Ik had in de Belgacom thread een gebruiker gezien die problemen in zone 016 meldde, en ik stelde toevallig ook 2 niet voorziene disconnects vast bij mij (ook zone 016), zie http://userbase.be/forum/viewtopic.php? ... 52#p567825
Na maanden op een stabiele 70/6 te zitten, nu dus plots teruggevallen naar 30/6.
Modem is een SAGEM, met vectoring friendly firmware 6LR10J-6LA07C .VDSL2 Tool zegt volgende:
__________________________________________________
| VDSL2Tool 3.0 | © Arno Raps | http://hierzo.net/ |
\__________________________________________________/
downstream upstream
Line: 30040 kbps 6064 kbps
Max: 78709 kbps 16491 kbps
Profile: 17a
Distance: 51 m
Training: 28,8 dB
Attenuation: 8,4 dB
# vdsl pstatex
Extended Port Status
Bme: 1 Port: 1
Downstream line rate: 34528 kbps
Upstream line rate: 8064 kbps
Bearer0 Downstream payload rate: 0 kbps
Bearer1 Downstream payload rate: 30040 kbps
Bearer0 Upstream payload rate: 0 kbps
Bearer1 Upstream payload rate: 6064 kbps
Downstream attainable payload rate: 95864 kbps
Downstream attainable line rate: 115112 kbps
Downstream Training Margin: 28.8 dB
Downstream Line Protection (Bearer1 Path): 1.0 DMT Symbols
Upstream Line Protection (Bearer1 Path): 1.0 DMT Symbols
Near-end ITU Vendor Id: 0xb500494b4e530200
Far-end ITU Vendor Id: 0xb5004244434da45f
Downstream delay: 7.5 ms
Upstream delay: 4.0 ms
Tx total power -20.7 dbm
FE Tx total power 12.6 dbm
VDSL Estimated Loop Length : 505 ft
G.Hs Estimated Near End Loop Length : 0 ft
G.Hs Estimated Far End Loop Length :0 ft
Current framing mode: 0x10
Bandplan Type...........: 0
No. of Upstream Bands...: 2
No. of Downstream Bands.: 3
Line Type: 0x04000000
