Nieuw in verpakking, nooit gebruikt.
Type: Iso-Tech ICM133R
Startprijs: €25
Meeneemprijs: €50
Termijnen: toewijzing 48H na laatste bod of bij bieden meeneemprijs
Locatie: Gent (Afhaling, of verzending met bpost (ten koste van koper!)
Fotos: zie bijlages bij deze post
Specs:
ICM133R 1000A ac,True-rms reading
1000A ac current measurement
750Vac / 1000Vdc voltage measurement
Large 51mm dia. conductor jaw capacity
4000 count backlit digital display with analogue bargraph
True RMS reading on AC mode
Resistance & continuity beeper <30Ω
Display Hold & Min Max Function
10ms Peak Hold on ac A & ac V
Frequency Counter
Auto Power Off (30 minutes)
Separate battery compartment
600V circuit protection
Complies with EN61010 CAT. III 600V Safety Standard for industrial applications
Rugged construction with flame retardant, high impact plastic
ac voltage
Ranges 400V & 750V
Resolution 0.1V & 1V
Basic Accuracy ±(1.0% rdg+ 5d)
50 to 500Hz
dc voltage
Ranges 400V & 1000V
Basic Accuracy ±(0.7% rdg+ 2d)
ac current
Ranges 400A & 1000A
Resolution 0.1A & 1A
Basic Accuracy ±(1.9% rdg + 5d) 50-60Hz
Resistance
Range 400Ω
Resolution 0.1Ω
Basic Accuracy ±(1.0% rdg+ 3d)
Frequency counter
Ranges 4kHz & 10kHz
Resolution 1Hz & 10Hz
Basic Accuracy ±(0.1% + 2d) @5V rms max
Size (WxHxD) and Weight 90 x 275 x 51mm, 420g
Supplied with
Test leads, carry case, instruction leaflet and 9V PP3 alkaline battery.
