* Bugcheck Analysis *
DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high. This is usually
caused by drivers using improper addresses.
If kernel debugger is available get stack backtrace.
Arguments:
Arg1: 00000009, memory referenced
Arg2: 00000002, IRQL
Arg3: 00000000, value 0 = read operation, 1 = write operation
Arg4: 00000009, address which referenced memory
Debugging Details:
READ_ADDRESS: 00000009
CURRENT_IRQL: 2
FAULTING_IP:
+9
00000009 ?? ???
CUSTOMER_CRASH_COUNT: 2
DEFAULT_BUCKET_ID: DRIVER_FAULT
BUGCHECK_STR: 0xD1
LAST_CONTROL_TRANSFER: from 035ab100 to 00000009
STACK_TEXT:
WARNING: Frame IP not in any known module. Following frames may be wrong.
f9e4ced8 035ab100 00000004 0b15d100 00000009 0x9
00010292 00000000 00000000 00000000 00000000 0x35ab100
FAILED_INSTRUCTION_ADDRESS:
+9
00000009 ?? ???
FOLLOWUP_IP:
nt!KiTrap0E+2ad
804d7c50 ?? ???
SYMBOL_STACK_INDEX: 1
FOLLOWUP_NAME: MachineOwner
SYMBOL_NAME: nt!KiTrap0E+2ad
MODULE_NAME: nt
IMAGE_NAME: ntoskrnl.exe
DEBUG_FLR_IMAGE_TIMESTAMP: 3b7de38f
STACK_COMMAND: .trap fffffffff9e4ce68 ; kb
BUCKET_ID: 0xD1_CODE_AV_BAD_IP_nt!KiTrap0E+2ad
Followup: MachineOwner
edit>>> ik weet dat het iets te maken heeft met een driver... maar kan ik op een of andere manier met deze info te weten komen de welke het juist is?
dit heb ik ook gevondenBeschadigd blok in apparaat \Device\CdRom1.
maar er zit geen schijf in de cdrom drive
![Neutral :|](./images/smilies/icon_neutral.gif)
