132.9 A6
ROP vectoring level = Active
Maintenance mode = N
Fallback mode = NORMAL
-DLM information
DLM information
Eligibility flag = Y
Zone = DLMzone72
Current overrule DS speed =
Current overrule INP = 33.0
Vorige maand heb ik Voip aangevraagd , en mijn profiel veranderde naar 20/2. Na het opnieuw openen van een ticket werd er een lijntest uitgevoerd. Waarna ik op 50/10 kwam. Resultaat van deze lijntest hieronder.
copper analysis
CABLELENGTH = 362 m
AE_Insulation = 10 MOhm
BE_Insulation = 10 MOhm
AB_Insulation = 6872 kOhm
BA_Insulation = 6872 kOhm
AE_Capacitance = 29 nF
BE_Capacitance = 29 nF
AB_CAPACITANCE = 686 nF
Copper test type = AGW
-synchro analysis
synchro analysis
LineProfile = vdsl2_DLM_20M6M_v1
PortState = UNLOCK
DownstreamAttenuation = 15.9
UpstreamAttenuation = 25.7
DownstreamBitRate = 50200.0
DownstreamNoiseMargin = 10.6
UpstreamNoiseMargin = 13.2
VLAN10_PBIT = p0
+PM counters
+LED indicator
+modem information
Firmware version = 1.100.133.21 A6
+LAN Port entries
-DLM information
DLM information
Date Next eval.
2016-12-11T14:57:25 2016-12-13T14:57:25
2016-12-05T17:50:06 2016-12-06T17:50:06
Eligibility flag = F
Zone = DLMzone12
Activation flag = AUTO
Current overrule DS speed = 50200
Nu is mijn vraag, hoe komt het dat de cable length van 2340 m naar 362 m is gegaan ? Wil dit zeggen dat ik nu op een dichtere ROP zit ?
Maar dan zou ik toch een hogere snelheid moeten kunnen verkrijgen ? Of zie ik dit verkeerd ?
Is er hier iemand die mij hierover de nodige uitleg kan aan geven.
Alvast bedankt , en al een fijn nieuw jaar 2017 !
Lijntest met 2 verschillende resultaten ??
- Bedankt: 11 keer
Copper test type is verschillend.
Telefoonsignaal komt niet meer vanuit de LEX maar vanuit ROP via AGW.
Voor het VDSL2 signaal maakt dit geen verschil.
Je woont nog altijd ongeveer 362 meter van ROP.
- OBiWaN007
- Bedankt: 24 keer
Ik werk voor PXM, stuur in PM even je lijnnummer en ik zal zien wat ik voor je kan betekenen
opgelet, ik bedoel effectief je LIJNnummer en dus NIET je VOIPnummer.
mocht je deze niet kennne, je lijnnummer kan je makkelijk te weten komen door op je
lijn rechtsteeks (dus inpluggen op de NTP en NIET op de VOIP poort van je modem)
een telefoontoestel te hangen en 1924 bellen dan leest een computerstem je effectieve lijnnummer.
Internet: 1x EDPNet Fiber XL 500/100 mbit met FritzBox 7490 --> firmware 07.27
Telephony: VoIP in : EDPnet & VoIP uit : MegaVoIP + GSM: Proximus Mobilus Unlimited 5G
TV: 1x Fiber Proximus 1000/100 mbit met Bbox3v+ --> Decoder v7 & 79" UHD TV + AllSports
Storage: 1x Netgear ReadyNAS 314 @ 25TB & 1x Synology NAS 916+ @ 35TB --> Raid 5
![Afbeelding](https://www.speedtest.net/result/9589407904.png)
