Als ik m'n interface probeer te activeren krijg ik steeds "TLS failed" ?
Met de OVPN client op Windows lukt de connectie prima (al zie ik dat INSECURE toch ook niet graag staan);
Misschien is dit ook het probleem met de Mikrotik aangezie ik daar enkel AES ciphers kan opgeven met minstens 128 bits of blowfish.Fri Dec 02 18:26:27 2016 OpenVPN 2.3.13 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [PKCS11] [IPv6] built on Nov 3 2016
Fri Dec 02 18:26:27 2016 Windows version 6.2 (Windows 8 or greater) 64bit
Fri Dec 02 18:26:27 2016 library versions: OpenSSL 1.0.1u 22 Sep 2016, LZO 2.09
Enter Management Password:
Fri Dec 02 18:26:33 2016 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
Fri Dec 02 18:26:33 2016 Attempting to establish TCP connection with [AF_INET]serverip:1194 [nonblock]
Fri Dec 02 18:26:34 2016 TCP connection established with [AF_INET]serverip:1194
Fri Dec 02 18:26:34 2016 TCPv4_CLIENT link local: [undef]
Fri Dec 02 18:26:34 2016 TCPv4_CLIENT link remote: [AF_INET]serverip:1194
Fri Dec 02 18:26:35 2016 WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
Fri Dec 02 18:26:37 2016 WARNING: INSECURE cipher with block size less than 128 bit (64 bit). This allows attacks like SWEET32. Mitigate by using a --cipher with a larger block size (e.g. AES-256-CBC).
Fri Dec 02 18:26:37 2016 [synology.com] Peer Connection Initiated with [AF_INET]serverip:1194
Fri Dec 02 18:26:39 2016 do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
Fri Dec 02 18:26:39 2016 open_tun, tt->ipv6=0
Fri Dec 02 18:26:39 2016 TAP-WIN32 device [Ethernet 3] opened: \\.\Global\{BF962FDC-42E5-4616-B1C3-9F80438C8602}.tap
Fri Dec 02 18:26:39 2016 Notified TAP-Windows driver to set a DHCP IP/netmask of 192.168.15.6/255.255.255.252 on interface {BF962FDC-42E5-4616-B1C3-9F80438C8602} [DHCP-serv: 192.168.15.5, lease-time: 31536000]
Fri Dec 02 18:26:39 2016 Successful ARP Flush on interface [88] {BF962FDC-42E5-4616-B1C3-9F80438C8602}
Fri Dec 02 18:26:45 2016 Initialization Sequence Completed
