Als ik deze bekijk kan mijn VDSL lijn eigenlijk 100 mbit download halen ( in maart was het 57 mbit )
Maar alles wordt netjes begrensd op 30 mbit .
Wordt deze onnozele spel van cappen ooit opgelosd .
Laat zoals onze buurlanden gewoon internetten op snelheid wat men kan en niet wat men wil toelaten omwille van
onnezele oorlog tussen sips .
MVG
DEZE IS VAN VANDAAG
active profiel 30/6
Extended Port Status
Bme: 1 Port: 1
Downstream line rate: 34528 kbps
Upstream line rate: 7392 kbps
Bearer0 Downstream payload rate: 0 kbps
Bearer1 Downstream payload rate: 30040 kbps
Bearer0 Upstream payload rate: 0 kbps
Bearer1 Upstream payload rate: 6048 kbps
Downstream attainable payload rate: 100764 kbps
Downstream attainable line rate: 120992 kbps
Downstream Training Margin: 30.4 dB
Downstream Line Protection (Bearer1 Path): 1.0 DMT Symbols
Upstream Line Protection (Bearer1 Path): 1.0 DMT Symbols
Near-end ITU Vendor Id: 0xb500494b4e530200
Far-end ITU Vendor Id: 0xb500494b4e530000
Downstream delay: 7.5 ms
Upstream delay: 5.4 ms
Tx total power -25.5 dbm
FE Tx total power 12.0 dbm
VDSL Estimated Loop Length : 254 ft
G.Hs Estimated Near End Loop Length : 1589 ft
G.Hs Estimated Far End Loop Length :288 ft
Current framing mode: 0x10
DEZE IS VAN 5 MAART 2014
( 25/10 PROFIEL high upload )
Bme: 1 Port: 1
Downstream line rate: 30400 kbps
Upstream line rate: 12256 kbps
Bearer1 Downstream payload rate: 25184 kbps
Bearer1 Upstream payload rate: 10048 kbps
Downstream attainable payload rate: 57560 kbps
Downstream attainable line rate: 72296 kbps
Downstream Training Margin: 27.8 dB
Downstream Line Protection (Bearer1 Path): 4.0 DMT Symbols
Downstream delay: 14.4 ms
Upstream delay: 5.5 ms
Tx total power -25.2 dbm
FE Tx total power 10.2 dbm
VDSL Estimated Loop Length : 215 ft
G.Hs Estimated Near End Loop Length : 1595 ft
G.Hs Estimated Far End Loop Length :264 ft
Heeft vdsl nog zin !!!!!!!
einstein1978
- Starter
Laatst gewijzigd door TiTanium 30 apr 2014, 20:00, in totaal 2 gewijzigd.
Reden: Rode kleur is enkel voor moderators. + caps verwijderd uit topictitel.
- meon
- Twitter: meon
- Bedankt: 780 keer
Ten eerste: crossposten wordt hier niet geapprecieerd.
Snelheidslimieten op VDSL zijn er om een stuk ongelijkheid weg te werken.
Anders dan de "best effort" die in het buitenland wordt gehanteerd (je krijgt wat je kan krijgen, geen garanties) kiest Belgacom er voor om VDSL als stabiel product aan te bieden: de verkondigde snelheden worden min of meer gegarandeerd. Tegenwoordig krijgt het gros van de VDSL-gebruikers de verkondigde 30 Mbps downlink en haalt deze snelheid ook consequent.
Dankzij technieken op de lijn kunnen de snelheden echter opgetrokken worden voor lijnen die hier technisch toe in staat zijn. Let wel: deze snelheden worden noch gegarandeerd, noch verkocht. Sommigen kunnen dus op een stabiele 70 Mbps zitten, anderen blijven op hun provisioningprofiel van 30 Mbps zitten.
Ikzelf ben een van de gelukkigen met nog een ADSL2+-aansluiting van 12 Mbps, maar zie je mij zo roepen zoals jij doet?
DIBO
- Bedankt: 98 keer
@einstein1978
jouw VDSL lijn zit in de absolute top, op slechts enkele tientallen meters van de ROP. Beter kan bijna niet. Als je hiermee niet tevreden bent, dan heb je idd. voor de verkeerde technologie gekozen. Vanaf dag één al met 120/6 kunnen werken, da's bij die andere club.
DIBO
- Bedankt: 98 keer
TS is vandaag (klik) overgestapt van een high upload EDPnet naar Scarlet VDSL aansluiting.
DLM heeft wel net iets meer tijd nodig
En Eva werkt niet voor Scarlet, daarvoor moet je bij Cindy zijn (maar in dit geval moet hij best even afwachten voor hij deze vrouwen lastig valt).
- gbmed
- Erelid
- Uitgedeelde bedankjes: 228 keer
- Bedankt: 126 keer
Excuseer ? Zelfs al haal je op de eerste dag 150.000/35.000 attainable waarden (om maar iets te zeggen) dan nog begint alles bij het provisioningsprofiel !! En dat is 30/6 SYNC en 30/X surf waar X bepaald wordt door het abbonement.gm123 schreef:Wel vreemd dat hij maar op een 30 Mbit profiel zit dan. DLM staat misschien af? Misschien eens een berichtje naar Eva doen, dat zal meer uithalen dan hier klagen.
De TS scoort iig. zeer hoog op kennis en ervaring:
Geen verder commentaar .... Einstein iemand ?Wordt deze onnozele spel van cappen ooit opgelosd .
PS: NEEN, VDSL HEEFT GEEN ZIN VANWEGE NIET MEER ONDERSTEUND !! Wel zitten we ondertussen op VDSL2 en bijna op FTTH
iRockabizzydilly
- Bedankt: 172 keer
't Is hier al gezegd maar met zo een lijn mag je best tevreden zijn, het enige wat nog rest is geduld. DLM komt langs, en dan haal je wie weet zelfs 70Mbit.
- Bedankt: 757 keer
Offtopic: Misschien moeten we in de modregels toch ns allcaps topics met uitroeptekens "verbieden"; een modedit (indien technisch mogelijk) naar een minder schreeuwerige toestand zou niet misstaan
Post made via mobile device ]
Post made via mobile device ]- TiTanium
- Bedankt: 472 keer
Caps zijn verwijderd, meestal wordt dit manueel aangepast
gm123
- Bedankt: 116 keer
Ik ging er vanuit dat hij al langer op dat profiel zit en dat DLM nog steeds niet is langs geweest, nu zie ik dat hij in maart nog op een high upload profiel zat en hij waarschijnlijk gewoon nog wat geduld moet hebben. Erg duidelijk was het niet hé uit zijn post.gbmed schreef:Excuseer ? Zelfs al haal je op de eerste dag 150.000/35.000 attainable waarden (om maar iets te zeggen) dan nog begint alles bij het provisioningsprofiel !! En dat is 30/6 SYNC en 30/X surf waar X bepaald wordt door het abbonement.gm123 schreef:Wel vreemd dat hij maar op een 30 Mbit profiel zit dan. DLM staat misschien af? Misschien eens een berichtje naar Eva doen, dat zal meer uithalen dan hier klagen.
