Cisco 877W Wlan configuratie woes...
vasonline
Uitgedeelde bedankjes: 116 keer
Bedankt: 18 keer
Dag Iedereen,
Ik heeb veel moeite om het wlan gedeelte van mijn Cisco 877W aan de praat te krijgen.
verschillende voorbeelden nagekeken, maar ergens moet er toch iets verkeerd zijn.
Kan jij me helpen?
Groetjes & alvast bedankt!!
Building configuration...
Current configuration : 7244 bytes
! No configuration change since last restart
version 12.4
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname  XXXXXXXXXXXXXXXXXXXXXXXX
boot-start-marker
boot-end-marker
logging buffered 4096
enable secret XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX!
no aaa new-model
clock timezone GMT 1
clock summer-time GMT+2 recurring last Sun Mar 2:00 last Sun Oct 2:00
dot11 syslog
dot11 ssid XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
   vlan 3
   authentication open
   authentication key-management wpa
   guest-mode
   wpa-psk ascii XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX!
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.0.0.200 10.0.0.254
ip dhcp pool vlan2
   import all
   network 10.0.1.0 255.255.255.0
   default-router 10.0.1.254
   dns-server 10.0.1.254
   domain-name XXXXXXXXXXXXXXXXXX
   lease 14
ip dhcp pool vlan1
   network 10.0.0.0 255.255.255.0
   dns-server 10.0.0.254
   default-router 10.0.0.254
   lease 14
ip dhcp pool vlan3
   import all
   network 10.0.2.0 255.255.255.0
   default-router 10.0.2.254
   dns-server 10.0.2.254
 lease 14
ip inspect name firewall dns
ip inspect name firewall udp
ip inspect name firewall tcp
ip inspect name firewall ftp
ip inspect name router udp router-traffic
ip inspect name router tcp router-traffic
ip inspect name router icmp router-traffic
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
ip domain name XXXXXXXXXXX
ip name-server 195.238.2.22
ip name-server 195.238.2.21
ip name-server 208.67.222.222
ip name-server 208.67.220.220
username admin password XXXXXXXXXXXXXXXXXXXXXXXXXXXX
crypto isakmp policy 1
 encr 3des
 authentication pre-share
 group 2
crypto isakmp key XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
crypto ipsec transform-set 3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set AES-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set 3DES-SHA-compression esp-3des esp-sha-hmac comp-lzs
crypto ipsec transform-set AES-SHA-compression esp-aes esp-sha-hmac comp-lzs
crypto map VPN-Map-1 10 ipsec-isakmp
 ! Incomplete
 set peer XXXXXXXXXXXXXXXXXX
 set transform-set AES-SHA-compression
 set pfs group2
 match address Crypto-lijst
crypto map VPN-Map-1 20 ipsec-isakmp
 set peer XXXXXXXXXXXXXXXXXXXXXX
 set pfs group2
 match address Crypto-lijst-secretariaat
archive
 log config
  hidekeys
bridge irb
interface ATM0
 description *** I-line ADSL to Skynet  ***
 ip address XXXXXXXXXXXXXXXXXXXXXXXXXXXXX
 ip access-group 102 in
 ip inspect router out
 ip nat outside
 ip virtual-reassembly
 no atm ilmi-keepalive
 pvc 8/35
  protocol ip XXXXXXXXXXXXXXXXXX broadcast
  encapsulation aal5snap
 dsl operating-mode auto
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
 switchport access vlan 2
interface Dot11Radio0
 no ip address
 ip nat inside
 no ip route-cache cef
 no ip route-cache
 no dot11 extension aironet
 encryption mode ciphers tkip
 encryption vlan 3 mode ciphers tkip
 speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
 channel 2437
 station-role root
 no cdp enable
interface Dot11Radio0.1
 encapsulation dot1Q 1 native
 ip address 10.0.2.254 255.255.255.0
 ip access-group 101 in
 ip inspect firewall in
 ip nat inside
 no ip route-cache
 no cdp enable
 bridge-group 1
 bridge-group 1 subscriber-loop-control
 bridge-group 1 spanning-disabled
 bridge-group 1 block-unknown-source
 no bridge-group 1 source-learning
 no bridge-group 1 unicast-flooding
interface Vlan1
 ip address 10.0.0.254 255.255.255.0
 ip access-group 101 out
 ip nat inside
 hold-queue 100 out
interface Vlan2
 ip address 10.0.1.254 255.255.255.0
 ip nat inside
 hold-queue 100 out
interface Vlan3
 no ip address
 ip nat inside
 bridge-group 1
 hold-queue 100 out
interface BVI1
 no ip address
 ip nat inside
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 XXXXXXXXXXXXXXXXXXXXXXXX
no ip http server
no ip http secure-server
ip dns server
ip nat inside source list 101 interface ATM0 overload
ip access-list extended Crypto-lijst
ip access-list extended Crypto-lijst-secretariaat
 permit ip 10.0.0.0 0.0.0.255 192.168.89.0 0.0.0.255
access-list 101 deny   ip 10.0.0.0 0.0.0.255 192.168.89.0 0.0.0.255
access-list 101 permit tcp any host 195.238.5.128 eq smtp
access-list 101 deny   tcp any any eq smtp log
access-list 101 permit ip 0.0.0.0 255.255.255.0 any
access-list 101 permit ip any any
access-list 102 remark Gefragmenteerde paketten blokkeren
access-list 102 deny   tcp any any log fragments
