I have a fritz box 7390 , new firmware , if I want to increase the stability ,or inp , (e.g) , rthe Belgacom line is out (the stabililty is also awful) Do you have such problems.
Thanks in advance
Fritzbox 7390 and new firmware
- fryelectro
- Uitgedeelde bedankjes: 363 keer
- Bedankt: 174 keer
I don't have stability issues (I do see some Errors (ES)at the "DSL Telephone switch" which I've never seen before) with the new firmware BUT since I applied it, a few hours later I was forced back to my provisiong profile of 30/6 instead of 70/6... It is not sure that the firmware upgrade has something to do with it, but in the three years I am connected to VDSL2, I was never set on a lower profile....
Orange Go Extreme
Orange Go Extreme
For my own part the profile in snr was doing "yoyo" . In order to stabilise I did what I always did and then no connxion at all . As a result two interventions of a technician and two ports out , so I go back to the old firmware and no problem anymore
So I think there is a problem !
- Bedankt: 3720 keer
- Recent bedankt: 20 keer
If you really want some help from the Forum community, you should give a few more details of your xDSL subscription, e.g.
- - are you ADSL2+ or VDSL2 ?
- what is your modem sync speed?
- line values (attenuation, snr)?
- last but not least: how does your internal wiring look like (starting from the Belgacom wallplate, splitter/filter, etc ..)
So
I am in VDS2, distance from the ROP followin g Hierzo : 354 m , followin Belgacom 498 m
You'll find here after all my data
Sorry but my Nederlands is niet goed
The problems came when I did the upgrade and I want to stabilise my line
Thank you for your help
PS no problem (physical problem on my line) but a "perturbating neighbour" normally SNR equal to to 20 dB but I have this problem.
All the data are very good except this
- Bijlagen
- (106.92 KiB) 1637 keer gedownload
Here also with the new firmware two VDSL ports out of service by playing with the increase the stability function. Now I'm using my b-box2 in bridge mode and all works smoothly.
