Heeft iemand ervaring met deze?
https://www.duosecurity.com/duo-push
What is Duo Push?
Duo Push is the easiest form of secondary authentication. Once Duo Mobile is installed and activated on your phone, you can authenticate with just one tap of a button.
Duo Push doesn’t slow you down while you’re trying to access your applications, and doesn’t require any extra hardware tokens - only your own personal phone.
How do I use it?
Make sure you’re signed up for a Duo account, and you’ve downloaded Duo Mobile to your device.
Log into your application with your username and password.
On the Two-Factor Authentication prompt, select Duo Push and press Log in.
A push notification will be sent to your device within seconds. Press Approve.
You’re in!
Duo Push
- Bedankt: 253 keer
GSM: Hey Telecom L 50 GB