access-list 102 deny   udp any any log fragments
access-list 102 deny   icmp any any log fragments
access-list 102 remark Prive adressen niet vanop internet
access-list 102 deny   ip 10.0.0.0 0.255.255.255 any
access-list 102 deny   ip 172.16.0.0 0.15.255.255 any
access-list 102 deny   ip 192.168.0.0 0.0.255.255 any
access-list 102 deny   ip 127.0.0.0 0.255.255.255 any
access-list 102 deny   ip host 255.255.255.255 any
access-list 102 deny   ip host 0.0.0.0 any
access-list 102 remark VPN vanuit  toestaan
access-list 102 permit udp host XXXXXXXXXXXX any eq isakmp
access-list 102 permit esp host XXXXXXXXXXXX any
access-list 102 permit udp host XXXXXXXXXXXXXX any eq isakmp
access-list 102 permit esp host XXXXXXXXXXXXXX any
access-list 102 remark SSH toelaten vanuit
access-list 102 permit tcp host XXXXXXXXXXXXXX any eq 22 log
access-list 102 permit tcp host XXXXXXXXXXXX any eq 22 log
access-list 102 remark Imcp instellingen
access-list 102 permit icmp any any echo-reply
access-list 102 permit icmp any any time-exceeded
access-list 102 permit icmp any any unreachable
access-list 102 permit icmp any any parameter-problem
access-list 102 permit icmp any any source-quench
access-list 102 permit icmp any any packet-too-big
access-list 102 permit icmp any any administratively-prohibited
access-list 102 deny   ip any any log
control-plane
bridge 1 protocol ieee
bridge 1 route ip
banner motd ^CCC
^C
line con 0
 exec-timeout 120 0
 no modem enable
 stopbits 1
line aux 0
line vty 0 4
 access-class 1 in
 exec-timeout 120 0
 login local
 transport input ssh
scheduler max-task-time 5000
sntp server 207.46.232.182
end
Momenteel werkt alles, behalve het Wlan.
Interface                  IP-Address      OK? Method Status                Protocol
FastEthernet0              unassigned      YES unset  up                    up
FastEthernet1              unassigned      YES unset  up                    up
FastEthernet2              unassigned      YES unset  up                    up
FastEthernet3              unassigned      YES unset  up                    up
Dot11Radio0                unassigned      YES NVRAM  reset                 down
Dot11Radio0.1              10.0.2.254      YES NVRAM  reset                 down
ATM0                     xxxxxxxx       YES NVRAM  up                    up
Vlan1                      10.0.0.254      YES NVRAM  up                    up
NVI0                      xxxxxxxxx      YES unset  up                    up
Vlan2                      10.0.1.254      YES NVRAM  up                    up
Vlan3                      unassigned      YES NVRAM  up                    down
BVI1                       unassigned      YES NVRAM  down                  down
Laatst gewijzigd door vasonline 29 okt 2010, 21:43, in totaal 2 gewijzigd.
Bedankt: 208 keer
Wat lukt er, wat niet ?
Wat geeft een debug ?
Al geprobeerd zonder enige security ?
vasonline
Bedankt: 18 keer
Tomsworld schreef:Wat lukt er, wat niet ?
ik heb er even een sh ip int brief bijgevoegd.
Alles werkt, behalve het wlan gedeelte.
LAN, 2 VLANS, en 1 VPN.
Groetjes
Bedankt: 208 keer
Groetjes
Wat werkt niet ?
- Zie je de ssid
- Kan je je niet verbinden ?
- Krijg je geen ip ?
vasonline
Bedankt: 18 keer
Tomsworld schreef:
Wat werkt niet ?
- Zie je de ssid
Zoals je ziet in sh ip int brief, krijg ik de interfaces dot11 radio niet up.
Het resulaat is dat de wlan radio gewoon uitstaat momenteel (geen ssid, niks, nada ;) )
Debug wil ik aanzetten, welke parameter?
Want één keer alle debug messages aangezet, en de klassieke beginnersfout: console overwhelmed, machine overloaded... ;)
Groetjes
trobbelke
ik heb geen ervaring met de 800 reeks, alleen met de Aironet 1200 reeks, maar als ge via de web interface probeert de radio aan te zetten, krijgt ge dan misschien een melding waarom het niet gaat?
algey
vasonline schreef: Zoals je ziet in sh ip int brief, krijg ik de interfaces dot11 radio niet up.
VasOnline,
Wil je de hele hele running-conf hier even neerzetten?
vasonline
Bedankt: 18 keer
VasOnline,
Dag,
In mijn eerste post kan je de running config vinden. (onder "code")
Mvg,
UPDATE:
Ik heb het http://blogs.techrepublic.com.com/networking/?p=580
Cisco 871W worksheet gedownload en nagekeken met mijn configuratie, en dat ziet er nu al heel wat beter uit!
Een wifi connectie maken probeer ik op het moment dat ik daar ben (vanop afstand alles aangepast)
Ook voor andere Cisco configuratievragen is dit een leuk worksheet, omdat het een goede structuur geeft,
met extra uitleg.
Voor België met ADSL en PPPoE moet je zoiets doen:
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
interface ATM0.1 point-to-point
description Wan zijde
no ip redirects
no ip unreachables
no ip proxy-arp
pvc 8/35
protocol ppp dialer
dialer pool-member 1
(dialer 1 zit reeds in het template)
Groetjes,
S.
