4x Barcode scanners Datalogic QUICKSCAN QD2100 (recht of gek
shiseido
Bedankt: 18 keer
Waren reeds (tweedehands) aangekocht voor de toekomstige winkel van mijn vrouw, maar hebben echter beslist op ander systeem over te stappen.
Bij deze dus "for sale"!
Scanners verkeren in nieuwstaat, zijn voorzien van USB-connectie & hebben allemaal een bijhorende stand.
Supersnelle toestellen met groene dot projectie bij positieve scan.
Toestellen zijn gereset naar de factory settings ahv van de Datalogic Alladin software.
2 hebben een krulkabel, 2 een rechte -- waarvan 1 met optionele voeding.
Pics :
1x QuickScan I QD2110 met Datalogic STD-QD20-BK stand & Cable, USB, Type A, Straight, 6 Feet, CAB-426E (type n° 90A052044)
2x QuickScan I QD2110 met Datalogic STD-QD20-BK stand & Cable, USB, Type A, Coiled, 9 Feet, CAB-424E (type n° 90A052043)
1x QuickScan I QD2110 met Datalogic STD-QD20-BK stand & Cable, USB, Type A, Coiled, 9 Feet, CAB-412 Optional Power (type n° 90A051922)
"The QuickScan reader series is Datalogic Scanning’s value line of general purpose handheld data collection products. The QuickScan I QD2100 linear imaging reader is an entry level product that is perfect for use in retail and office environments plus activities associated with couriers and postal services.
The QD2100 is small, lightweight and its ergonomic design is comfortable to use during daily operations. It offers snappy reading performance especially on hard to read bar codes and is capable of reading a wide range of symbologies including the majority of 1D codes plus GS1 DataBar™ linear codes. The QD2100 reader features Datalogic’s exclusive patented ‘Green Spot’ for good read feedback directly on the code. When in Stand Mode, the Green Spot remains on to show the operator where to position the code for quick and intuitive reading.
Like the QuickScan L reader, the QD2100 has been designed with durability in mind. One of the most vulnerable features of any scanner is damage to the scan window. When such incidents happen, the scanner may have to be replaced. The QD2100 was specifically designed so that a replacement window pack can be ordered to replace damaged or scratched windows without having to send the scanner away for repairs. This helps to reduce the total cost of ownership during the life of the scanner and helps to ensure that it is always available for use.
The QD2100 is available with two multi-interface options: RS-232 / IBM 46XX / USB and RS-232 / USB / Keyboard Wedge / Wand and includes various packaging options so that it can be ordered as the scanner only or as a kit equipped with a scanner, cable and stand to facilitate hand-free reading options. The Datalogic Aladdin™ configuration program provides user-friendly features that simplify the start-up procedure, even for inexperienced users."
Alle info/specs/drivers ivm scanner : http://www.datalogic.com/eng/products/a ... d-164.html
Bieden vanaf 15 euro excl verzending met opbod van 5 euro.
Verzending via Kiala, B-post of ophaling te Lier.
Afsluiting 48u na het hoogste bod.
Happy bidding!
Cheers,
S.
cloink
Twitter: cloink
Bedankt: 152 keer
15€ voor één van de twee type 90A052043.
ooh. shiny.
helmuteke
Bedankt: 27 keer
15€ voor de andere 90A052043
Bedankt: 1450 keer
Hoe werkt zoiets? Is er een programmaatje waar je de barcodes mee maakt en die je dan afdrukt? Deze herkennen de prijs die daar aan hangt dan?
shiseido
Bedankt: 18 keer
Er bestaan idd progs om zelf barcodes te genereren, maar vaak worden de originele codes van producten gebruikt die in je eigen systeem aan een bepaalde prijs gekoppeld zijn.
De codes bevatten op zich als dusdanig geen bedrag -- of je moest bv bij de Inditex of Bestseller keten terecht komen die zelf voor al hun winkels de codes bepalen voor verschillende markten -- cfr. Zara (inditex) met o.a. Mexico & Spanje die cheaper zijn dan de rest van de wereld, Bestseller zal dan weer in Denemarken & Zweden het goedkoopst zijn -- net zoals Jack & Jones, Selected,..
De makkelijkst te gebruiken is Code 39 of Code 128. De echte EAN codes bepaalden (dacht ik) met bepaalde cijfers ook het land van herkomst etc.
Maar met deze readers kan je evt ook voor het organiseren van je eigen collecties gebruiken -- bv :
- gebruik van boek of cd-collectie soft, die je aan de hand van deze codes instant kan laten koppelen aan reeds aangevulde fiches op het WWW of via open DB's, zo via IOS of android app bekijken wat he al in stock hebt..
- opzoeken van producten online om zo de goedkoopste prijs te vinden
- aanmaak van eigen codes, en in te scannen bij uitleen & ontvangst van bv. boeken
Met de meeste Dymo apparaten kan je zo een resem opeenvolgende codes afdrukken, en gebruiken naar believen.
