Sinds een uurtje ligt onze lijn volledig op zijn gat...
Internetverbinding niet of zeer traag
TV valt uit, netflix valt uit...
Speedtest gedaan
Ping: 190
Upload 2.71
Is dit lokaal of zijn er nog Gentenaars met een S(lak)-DSL?
Problemen in het Gentse?
warpozio
- Bedankt: 18 keer
ok modem reset, en pingske gelanceerd naar ip van modem en dat ziet er niet goed uit.
C:\Users\Warpozio>ping 192.168.1.1 -t
Pinging 192.168.1.1 with 32 bytes of data:
Reply from 192.168.1.1: bytes=32 time=128ms TTL=64
Request timed out.
Reply from 192.168.1.1: bytes=32 time=33ms TTL=64
Reply from 192.168.1.1: bytes=32 time=240ms TTL=64
Reply from 192.168.1.1: bytes=32 time=89ms TTL=64
Reply from 192.168.1.1: bytes=32 time=224ms TTL=64
Request timed out.
Request timed out.
Reply from 192.168.1.4: Destination host unreachable.
Request timed out.
Reply from 192.168.1.1: bytes=32 time=194ms TTL=64
Reply from 192.168.1.1: bytes=32 time=28ms TTL=64
Reply from 192.168.1.1: bytes=32 time=131ms TTL=64
Reply from 192.168.1.1: bytes=32 time=30ms TTL=64
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 192.168.1.1: bytes=32 time=88ms TTL=64
Reply from 192.168.1.1: bytes=32 time=288ms TTL=64
Reply from 192.168.1.1: bytes=32 time=117ms TTL=64
Reply from 192.168.1.1: bytes=32 time=112ms TTL=64
Reply from 192.168.1.1: bytes=32 time=12ms TTL=64
Reply from 192.168.1.1: bytes=32 time=155ms TTL=64
Reply from 192.168.1.1: bytes=32 time=62ms TTL=64
Request timed out.
Request timed out.
Request timed out.
Reply from 192.168.1.1: bytes=32 time=101ms TTL=64
Reply from 192.168.1.1: bytes=32 time=22ms TTL=64
Reply from 192.168.1.1: bytes=32 time=122ms TTL=64
Reply from 192.168.1.1: bytes=32 time=18ms TTL=64
Reply from 192.168.1.1: bytes=32 time=140ms TTL=64
Reply from 192.168.1.1: bytes=32 time=19ms TTL=64
Reply from 192.168.1.1: bytes=32 time=24ms TTL=64
Reply from 192.168.1.1: bytes=32 time=71ms TTL=64
Reply from 192.168.1.1: bytes=32 time=29ms TTL=64
Ping statistics for 192.168.1.1:
Packets: Sent = 38, Received = 26, Lost = 12 (31% loss),
Approximate round trip times in milli-seconds:
Minimum = 12ms, Maximum = 288ms, Average = 99ms
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
warpozio
- Bedankt: 18 keer
vreet raar
tweede keer reset nu vanavond
TV: weg
ene laptop: geen internet, pingen naar modem geeft PING: transmit failed. General failure.
andere laptop (deze) heb ik gewoon verbinding.... zij het vreet traag
speedtest geeft time out fouten
TV: weg
pyro85
- Bedankt: 126 keer
Hier geen problemen gehad in het Gentse.
Lijkt me eerder een probleem met de bbox zelf als je al niet kan pingen naar 192.168.1.1.
Probeer eens een factory reset (knopje achteraan), als het daarna nog niet in orde is kan je de helpdesk bellen en een ruilnummer aanvragen voor een nieuwe bbox.
- lacer
- Bedankt: 193 keer
Gisterenavond zo tussen 20h30 en 21h30 leek het erop dat ik heel veel moeite had om een film te streamen met Kodi. Enkel Youtube kijken viel nog mee.
Verder geen metingen gedaan of zo, maar later in de avond leek het hersteld.
@ Warpozio woon jij in het centrum van Gent ?
Maar inderdaad, als je een slechte ping hebt naar je modem scheelt er iets ermee.
Laatst gewijzigd door lacer 22 aug 2015, 11:36, in totaal 1 gewijzigd.
EdpNet XL 99/35 Mbps
