[*]Te koop wegens niet in gebruik.
[*]Nieuwe staat ( enkel om te testen gebruikt )
[*]Levenslange Garantie
[*]19"
[*]Versie 2
[*]Alle toebehoren + originele doos
[*] Min Prijs : 100€
[*] Meeneem Prijs : 125€
[*] Ruilen tegen : FritzBox 7390
[*] Afhalen te Wetteren of Kila ( extra kosten )
[*] Ik sluit af op 09/12/2012
Physical Interfaces
LAN ports: Eight (8) 10/100 Mbps auto-sensing, Auto Uplink™ RJ-45 ports; one (1) Gigabit 10/100/1000 Mbps LAN port; one LAN port can be dedicated hardware DMZ port
WAN ports: Two 10/100 Mbps Ethernet RJ-45 ports with auto fail-over and load balancing
Serial port: One console port for command line interface (CLI) support
Security Features
SPI firewall: Stateful packet inspection (SPI) to prevent notorious denialofservice (DoS) attacks, including logging, reporting and email alerts, address, service and protocol, Web URL keyword filtering, prevent replay attack (reassembly attack), port/service blocking. Advanced features include block Java/URL/ ActiveX based on extension, FTP/SMTP/RPC program filtering
SIP Application Layer Gateway
SIP compatibility list:
Linksys SPA-901
Linksys SPA-941
SNOM M3
Cisco 7940G
X-Lite 3.0 (software for phones)
D-Link DPH-140S
Grandstream GXP-2000
Polycom SoundStation 6000
Siemens C450
Aastra 51i
VPN functionality: Two hundred (200) dedicated VPN tunnels, Manual key and Internet Key Exchange Security Association (IKE SA) assignment with pre-shared key and RSA/DSA signatures, key life and IKE lifetime time settings, perfect forward secrecy (Diffie-Hellman groups 1 and 2 and Oakley support), operating modes (main, aggressive), fully qualified domain name (FQDN) support for dynamic IP address VPN connections.
IPsec support: IPsec-based 56-bit (DES), 168-bit (3DES), or 256-bit (AES) encryption algorithm, MD5 or SHA-1 hashing algorithm, AH/AH-ESP support, PKI features with X.509 v.3 certificate support, remote access VPN (client-to-site), site-to-site VPN, IPsec NAT traversal (VPN pass-through)
Mode of Operation: One-to-one/many-to-one Multi-network Address Translation (NAT), classical routing, unrestricted users per port
IP Address Assignment: Static IP address assignment, internal DHCP server on LAN, DHCP client on WAN, PPPoE client support
Performance Features
Throughput:
LAN-to-WAN: up to 80 Mbps
3DES IPsec tunnel: Up to 30 Mbps
Management Features
Administration interface: SNMP (v1b, v2c) support, telnet, web graphic user interface, Secure Sockets Layer (SSL) remote management, user name and password protected; secure remote management support authenticated through IP address or IP address range and password; configuration changes/upgrades through Web GUI.
Configuration and upgrades: Upload and download configuration settings, firmware upgradeable flash memory
Logging: SYSLOG, email alerts
Functions
VPN Wizard to simplify configuration of the VPN, auto detect to automatically detect ISP address type (static, dynamic, PPPoE), port range forwarding, port triggering, exposed host (DMZ), hardware DMZ, enable/disable WAN ping, DNS proxy, MAC address cloning/ spoofing, Network Time Protocol NTP support, keyword content filtering, email alerts, DHCP server (info and display table), PPPoE login client support, WAN DHCP client, diagnostic tools (ping, trace route, other), port/service, Auto Uplink on switch ports and Quality of Service (QoS).
Protocol Support
Network: IP routing, TCP/IP, UDP, ICMP, PPPoE
IP addressing: DHCP (client and server)
Routing: RIP v1, RIPv2 (static routing, dynamic routing)
VPN/security: IPsec (ESP, AH), MD5, SHA-1, DES, 3DES, IKE, PKI, AES
Maintenance
Save/restore configuration, restore defaults, upgrades via Web browser, display statistics, logging, SYSLOG support
Hardware Specifications
Processor: 533 MHz Intel XScale IXP425
Memory: 32 MB flash, 64 MB DRAM
Encryption accelerator: Cavium Processor up to 60+ Mbps (3DES+SHA-1) encryption
Power requirements: 100-240V AC, 50-60 Hz, 15W Max
Dimensions: 33 x 20.3 x 4.4 cm (13 x 8 x 1.75 in)
Weight: 2.01 kg (4.42 lb)
Environmental Specifications
Operating temperature: 0º to 40º C (32º to 104º F)
Operating humidity: 90% maximum relative humidity, non-condensing
Warranty
Switch: NETGEAR Lifetime Warranty†
Power supply: NETGEAR 3-year Warranty
Package Contents
ProSafe Dual WAN VPN Firewall with 8-port 10/100 Switch (FVX538)
Ethernet cable
Rack mount kit
Installation guide
Resource CD with five user license of ProSafe VPN Client Software
Warranty/support information card
Post made via mobile device ]