Anders eveneens online of via progs zoals word & excel te genereren..
murdock447
Bedankt: 26 keer
15Euro voor de versie met de niet gekrulde kabel (90A052044)
shiseido
Bedankt: 18 keer
For the record :
1x QuickScan I QD2110 met 90A052043 (gekrulde kabel)
--> @ cloink -- 15 euro geboden
--> @ helmuteke -- 15 euro geboden
1x QuickScan I QD2110 met 90A052044 (rechte kabel)
--> @ murdock447 -- 15 euro geboden
Nog 1x QuickScan I QD2110 met 90A051922 (rechte kabel met opt. pwr) à 15 euro
Als de power niet nodig is, waarom zou je dan er een powerkabel aan koppelen? (puur om te weten wat het nut van de optie is)
Indien perfecte werking zonder powerkabel, 15 euro geboden.
shiseido
Bedankt: 18 keer
MClaeys, scanner werkt puuurfect zonder de externe power.
Heb even liggen zoeken wat de functie er dan wel van kan zijn, maar is zo goed als niks over te vinden...
Genoteerd als dusdanig.
4 @ 15 euro :)
Misschien voor USB-1 poorten die niet genoeg power geven :) bod staat dus :)
shiseido
Bedankt: 18 keer
--> @ cloink -- 15 euro geboden -- vervalt vandaag 29 juli om 14:51
--> @ helmuteke -- 15 euro geboden -- vervalt vandaag 29 juli om 06:30
--> @ murdock447 -- 15 euro geboden -- vervalt morgen 30 juli om 16:30
1x QuickScan I QD2110 met 90A051922 (gekrulde kabel)
--> @ MClaeys -- 15 euro geboden -- vervalt morgen 30 juli om 18:47
shiseido
Bedankt: 18 keer
* Uren van helmuteke & murdock447 zijn verkeerdelijk geswitched..
helmuteke
Bedankt: 27 keer
shiseido schreef:* Uren van helmuteke & murdock447 zijn verkeerdelijk geswitched..
verval ik niet deze middag om 16.30 ???
bod geplaatst op 27/07 om 16.30 ??
helmuteke
Bedankt: 27 keer
NVM , mijn fout :-)
gezien
jgijsen
Bedankt: 5 keer
20 euro voor 1x QuickScan I QD2110 met 90A052043 (gekrulde kabel)
cloink
Twitter: cloink
Bedankt: 152 keer
Dat is dan toch al niet die van mij, daarvoor was ie 2 minuten te laat! :mrgreen:
Ik PB je m'n gegevens...
ooh. shiny.
helmuteke
Bedankt: 27 keer
Met welk uur wordt er rekening gehouden ??
klok forum loopt uur achter en het overzicht van Shisedo toont deze uren
shiseido schreef:1x QuickScan I QD2110 met 90A052043 (gekrulde kabel)
helmuteke
Bedankt: 27 keer
Nu is het 14.26 voor mij (of 27)
helmuteke
Bedankt: 27 keer
Dus op welke heeft jgijsen nu geboden ???
cloink
Twitter: cloink
Bedankt: 152 keer
lol, cluserfuck. :lol:
ooh. shiny.
helmuteke
Bedankt: 27 keer
cloink schreef:lol, cluserfuck. :lol:
moest ik da woord gaan opzoeken , idd een probleem dus
jgijsen
Bedankt: 5 keer
Ik zal het probleem oplossen.
20 euro voor beide QuickScan I QD2110 met 90A052043 (gekrulde kabel)
helmuteke
Bedankt: 27 keer
25 €uro voor 1 x QuickScan I QD2110 met 90A052043 (gekrulde kabel)
cloink
Twitter: cloink
Bedankt: 152 keer
jgijsen schreef:Ik zal het probleem oplossen.
Nee nee, daar gaat het niet om, het gaat over de eindtijd. Als we de tijden van de TS respecteren, is er nog slechts 1 te koop.
Soit, ik hoor het wel!
ooh. shiny.
jgijsen
Bedankt: 5 keer
Jouw bod: door cloink op 27 jul 2014, 14:51
Voorwaarden: Afsluiting 48u na het hoogste bod.
Mijn bod: door jgijsen op 29 jul 2014, 13:53
cloink
Twitter: cloink
Bedankt: 152 keer
Ja, alleen kloppen die tijden niet. Uw bod was eigenlijk om 14:53 echte tijd...
ooh. shiny.
Mr.T
Bedankt: 13 keer
En jouw eerste bod was dan eigenlijk om 15:51.
Ach TS zal wel een beslissing nemen, maar volgens mij is het bod van jgijsen wel geldig.
shiseido
Bedankt: 18 keer
Damn -- dit wordt weer een moeilijke..
Hoe mijn forumklok wederom de mist is ingegaan, beat me.
Zeker & vast één van de vorige topics terug juist gezet.
Daar ik als dusdanig in "fout" was, denk ik dat het het eerlijkste is dat cloink idd de winnaar is van de eerste.
