error: HTTP/1.1 404 Not Found
En eventjes verder stopt vlc player ...
stream_filter_httplive info: updating hls stream (program-id=0, bandwidth=1851273) has 0 segments
stream_filter_httplive info: updating hls stream (program-id=0, bandwidth=0) has 5 segments
stream_filter_httplive info: - segment 9218 appended
access_http error: error: HTTP/1.1 404 Not Found
main error: no suitable access module for `https://weepeetv.my-stream.eu/channel/8d39efee-220c-4f1d-bff1-918ef5831e4d/7acb6a6f-66df-445e-833e-cb6872dccd05/part-135653113400009218.ts'
stream_filter_httplive error: downloaded segment 9218 from stream 0 failed
stream_filter_httplive info: playing segment 9216 from stream 0
stream_filter_httplive info: Reloading HLS live meta playlist
stream_filter_httplive info: Live Playlist HLS protocol version: 1
stream_filter_httplive info: - segment 9219 appended
stream_filter_httplive info: downloaded segment 9219 from stream 0
stream_filter_httplive info: playing segment 9217 from stream 0
stream_filter_httplive info: - segment 9220 appended
stream_filter_httplive info: downloaded segment 9220 from stream 0
stream_filter_httplive info: updating hls stream (program-id=0, bandwidth=1865862) has 0 segments
stream_filter_httplive info: - segment 9269 appended
main error: no suitable access module for `https://weepeetv.my-stream.eu/channel/8d39efee-220c-4f1d-bff1-918ef5831e4d/7acb6a6f-66df-445e-833e-cb6872dccd05/part-135653113400009269.ts'
stream_filter_httplive error: downloaded segment 9269 from stream 0 failed
Herstarten lukte niet.
stream_filter_httplive info: - segment 9267 appended
stream_filter_httplive info: playing segment 9264 from stream 0
stream_filter_httplive info: downloaded segment 9267 from stream 0
stream_filter_httplive info: - segment 9268 appended
stream_filter_httplive info: playing segment 9265 from stream 0
stream_filter_httplive info: downloaded segment 9268 from stream 0
stream_filter_httplive info: HTTP Live Streaming (weepeetv.my-stream.eu/channel/8d39efee-220c-4f1d-bff1-918ef5831e4d/7acb6a6f-66df-445e-833e-cb6872dccd05/stream.m3u8)
stream_filter_httplive info: Choose segment 2/5 (sequence=9273)
stream_filter_httplive info: downloaded segment 9273 from stream 0
main error: no suitable access module for `https://weepeetv.my-stream.eu/channel/8d39efee-220c-4f1d-bff1-918ef5831e4d/7acb6a6f-66df-445e-833e-cb6872dccd05/part-135653113400009274.ts'
stream_filter_httplive error: downloaded segment 9274 from stream 0 failed
stream_filter_httplive error: fetching first segment failed.
es error: cannot peek
ps error: cannot peek
mpgv error: cannot peek
mjpeg error: cannot peek
main error: no suitable demux module for `https/://weepeetv.my-stream.eu/channel/8d39efee-220c-4f1d-bff1-918ef5831e4d/7acb6a6f-66df-445e-833e-cb6872dccd05/stream.m3u8'
Een tweede keer herstarten lukte wel.
EDIT:
Nog eentje.
stream_filter_httplive info: updating hls stream (program-id=0, bandwidth=693870) has 0 segments
stream_filter_httplive info: - segment 6335 appended
main error: no suitable access module for `https://weepeetv.my-stream.eu/channel/9f89df7c-b999-45fd-acab-a6a0f545a8a2/bd57c4f0-4a58-4153-b8a0-9f6b73864703/part-135650731300006335.ts'
stream_filter_httplive error: downloaded segment 6335 from stream 0 failed
stream_filter_httplive info: playing segment 6333 from stream 0
stream_filter_httplive info: - segment 6336 appended
stream_filter_httplive info: playing segment 6334 from stream 0
stream_filter_httplive info: downloaded segment 6336 from stream 0
stream_filter_httplive info: - segment 6337 appended
main error: no suitable access module for `https://weepeetv.my-stream.eu/channel/9f89df7c-b999-45fd-acab-a6a0f545a8a2/bd57c4f0-4a58-4153-b8a0-9f6b73864703/part-135650731300006337.ts'
stream_filter_httplive error: downloaded segment 6337 from stream 0 failed
stream_filter_httplive info: HTTP Live Streaming (weepeetv.my-stream.eu/channel/9f89df7c-b999-45fd-acab-a6a0f545a8a2/bd57c4f0-4a58-4153-b8a0-9f6b73864703/stream.m3u8)
stream_filter_httplive info: Choose segment 2/5 (sequence=6339)
stream_filter_httplive info: downloaded segment 6339 from stream 0
main error: no suitable access module for `https://weepeetv.my-stream.eu/channel/9f89df7c-b999-45fd-acab-a6a0f545a8a2/bd57c4f0-4a58-4153-b8a0-9f6b73864703/part-135650731300006340.ts'
stream_filter_httplive error: downloaded segment 6340 from stream 0 failed
main error: no suitable demux module for `https/://weepeetv.my-stream.eu/channel/9f89df7c-b999-45fd-acab-a6a0f545a8a2/bd57c4f0-4a58-4153-b8a0-9f6b73864703/stream.m3u8'
EDIT:
Nog eentje.
