Probeer al enige tijd mijn freepbx in orde te krijgen maar zonder suc6 ...
IP trunk online 1
IP trunk registrations 1
Mijn outbound calls werken en krijg het correcte DID nummer
Spijtig genoeg krijg ik geen inbound calls .... Elke maal ik bel op het nummer kom ik terecht op een bericht: "The number you have dialed is not in service"
Dit is wat ik krijg in de log, dus call lijkt wel binnen te komen, maar dan valt die op
-- Executing [s@from-sip-external:5] Playback("SIP/weepee_out_prim-0000004c", "ss-noservice") in new stack
-- <SIP/weepee_out_prim-0000004c> Playing 'ss-noservice.gsm' (language 'en')
-- Executing [3211369816@from-sip-external:1] NoOp("SIP/weepee_out_prim-0000004c", "Received incoming SIP connection from unknown peer to 3211369816") in new stack
-- Executing [3211369816@from-sip-external:2] Set("SIP/weepee_out_prim-0000004c", "DID=3211369816") in new stack
-- Executing [3211369816@from-sip-external:3] Goto("SIP/weepee_out_prim-0000004c", "s,1") in new stack
-- Goto (from-sip-external,s,1)
-- Executing [s@from-sip-external:1] GotoIf("SIP/weepee_out_prim-0000004c", "0?from-trunk,3211369816,1") in new stack
-- Executing [s@from-sip-external:2] Set("SIP/weepee_out_prim-0000004c", "TIMEOUT(absolute)=15") in new stack
Channel will hangup at 2013-05-22 16:38:44.903 CEST.
-- Executing [s@from-sip-external:3] Answer("SIP/weepee_out_prim-0000004c", "") in new stack
-- Executing [s@from-sip-external:4] Wait("SIP/weepee_out_prim-0000004c", "2") in new stack
== Spawn extension (from-sip-external, s, 5) exited non-zero on 'SIP/weepee_out_prim-0000004c'
-- Executing [h@from-sip-external:1] NoOp("SIP/weepee_out_prim-0000004c", "Hangup") in new stack
-- Executing [h@from-sip-external:2] Set("SIP/weepee_out_prim-0000004c", "DID=s") in new stack
-- Executing [h@from-sip-external:3] Goto("SIP/weepee_out_prim-0000004c", "s,1") in new stack
-- Executing [s@from-sip-external:1] GotoIf("SIP/weepee_out_prim-0000004c", "0?from-trunk,s,1") in new stack
Channel will hangup at 2013-05-22 16:38:48.973 CEST.
== Spawn extension (from-sip-external, s, 3) exited non-zero on 'SIP/weepee_out_prim-0000004c'
Iemand enig idee ...