Het bod van jgijsen was in die optiek 2 minuten te laat voor deze bieding, maar wel geldig voor de 2de 90A052043 -- die daarna terug overboden werd door helmuteke met 25 euro.
Ik ga dus tot aan dit bericht de oude tijd behouden, en dus cloink de eerste gunnen.
Voor de volgende 3, waarvan die van helmuteke dus terug ondervalt -- stel ik voor de juiste "forum"-tijd te nemen, aangezien deze als dusdanig iedereen nog de nodige kansen biedt om een bod uit te brengen.
dus in de oude & nieuwe orde :
(TS-tijd)
--> @ cloink -- GEWONNEN -- 14:51
(forum-tijd)
--> @ helmuteke -- 25 euro geboden -- vervalt donderdag 31 juli om 15:51
--> @ murdock447 -- 15 euro geboden -- vervalt morgen 30 juli om 07:30
1x QuickScan I QD2110 met 90A051922 (rechte kabel)
--> @ MClaeys -- 15 euro geboden -- vervalt morgen 30 juli om 19:47
cloink
Twitter: cloink
Bedankt: 152 keer
Sympathiek! :beerchug:
ooh. shiny.
helmuteke
Bedankt: 27 keer
cloink schreef:Sympathiek! :beerchug:
idd sympathiek , maar toch weer een gefoefel van jewelste.
op het einde van de rit zal er weer één den dupe van zijn
Bedankt: 757 keer
Er kan geen gefoefel zijn. De juiste uren zijn nl makkelijk op te sporen door gewoon de posts van de relevante biedingen te vergelijken. Of de klok nu juist of fout staat, het relatieve verschil tussen de twee klokken zal altijd hetzelfde zijn.
Bedankt: 757 keer
Cloink's bod was op 27/7 15:51
Jgijsen's bod was op 29/7 14:53
De 48u was dus nog niet afgelopen.
Bij jgijsen's tweede bod was het 15:48, de 48u was nog altijd aant lopen.
Volgens mij was dit tweede bod (20 voor beide elementen) dus nog geldig.
I stand corrected dus; tis weer een soep aant worden. Verplichte aanduiding EXACT welk item je voor biedt zou ni slecht zijn, alsook verplicht apart aanbieden van alle items, incl identieke, met unieke volgnummer.
Mods?
jgijsen
Bedankt: 5 keer
Ja ik ben dus gewoon de dupe en dit is een oneerlijke manier van werken.
De regels zijn simpel. 48 uur NA het bod loopt de bieding af.
Of we nu in de tijdszone van Shakamaka zitten of als de tijd op de server een uur verkeerd staat, maakt daar geen enkel verschil in.
Mijn bod is gebeurd BINNEN de tijdspanne van 48 uur, meer nog, zelfs mijn correctie door te bieden op BEIDE items was binnen deze tijdspanne.
Bijgevolg kan ik mij dan ook absoluut niet akkoord verklaren met deze manier van werken.
Bedankt: 1450 keer
Ik zal het nog even op een rijtje zetten op basis van de forumtijden (dit zijn de enige tijden die gelden).
door cloink op zo jul 27, 2014 15:51: 1 * 15 eur
door helmuteke op zo jul 27, 2014 17:30: 1 * 15 eur
door jgijsen op di jul 29, 2014 14:53: 1 * 20 eur --> dit is binnen de 48 uur, onduidelijk op welke van de twee hij biedt
door jgijsen op di jul 29, 2014 15:48: 2 * 20 eur --> dit is nog altijd binnen de 48 uur (47u en 57 minuten), hier heeft hij beide
door helmuteke op di jul 29, 2014 15:51: 1 * 25 eur
Momenteel gelden de boden van jgijsen voor 20 eur voor 1 van de twee toestellen en van helmuteke voor 25 eur voor het 2e toestel. En de bieding loopt nog verder!
cloink
Twitter: cloink
Bedankt: 152 keer
Fraai, ik heb ondertussen betaald! :roll:
ooh. shiny.
Bedankt: 1450 keer
Gelieve cloink dus terug te betalen... Tenzij hij meer biedt en de rest wil toevoegen! :)
Sorry voor de verawarring, nochtans ish et heel duidelijk als je de forumtijden bekijkt.
TiTanium
Bedankt: 472 keer
Dom zomer en winteruur zegt :evil:
Klopt ieder geval dat hij binnen de 48 uur zat.
Als Cloink tevreden is met het toestel waar ik op heb geboden wil ik mijn bod wel afstaan, meer dan 15 ging ik toch niet gaan omdat het maar voor wat gepruts was :) (had er dus geen speciale plannen mee).
Dan is ook geen terugbetaling nodig (tenzij iemand binnen de tijd alsnog meer bied).
cloink
Twitter: cloink
Bedankt: 152 keer
Wederom sympathiek! :beerchug:
Prima voor mij hoor, het type kabel kan me in principe gestolen worden, 't is voor hobby-gebruik. :-)
ooh. shiny.