stream_filter_httplive info: Choose segment 2/5 (sequence=6342)
stream_filter_httplive info: downloaded segment 6342 from stream 0
stream_filter_httplive info: downloaded segment 6343 from stream 0
stream_filter_httplive info: playing segment 6342 from stream 0
ts error: MPEG-4 descriptor not found
packetizer_mpeg4audio info: AAC channels: 2 samplerate: 48000
main error: no suitable access module for `https://weepeetv.my-stream.eu/channel/9f89df7c-b999-45fd-acab-a6a0f545a8a2/bd57c4f0-4a58-4153-b8a0-9f6b73864703/part-135650731300006344.ts'
stream_filter_httplive error: downloaded segment 6344 from stream 0 failed
avcodec info: obtained IDirect3DDeviceManager9
avcodec info: DXVA2CreateVideoService Success!
avcodec info: Using DXVA2 (NVIDIA GeForce 8600 GT , vendor 4318(NVIDIA), device 1026, revision 161) for hardware decoding.
freetype error: Breaking unbreakable line
EDIT:
Herstarten en praktisch onmiddellijk volledig gestopt.
stream_filter_httplive info: updating hls stream (program-id=0, bandwidth=1063478) has 0 segments
stream_filter_httplive info: - segment 6345 appended
stream_filter_httplive info: downloaded segment 6345 from stream 0
main error: ES_OUT_SET_(GROUP_)PCR is called too late (pts_delay increased to 1000 ms)
main error: ES_OUT_RESET_PCR called
stream_filter_httplive info: - segment 6346 appended
stream_filter_httplive info: - segment 6347 appended
stream_filter_httplive info: downloaded segment 6346 from stream 0
stream_filter_httplive info: downloaded segment 6347 from stream 0
EDIT:
Herstarten lukt niet.
stream_filter_httplive info: Choose segment 2/5 (sequence=6348)
stream_filter_httplive info: downloaded segment 6348 from stream 0
main error: no suitable access module for `https://weepeetv.my-stream.eu/channel/9f89df7c-b999-45fd-acab-a6a0f545a8a2/bd57c4f0-4a58-4153-b8a0-9f6b73864703/part-135650731300006349.ts'
stream_filter_httplive error: downloaded segment 6349 from stream 0 failed
Ook een tweede keer niet.
stream_filter_httplive info: Choose segment 2/5 (sequence=6351)
stream_filter_httplive info: downloaded segment 6351 from stream 0
main error: no suitable access module for `https://weepeetv.my-stream.eu/channel/9f89df7c-b999-45fd-acab-a6a0f545a8a2/bd57c4f0-4a58-4153-b8a0-9f6b73864703/part-135650731300006352.ts'
stream_filter_httplive error: downloaded segment 6352 from stream 0 failed
Een derde keer bijna.
stream_filter_httplive info: Choose segment 2/5 (sequence=6353)
stream_filter_httplive info: downloaded segment 6353 from stream 0
stream_filter_httplive info: downloaded segment 6354 from stream 0
stream_filter_httplive info: playing segment 6353 from stream 0
main error: no suitable access module for `https://weepeetv.my-stream.eu/channel/9f89df7c-b999-45fd-acab-a6a0f545a8a2/bd57c4f0-4a58-4153-b8a0-9f6b73864703/part-135650731300006355.ts'
stream_filter_httplive error: downloaded segment 6355 from stream 0 failed
stream_filter_httplive info: playing segment 6354 from stream 0
stream_filter_httplive info: updating hls stream (program-id=0, bandwidth=810656) has 0 segments
stream_filter_httplive info: - segment 6356 appended
stream_filter_httplive info: downloaded segment 6356 from stream 0
stream_filter_httplive info: - segment 6357 appended
stream_filter_httplive info: downloaded segment 6357 from stream 0
access_http error: failed to send request
main error: no suitable access module for `https://weepeetv.my-stream.eu/channel/9f89df7c-b999-45fd-acab-a6a0f545a8a2/bd57c4f0-4a58-4153-b8a0-9f6b73864703/stream.m3u8'
stream_filter_httplive error: reloading playlist failed
Vierde keer bijna.
stream_filter_httplive info: Choose segment 2/5 (sequence=6356)
stream_filter_httplive info: playing segment 6356 from stream 0
main error: no suitable access module for `https://weepeetv.my-stream.eu/channel/9f89df7c-b999-45fd-acab-a6a0f545a8a2/bd57c4f0-4a58-4153-b8a0-9f6b73864703/part-135650731300006358.ts'
stream_filter_httplive error: downloaded segment 6358 from stream 0 failed
stream_filter_httplive info: playing segment 6357 from stream 0
stream_filter_httplive info: updating hls stream (program-id=0, bandwidth=948046) has 0 segments
stream_filter_httplive info: - segment 6359 appended
stream_filter_httplive info: downloaded segment 6359 from stream 0
stream_filter_httplive info: - segment 6360 appended
stream_filter_httplive info: downloaded segment 6360 from stream 0
